(SPI Robustness?) Problem with DIY MAX7219 Library
Hi, I would like to create my own MAX7219 LED driver library to get a better understanding and reduce the code compared to using a premade library. With existing libraries, the LED module containing of four 8x8 dot matrices works fine. But my code only works sometimes and I do not understand why it does not work all the time. Sometimes means after a reset of the Mega 2560, the LEDs turn off instead of illuminating correctly. At the moment it is working very often, but sometimes not even after many resets. I think the reason could be that the data I send sometimes gets corrupted before arriving at the MAX7219. Could I somehow improve on that? With an oscilloscope it looks like I am sending the intended bytes, however. Here is the code:
 MAX7219 dot matrix display control with Arduino.
 IMPORTANT: The LEDs will stay on until you set them off!
 IMPORTANT: To set displays in series, first pull clock to low, then send 2 bytes for the last display in series, then 2 bytes for the display before this one and so on. AFTER this pull clock high to make the changes visible!
#include "SPI.h" // The MAX7219 does not use real SPI, because there is no MISO. But we still use the hardware SPI pins of the Arduino for better performance.
int ss_pin = 53; // This is the slave select pin of the Arduino Mega 2560.
  pinMode(ss_pin, OUTPUT); // This pin is used for chip select. The datasheet tells us that if this pin gets pulled low, the data transfer starts.
  SPI.begin(); // Wakes the SPI bus up.
  SPI.setBitOrder(MSBFIRST); // As declared in the data sheet. This means if we want to send for example 10000000, it is sent starting with the 1 from the left, not the 0 at the end.
  SPI.setClockDivider(SPI_CLOCK_DIV16); // SPI uses with DIV16 for example 1/16 of the system frequency. For the Arduino Mega 2560 this means 1 MHz (one clock high per 0.001 ms).
void transmit(int address1, int data1, int address2, int data2, int address3, int data3, int address4, int data4)
 This function sends data to the MAX7219. As the datasheet states, using 1 to 8 for the address refers to the led segments and the data defines how the leds are turned on.
 If 0 is used for the address after sending a 16 bit command, that command is sent to the next MAX7219 in the chain.
 The numbering from 1 to 4 refers to the displays in series.
  digitalWrite(ss_pin, LOW); // Starts the transmission.
  SPI.transfer(address4); // Sends one byte of data, so integers from 0 to 255 can be sent here.
  SPI.transfer(data4);
  SPI.transfer(address3);
  SPI.transfer(data3);
  SPI.transfer(address2);
  SPI.transfer(data2);
  SPI.transfer(address1);
  SPI.transfer(data1);
  digitalWrite(ss_pin, HIGH); // Ends the transmission.
  delay(100);
  delay(2000);
  transmit(255,0,255,0,255,0,255,0); // By default the display is in test mode which will light all leds. With this command test mode is turned off.
  transmit(249,0,249,0,249,0,249,0); // Use no decode mode for all digits.
  transmit(251,255,251,255,251,255,251,255); // Use all digits.
  while(true){
    for (int i = 1; i <= 8; i++) {
        transmit(i,0,i,0,i,1,i,0); //digit i turns on column 1 on display 3
          delay(100);
        transmit(i,0,i,0,i,0,i,0); //digit i turns off column 1
          delay(100);
