SPI problems on Arduino Pro Mini
I have recently purchased a MCP41010 Digital Potentiometer that I want to control using a Arduino Pro Mini. It is controlled via the SPI protocol. To start with, I made a test script, as below:
//Test Code to find/control a digital potentiometer (MCP41010)
//Uses SPI communication
//Based on 'DigitalPotControl', the SPI library demo code
// Potentiometer connections (from chip to arduino):
// Chip Select CS(1) is connected to SS (pin 53 on Arduino mega, pin 10 on Arduino Pro mini)
// Serial Clock SCK(2) is connected to SCK (pin 52 on Arduino mega, pin 13 on Arduino Pro mini)
// Serial Input SI(3) is connected to MOSI (pin 51on Arduino mega, pin 11 on Arduino Pro mini)
// Neg Power Vss(4) is connected to GND
// Pot. A pin PA0(5) is connected to GND
// Pot. Wiper pin PW0(6) is connected to pin A1
// Pot. B pin PB0(7) is connected to 5V
// Pos Power Vdd(8) is connected to pin 3
//Include the SPI library
#include <SPI.h>
//Set the slave select pin (as in description)
const int SSpin = 10; //set to 53 for Arduino MEGA, 10 for Arduino Pro Mini
//Set the wipe input pin (as in description)
const int Wpin = 1;
//Set the power pin (as in description)
const int POWpin = 3;
//Define variables for storing current and last read voltage
float voltage = 0;
float prevoltage = 0;
//Main setup function
  //Set Power pin as output, and set it high to turn on chip
  pinMode(POWpin, OUTPUT);
  digitalWrite(POWpin, HIGH);
  //Set slave select pin as output, and set it high to de-select chip
  pinMode(SSpin, OUTPUT);
  digitalWrite(SSpin, HIGH);
  //Set wiper pin as input
  pinMode(Wpin, INPUT);
  //Initialise SPI
  SPI.begin();
  //Initialise Serial
   //Loop through 128 channel, to find the digital potentiometer:
   for (int channel=0; channel<256; channel++) {
       //Get initial voltage, and store in prevoltage
       prevoltage = (float)analogRead(Wpin)*5.0/1024.0;
       //Loop throught the resistance on this channel, from min to max
       for (int resist=0; resist<256; resist++) {
           //Set resistance
           MCP41010Write(channel,resist);
           delay(2);
           //Read input, and convert to Volts
           //If it has changed from previous voltage (by at least 0.01 Volts) display results
           if (abs(voltage-prevoltage)>0.01) {
             //Print results to serial
             Serial.print("Resistance on Channel ");
             Serial.print(channel);
             Serial.print(" set to ");
             Serial.print(resist);
             Serial.print(", reading: ");
             Serial.print(voltage);
             Serial.println("V");
           delay(2);
           //Update previous voltage
           prevoltage=voltage;
       //Print update
       Serial.print("Done testing channel ");
       Serial.println(channel);
   //Turn off Chip, and display end of test message
   Serial.println("End of Test");
   digitalWrite(POWpin, LOW);
   digitalWrite(SSpin, LOW);
void MCP41010Write(int address, int value) {
  //Take the slave select pin low, to select chip
  //Send the address, followed by the value to set
  SPI.transfer(address);
  SPI.transfer(value);
  //Take the slave select pin high, to de-select the chip
I tested this script on the Dig. Pot., using an Arduino Mega (as I had one lying around) and it worked fine, with no results until channel 17, where the returning voltage smoothly swept from 5V to 0V.
However, when I tested the script on the Dig. Pot. using a 5V Arduino Pro Mini, I got a different result. No channel gave the expected result of a smooth sweep from 5V to 0V. Instead there was just the occasional random change in the return V, with no obvious pattern.
What am I doing wrong? Why does the Arduino Pro Mini appear to be sending random data when using SPI?
After messing with it for quite a while, I realised (like a fool) I had left the usb->pro mini board at 3.3V instead of 5V, meaning that the Arduino Pro Mini was underpowered. However, after fixing that, the Arduino Pro Mini is still not behaving as expected. Now it just gets no change of V returning from the Dig. Pot at all, on any channel.
Turns out the test sketch was also working fine when I used my other Arduino Pro Mini (a 3.3V version). So the problem was related only to my 5V Arduino Pro Mini.
So I looked it over, and there it was. One of the pins had slightly less solder on it than the others, and after a quick dab of some extra solder, everything is working fine.
Yey!
Good to let us know. Good luck with the rest of the project.
