SPI reads from slave, cannot write to volatile variable on slave
I cannot get the RPMcmdin variable to update on the slave device. The SPI ISR is at the bottom. Help?
#include <Servo.h>  //BLDC operations -> 50Hz pwm generation ESC input
volatile byte command = 0;
void ss_falling (){  // start of SPI transaction, no command yet
  command = 0;
}  // end of interrupt service routine (ISR) ss_falling
//PINS
const uint8_t RPMsense = 2;  //RPM sense input pin
const uint8_t FPpin = 9;     //Fuel Pump Run pin
const uint8_t IGpin = 6;     //Glow plug / ignition pin enable / disable
const uint8_t FVpin = 8;     //Fuel Valve enable / disable
//Global Variables
volatile int RPMcmdin = 0;       //Command input from ECU, used in Start/Run functions
volatile uint8_t RUNStatus = 0; // Global volatile system run status. 0 = OFF, 1 = START, 2 = RUN, 3 = SHUTDOWN
volatile uint8_t rpm = 0;
//const uint8_t modeT2 = 0x02;
const uint8_t modeT1 = 0x02; //PWM Freq Scale 16B P
//const uint8_t modeT0 = 0x02; //PWM Freq Scale 8B P87 T2 BASE =  PS(1, 8, 64, 256, 1024)
int value = 0; // servo program value for ESC. 1000 SD, 1200 Stop, 2000 MAX
Servo StarterCON; // Brushless motor instance
  //SPI setup
  pinMode(MISO, OUTPUT);  // have to send on master in, *slave out*
  SPCR |= _BV(SPE);  // turn on SPI in slave mode
  SPCR |= _BV(SPIE);  // turn on interrupts
  attachInterrupt (0, ss_falling, FALLING);  // interrupt for SS falling edge
  //Pins
  pinMode(FPpin, OUTPUT);
  pinMode(RPMsense, INPUT_PULLUP);
  pinMode(FVpin, OUTPUT);
  pinMode(IGpin, OUTPUT);
  //PWM Change Frequency
  StarterCON.attach(5);    // Pin 5 ESC control for Brushless Motor
  //TCCR2B = TCCR2B & 0b11111000 | modeT2;//Pin 3 and 11 PWM freq
  TCCR1B = TCCR1B & 0b11111000 | modeT1;//Pin 9 and 10 PWM freq
  //TCCR0B = TCCR0B & 0b11111000 | modeT0; //Pin 5 and 6 PWM Freq
  //Starter(int); FUELvalve(int); FuelPump(int); Ignition(int)
  //StartSEQ(); ShutdownSEQ();
 GetRPM();
 Serial.println(RPMcmdin);
 delay(100);
// Rough start sequence, needs work with fuel pump and handoff to RUN function
void StartSEQ(){
  return;
void ShutdownSEQ(){
  return;
void EngineRUN(){
  return;
// RPM Sense
int GetRPM(){
  unsigned long PWH = pulseIn(RPMsense,HIGH);
  rpm = 24928/PWH; // rpm:24928570 kRPM 24928
  return(rpm);
}//END RPM Sense
//Starter Speed Control
int Starter(int STRin){
  StarterCON.write(STRin);
  Serial.println(STRin);
  return;
}//END Starter Speed Control
//Fuel Pump Control
int FuelPump(int FP){
  analogWrite(FPpin, FP);
  return;
} //END Fuel Pump Control
//Fuel Valve Control function 1 opens valve, 0 closes valve.
int FUELvalve(int pos){
  if (pos == 1){
    digitalWrite(FVpin, HIGH);
  }else{
    digitalWrite(FVpin, LOW);
  return;
}//END Fuel Valve Control
//Igniter Control function 1 on, 0 off.
int Ignition(int i){
  if (i == 1){
    analogWrite(IGpin, 35);
  }else{
    analogWrite(IGpin, 0);
  return;
}//END Igniter Control
// SPI ISR
ISR (SPI_STC_vect){
  int c = SPDR;
  switch (command){
  // no command? then this is the command
  case 0:
    command = c;
    SPDR = 0;
    RPMcmdin = 0;
  case 'a': // Get RPM value and return
    SPDR = c + rpm;  // add 15
  case 'd':
    RPMcmdin = c;
  } // end of switch
}  //END(ISR) SPI_STC_vect
The other issue that it could be is the way that I send the write request from the Master. I did the same thing that I did for reading the value, and in this case it reads back the cmd value and I print it out but for some reason it subtracts 1 and I do not know why. This is the code from the Master (Arduino MEGA):
#include  <Wire.h>
#include  <LiquidCrystal_I2C.h>
#include <SPI.h>
#include <SparkFunMAX31855k.h> // Using the max31855k driver
LiquidCrystal_I2C lcd(0x3F,16,2);  //LCD address to 0x3f for a 16 char 2 line display
int Vpin = A8;
const uint8_t TEMPSS = 24;
const uint8_t VCC = 2;       // NOT USED, Function Place Holder
const uint8_t GND = 4;       // NOT USED, Function Place Holder
volatile uint8_t cmd = 0;
//Subinitialazation Funcitons
SparkFunMAX31855k probe(TEMPSS, VCC, GND);
void setup(){
  digitalWrite(SS, HIGH);  // ECM Slave Select Pin
  digitalWrite(TEMPSS, HIGH); // TEMP Slave Select Pin
  Wire.begin();        // join i2c bus (address optional for master)
  lcd.init();          // initialize the lcd
  lcd.backlight();
  pinMode(Vpin, INPUT);
  SPI.begin ();
  SPI.setClockDivider(SPI_CLOCK_DIV8);
void loop(){
if (Serial.available()>0){
  cmd = Serial.parseInt();
  WriteDATA(cmd);
ReadDATA();
delay(200);
byte WriteDATA(byte cmdin){
  cmdin++;
  digitalWrite(SS, LOW); // enable Slave Select
  SPITransfer ('d');
  SPITransfer (cmdin);
  cmd = SPITransfer (0);
  digitalWrite(SS, HIGH);  // disable Slave Select
  Serial.println(cmd);
//Requests parameter data from the ECU. Min 20ms response time a normal I2C freq.
void ReadDATA(){
  SPITransfer ('a');  // add command
  SPITransfer (1);
  byte rpm = SPITransfer (1);
  int RS = 1;
  int egt = GetEGT();
  int Vbat = Volt();
  LCD(rpm,egt,cmd,Vbat,RS);
//SPI transfer byte
byte SPITransfer (const byte dat){
  byte a = SPI.transfer (dat);
  delayMicroseconds (20);
  return a;
} //END SPITransfer
// Read Thermocouple
int GetEGT(){
  float temperature = probe.readCJT();
  temperature = probe.readTempC();
  return (temperature);
  return;
}//END Reads Thermocouple
//Read Voltage Value
int Volt(){
  //This needs to be worked on Cell Value, implemented for testing
  int Vin = analogRead(Vpin);
  int Vout = map(Vin, 0,1023,0,100);
  return(Vout);
}//END Read Voltage Value
// Write data to LCD in fomat for 16 x 2 LCD
void LCD(int rpm, int egt, int cmd, int vlt, byte RS){
  lcd.setCursor(0,0);
  lcd.print("RPM:     CMD:   ");
  lcd.setCursor(0,1);
  lcd.print("EGT:     BAT:   ");
  lcd.setCursor(4,0);
  lcd.print(rpm);
  lcd.setCursor(13,0);
  lcd.print(cmd);
  lcd.setCursor(4,1);
  lcd.print(egt);
  lcd.setCursor(8,1);
  lcd.print(RS);
  lcd.setCursor(13,1);
  lcd.print(vlt);
}//END Write LCD
I don't see an explicit use of an SPI.beginTransaction() or an SPI.endTransaction() command on the master.
see example
6v6gt:
see example
I tried to use that example, but it stopped transmission all together. Instead I used Nick Gammon's tutorial and structured it that way and he never uses the beginTransaction or endTransaction... I got his tutorials working on a separate sketch, but when I tried to implement it on my project, only the read from (case a) works and the Write to (case d) does not save the value to my global variable. I am a complete loss and feel like I have tried every combination of send commands that google can provide.
OK. try disconnecting the max31855k from the master and commenting out all the code for it. Since it is also an SPI device, it could be the source of the interference that you have described the your OP (unwanted subtraction of 1).
In your slave code, you are not clearing the variable command, so once it has something in it, the case 0 part of your switch statement to accept another command will never execute.
