I need to get my feet pointed correctly with some good examples of using the SPI protocol with Arduino. I was told to include the SPI library into the sketch, though the examples I find do not include the SPI library...What is the reason for this? :-? :-?
Here is a link to the data sheet for the 4 digit display that I am trying to link via SPI:
This display has an ATMega integrated on the backside...it seems that really I'm trying to communicate from one ATMega to another. I am a bit new to the Arduino platform, and completely new to SPI. My current goal is to have the display show a time...say 10:30 . I'm thinking I need some good examples of SPI projects, if not direct advice for using this display. Thank you for your reply.
:o
It is probably because the SPI library doesn't do very much when you look at the code in it.
This is some code I wrote for addressing two MCP23S17 chips through SPI for a CNC project to control stepping motors:-
// two MCP23S17 SPI port expander chips
setup(){
// initilise SPI expanders
// Set up ICON register it defaults to address 0xA on reset:
expanderW(MOTOR_WRITE, 0x0A, BANK | SEQOP | HAEN); // this sets both / all expanders to use address pins
expanderW(LIMIT_WRITE, 0x0A, BANK | SEQOP | HAEN); // this sets both / all expanders to use address pins
expanderW(LIMIT_WRITE,IODIRA, 0xff); // Data direction register A all inputs
expanderW(LIMIT_WRITE,IODIRB, 0xff); // Data direction register B all inputs
expanderW(LIMIT_WRITE,IPOLA, 0xff); // Input polarity read an earth (press) as a one
expanderW(LIMIT_WRITE,IPOLB, 0xff); // Input polarity read an earth (press) as a one
expanderW(LIMIT_WRITE,INTCONB, 0x00); // Notify on change
expanderW(LIMIT_WRITE,GPINTENA, 0xff); // enable notifacation on pins
expanderW(LIMIT_WRITE,GPINTENB, 0xff); // enable notifacation on pins
expanderW(MOTOR_WRITE,IODIRA, 0x00); // Data direction register A all outputs
expanderW(MOTOR_WRITE,IODIRB, 0x00); // Data direction register B all outputs
expanderW(MOTOR_WRITE, GPIOB, 0x00); // disable motors, set dir to 0, set step to 0
byte expanderR(byte com,byte add)
byte value;
digitalWrite(SS_PIN, LOW);
Spi.transfer(com); // address read
Spi.transfer(add); // register address
value = Spi.transfer(0x0); // dummy data for read
digitalWrite(SS_PIN, HIGH);
return value;
byte expanderW(byte com, byte add, byte dat) // expander read
Spi.transfer(com); // address write
Spi.transfer(dat); // register data
