SPI Save Device Issue
Hello,
I am working on a system that uses two devices which communicate with an Arduino Uno over SPI. One device is a CAN shield from Sparkfun and the other is an Amazon brand 2.2" lcd screen. I can make each device preform properly independently however when I try to have both running the screen stops updating.
My assumption is it is something to do with using the same CS pin (pin 10) for both devices and the libraries are fighting with each other.
If anyone could provide some insight into possibly editing the libraries or any other potential solutions I'd appreciate it.
CAN Shield
LCD Screen
Code with libraries attached below.
Your topic was MOVED to its current forum category which is more appropriate than the original as it has nothing to do with Installation and Troubleshooting of the IDE
CS stands for Chip Select so how would the sketch which device it is communicating with ?
Why have to used the same pin for both ?
It appears hidden here. Please use code tags and forum technics for posting code.
EDIT: Referring to sales sites is not the best. Links to datasheet is much better.
CS\ may be your problem. It depends if they are active high or active low. If both are the same it will not work. I have this work with some SD card readers, the card reader was high while the the CS other device was low.
Help us help you by posting an annotated schematic, not a frizzy picture with links to "Technical" information on the hardware devices.
Apparently I'm too new a user to post attachments so sorry for the long post.
// Motion control and general testing of multiple motors
// This is the main sourcecode to test CANbus control of the MyActuator RMD-X series with V???? firmware
// Uses Arduino Mega with the Sparkfun CAN-BUS shield
// National Geographic Photo Engineering
// Matt Norman
// May 20, 2022
#include <SPI.h>
#include <mcp_can.h>
#include "Ucglib.h"
// SAMD core //
#ifdef ARDUINO_SAMD_VARIANT_COMPLIANCE
#define SERIAL SerialUSB
#else
#endif
//# defines and constants //
#define LED2 8
#define LED3 7
#define CONTROL_PERIOD 10  // in MS
#define DIAL_PERIOD 250
#define NOISE_TOLERANCE 5
#define MAX_ACCELERATION 10000  // Max acceleration parameter 1 dps/LSB 0 - 10,000
#define MAX_SPEED 1000000       // Max speed parameter 1 dps/LSB -/+ 32767
#define MAX_DAMPING 32767       // Max acceleration parameter 1 dps/LSB 0 - 10,000
#define MAX_TORQUE 10000
#define T 4000
#define DLY() delay(2000)
unsigned long controlTimer = 0;
unsigned long currentTime = 0;
const int panPin = A0;
const int tiltPin = A1;
const int accPin = A3;
const int dampingPin = A2;
// cs pin = 10 for Uno = 53 for Mega //
const int SPI_CS_PIN = 10;
MCP_CAN CAN(SPI_CS_PIN);  // Set CS pin //
Ucglib_ILI9341_18x240x320_SWSPI ucg(/*sclk=*/13, /*data=*/11, /*cd=*/9, /*cs=*/10, /*reset=*/8);
// func prototypes //
double mapVal(double, double, double, double, double);
int sendReceiveBuffer(uint16_t, unsigned char*, unsigned char*);
uint8_t checkInput();
uint8_t samplePin(uint8_t, int32_t*);
int32_t checkSoftStop(uint16_t, int8_t, int32_t, int32_t);
int32_t readPosition(uint16_t);
int32_t readAcceleration(uint16_t);
int32_t homeMotor(uint16_t);
int32_t initalizeMotor(uint16_t);
void brakeOffMotor(uint16_t);
void printBuffer(unsigned char*);
void readErrorState(uint16_t);
void readFirmwareVersion(uint16_t);
void resetMotor(uint16_t);
void runMotor(uint16_t);
void setSpeed(uint16_t, uint32_t);
void setAcceleration(uint16_t, uint32_t);
void spdCommand(uint16_t, uint32_t);
void stopMotor(uint16_t);
void zeroMotor(uint16_t);
// global variables //
unsigned char len = 0;
unsigned char buf[8];
uint8_t reductionRatio = 36;  //gear box reduction 1:36 for RMD X6
uint8_t z = 127;              // start value
uint16_t msgID = 0x140;       //140+ID
uint32_t spdTilt = 5000;      // speed, motor reduces by 0.01 dps/LSB or 0.1 dps/LSB depending on command
uint32_t spdPan = 5000;       // speed, motor reduces by 0.01 dps/LSB or 0.1 dps/LSB depending on command
uint32_t lcg_rnd();
int32_t panLock = 135;            //Pan Axis movment stops in deg
int32_t tiltLock = 90;            //Tilt Axis movment stops in deg
int32_t angControl = 9000;        //angle, motor reduces by 0.01 deg/LSB
int32_t currentPosTilt = 0;       //current position of motor
int32_t currentPosPan = 0;        //current position of motor
int32_t newPosTilt = 0;           //next position of motor
int32_t newPosPan = 0;            //next position of motor
int32_t currentAcceleration = 0;  //current acceleration of motor
int32_t currentDamping = 0;       //current damping of motor
int32_t tiltIn = 0;
int32_t panIn = 0;
int32_t homePan = 0;
int32_t homeTilt = 0;
double damping = 10000;  // Movment damping
// runs once //
  SERIAL.begin(115200);
  // ucg.begin(UCG_FONT_MODE_TRANSPARENT);
  // ucg.setFont(ucg_font_ncenR14_hr);
  // ucg.clearScreen();
  while (CAN_OK != CAN.begin(CAN_1000KBPS))  // init can bus : baudrate = 1000k
    SERIAL.println("CAN BUS Shield init fail");
    SERIAL.println(" Init CAN BUS Shield again");
    delay(250);
  SERIAL.println("CAN BUS Shield init ok!");
  //Write LED pins low to turn them off by default
  digitalWrite(LED2, LOW);
  digitalWrite(LED3, LOW);
  //Motor startup sequeance
  SERIAL.println("Run Motor Startup");
  homePan = initalizeMotor(0X141);
  homeTilt = initalizeMotor(0X142);
  checkInput();
uint8_t r = 0;
// runs continuous //
  currentTime = millis();
  if (checkInput()) {
    if (samplePin(dampingPin, &currentDamping)) {
      damping = mapVal(currentDamping, 0, 1023, 0, 100) / 100;
    if (samplePin(accPin, &currentAcceleration)) {
      setAcceleration(0x141, mapVal(currentAcceleration, 0, 1023, 0, MAX_ACCELERATION));
      setAcceleration(0x142, mapVal(currentAcceleration, 0, 1023, 0, MAX_ACCELERATION));
    // SERIAL.print("Pan Axis Status");
    // SERIAL.println(checkSoftStop(0x141, 90, homePan));
    // SERIAL.println(readPosition(0x141));
    // SERIAL.print("Current Speed: ");
    // SERIAL.print(mapVal(panIn, 0, 1023, -MAX_SPEED, MAX_SPEED));
    // SERIAL.print(" | Damping Setting: ");
    // SERIAL.print(damping);
    // SERIAL.print(" | Acc Setting: ");
    // SERIAL.print(mapVal(currentAcceleration, 0, 1023, 0, MAX_ACCELERATION));
    // SERIAL.print(" | Acc Reading: ");
    // SERIAL.println(readAcceleration(0x141));
  if (currentTime - controlTimer >= CONTROL_PERIOD) {
    controlTimer = currentTime;
    setSpeed(0x141, damping * checkSoftStop(0x141, panPin, panLock, homePan));
    setSpeed(0x142, damping * checkSoftStop(0x142, tiltPin, tiltLock, homeTilt));
    // readErrorState( 0x142);
  // switch (r & 3) {
  //   case 0: ucg.undoRotate(); break;
  //   case 1: ucg.setRotate90(); break;
  //   case 2: ucg.setRotate180(); break;
  //   default: ucg.setRotate270(); break;
  // if (r > 3) {
  //   set_clip_range();
  // r++;
  // ucglib_graphics_test();
  // // cross();
  // pixel_and_lines();
  // color_test();
  // triangle();
  // fonts();
  // text();
  // if (r <= 3)
  //   clip();
  // box();
  // gradient();
  // //ucg.clearScreen();
  // DLY();
  // ucg.setMaxClipRange();
// Functions //
uint8_t checkInput() {
  uint8_t pinState = 0;
  pinState |= samplePin(panPin, &panIn);
  pinState |= samplePin(tiltPin, &tiltIn);
  return pinState;
uint8_t samplePin(uint8_t pin, int32_t* oldSample) {
  // grab new sample
  int32_t newSample = analogRead(pin);
  // check if new sample is above noise threshold
  if (abs(newSample - *oldSample) > NOISE_TOLERANCE) {
    // update oldSample
    *oldSample = newSample;
    return 1;
  return 0;
double mapVal(double valIn, double oldMin, double oldMax, double newMin, double newMax) {
  double oldRange = oldMax - oldMin;
  double newRange = newMax - newMin;
  double valOut = 0.0;
  valOut = (((valIn - oldMin) * newRange) / oldRange) + newMin;
  if (valIn >= 500.0 && valIn <= 550.0) {
    valOut = 0.0;
  if (valOut > newMax) {
    valOut = newMax;
  if (valOut < newMin) {
    valOut = newMin;
  return valOut;
int32_t initalizeMotor(uint16_t canID) {
  int32_t home = 0;
  runMotor(canID);
  delay(100);
  zeroMotor(canID);
  delay(100);
  brakeOffMotor(canID);
  delay(100);
  resetMotor(canID);
  delay(2500);
  setAcceleration(canID, MAX_ACCELERATION);
  delay(100);
  home = homeMotor(canID);
  return home;
int sendReceiveBuffer(uint16_t canId, unsigned char* buf_in, unsigned char* buf_out) {
  int success_flag = 0;  //Set success flag to zero
  int try_index = 5;     //Attempt send receive buffer 5 times
  buf_out[0] = 0x88;
  buf_out[1] = 0x00;
  buf_out[2] = 0x00;
  buf_out[3] = 0x00;
  buf_out[4] = 0x00;
  buf_out[5] = 0x00;
  buf_out[6] = 0x00;
  buf_out[7] = 0x00;
  if (buf_in[0] == 0x76)  //excepion as 0x76 does not recieve a return
    success_flag = 1;
    buf_out[0] = 0x76;
    return (success_flag);
  while ((buf_out[0] == 0x88) && (try_index--)) {
    CAN.sendMsgBuf(canId, 0, 8, buf_in);
    delay(10);
    if (CAN_MSGAVAIL == CAN.checkReceive())  // check if data coming
      CAN.readMsgBuf(&len, buf_out);  // read data,  len: data length, buf: data buf
      unsigned long canId = CAN.getCanId();
      if (buf_out[0] != 0x88) {
        success_flag = 1;
  return (success_flag);  //Return a zero if message not received
void printBuffer(unsigned char* buf) {
  SERIAL.print(buf[0], HEX);
  SERIAL.print("\t");
  SERIAL.print(buf[1], HEX);
  SERIAL.print("\t");
  SERIAL.print(buf[2], HEX);
  SERIAL.print("\t");
  SERIAL.print(buf[3], HEX);
  SERIAL.print("\t");
  SERIAL.print(buf[4], HEX);
  SERIAL.print("\t");
  SERIAL.print(buf[5], HEX);
  SERIAL.print("\t");
  SERIAL.print(buf[6], HEX);
  SERIAL.print("\t");
  SERIAL.println(buf[7], HEX);
void readFirmwareVersion(uint16_t canID) {
  unsigned char buf_in[8];
  unsigned char buf_out[8];
  //Read Firmware Version
  buf_in[0] = 0xB2;
  buf_in[1] = 0x00;
  buf_in[2] = 0x00;
  buf_in[3] = 0x00;
  buf_in[4] = 0x00;
  buf_in[5] = 0x00;
  buf_in[6] = 0x00;
  buf_in[7] = 0x00;
  sendReceiveBuffer(canID, buf_in, buf_out);
void runMotor(uint16_t canID) {
  //Motor ruunning command, legacy from v2.0??
  buf_in[0] = 0x88;
  buf_in[1] = 0x00;
  buf_in[2] = 0x00;
  buf_in[3] = 0x00;
  buf_in[4] = 0x00;
  buf_in[5] = 0x00;
  buf_in[6] = 0x00;
  buf_in[7] = 0x00;
void brakeOffMotor(uint16_t canID) {
  //Brake Off Command
  buf_in[0] = 0x77;
  buf_in[1] = 0x00;
  buf_in[2] = 0x00;
  buf_in[3] = 0x00;
  buf_in[4] = 0x00;
  buf_in[5] = 0x00;
  buf_in[6] = 0x00;
  buf_in[7] = 0x00;
void brakeOnMotor(uint16_t canID) {
  //Brake Off Command
  buf_in[0] = 0x78;
  buf_in[1] = 0x00;
  buf_in[2] = 0x00;
  buf_in[3] = 0x00;
  buf_in[4] = 0x00;
  buf_in[5] = 0x00;
  buf_in[6] = 0x00;
  buf_in[7] = 0x00;
void zeroMotor(uint16_t canID) {
  // set current position as zero
  buf_in[0] = 0x64;
  buf_in[1] = 0x00;
  buf_in[2] = 0x00;
  buf_in[3] = 0x00;
  buf_in[4] = 0x00;
  buf_in[5] = 0x00;
  buf_in[6] = 0x00;
  buf_in[7] = 0x00;
int32_t homeMotor(uint16_t canID) {
  int32_t tempHome[4];
  // motor homing sequence
  setPosition(canID, 180);
  tempHome[0] = readPosition(canID);
  setPosition(canID, 185);
  tempHome[1] = readPosition(canID);
  setPosition(canID, 175);
  tempHome[2] = readPosition(canID);
  tempHome[3] = (tempHome[0] + tempHome[1] + tempHome[2]) / 3;
  SERIAL.print("Home Complete ");
  SERIAL.println(canID, HEX);
  return tempHome[3];
void resetMotor(uint16_t canID) {
  // motor reset, necassary for zero position write to take effect
  buf_in[0] = 0x76;
  buf_in[1] = 0x00;
  buf_in[2] = 0x00;
  buf_in[3] = 0x00;
  buf_in[4] = 0x00;
  buf_in[5] = 0x00;
  buf_in[6] = 0x00;
  buf_in[7] = 0x00;
void setPosition(uint16_t canID, uint32_t pos) {
  pos = pos * 100 * reductionRatio;
  //Send incremental position
  buf_in[0] = 0xA4;
  buf_in[1] = 0x00;
  buf_in[2] = MAX_SPEED;
  buf_in[3] = MAX_SPEED >> 8;
  buf_in[4] = pos;
  buf_in[5] = pos >> 8;
  buf_in[6] = pos >> 16;
  buf_in[7] = pos >> 24;
  delay(750);
void setSpeed(uint16_t canID, uint32_t spd) {
  if (spd == 0) {
    stopMotor(canID);
  //Send incremental speed
  buf_in[0] = 0xA2;
  buf_in[1] = 0x00;
  buf_in[2] = 0x00;
  buf_in[3] = 0x00;
  buf_in[4] = spd;
  buf_in[5] = spd >> 8;
  buf_in[6] = spd >> 16;
  buf_in[7] = spd >> 24;
void setAcceleration(uint16_t canID, uint32_t acc) {
  //Send incremental acceleration
  buf_in[0] = 0x43;
  buf_in[1] = 0x00;
  buf_in[2] = 0x00;
  buf_in[3] = 0x00;
  buf_in[4] = acc;
  buf_in[5] = acc >> 8;
  buf_in[6] = acc >> 16;
  buf_in[7] = acc >> 24;
void stopMotor(uint16_t canID) {
  //stop motor movment
  buf_in[0] = 0x81;
  buf_in[1] = 0x00;
  buf_in[2] = 0x00;
  buf_in[3] = 0x00;
  buf_in[4] = 0x00;
  buf_in[5] = 0x00;
  buf_in[6] = 0x00;
  buf_in[7] = 0x00;
void readMode(uint16_t canID) {
  buf_in[0] = 0x70;
  buf_in[1] = 0x00;
  buf_in[2] = 0x00;
  buf_in[3] = 0x00;
  buf_in[4] = 0x00;
  buf_in[5] = 0x00;
  buf_in[6] = 0x00;
  buf_in[7] = 0x00;
int32_t checkSoftStop(uint16_t canID, int8_t pin, int32_t stop, int32_t homePosition) {
  int32_t currentPosition = readPosition(canID);  // in 1deg/lsb
  int32_t negStop = homePosition - stop;
  int32_t posStop = homePosition + stop;
  int32_t speed = 0;
  if (currentPosition <= negStop) {
    // setSpeed(canID, 0);
    setPosition(canID, (negStop + 1));
    speed = 0;
  } else if (currentPosition >= posStop) {
    setPosition(canID, (posStop - 1));
    speed = 0;
    speed = mapVal(analogRead(pin), 0, 1023, -MAX_SPEED, MAX_SPEED);
  return speed;
int32_t readPosition(uint16_t canID) {
  int32_t pos = 0;
  //read current position
  buf_in[0] = 0x92;
  buf_in[1] = 0x00;
  buf_in[2] = 0x00;
  buf_in[3] = 0x00;
  buf_in[4] = 0x00;
  buf_in[5] = 0x00;
  buf_in[6] = 0x00;
  buf_in[7] = 0x00;
  pos = ((uint32_t)buf_out[7] << 24) | ((uint32_t)buf_out[6] << 16) | ((uint32_t)buf_out[5] << 8) | ((uint32_t)buf_out[4]);
  pos = pos / 100 / reductionRatio;
  // pos = ((uint32_t)buf_out[7] << 8) | ((uint32_t)buf_out[6]);
  return pos;
int32_t readAcceleration(uint16_t canID) {
  int32_t acc = 0;
  buf_in[0] = 0x42;
  buf_in[1] = 0x00;
  buf_in[2] = 0x00;
  buf_in[3] = 0x00;
  buf_in[4] = 0x00;
  buf_in[5] = 0x00;
  buf_in[6] = 0x00;
  buf_in[7] = 0x00;
  acc = ((uint32_t)buf_out[7] << 24) | ((uint32_t)buf_out[6] << 16) | ((uint32_t)buf_out[5] << 8) | ((uint32_t)buf_out[4]);
  return acc;
void readErrorState(uint16_t canID) {
  int8_t temp = 0;
  int8_t brake = 0;
  int16_t voltage = 0;
  int16_t errStat = 0;
  int16_t torqueCurrent = 0;
  int16_t motorSpeed = 0;
  int16_t outputAngle = 0;
  //read error frame one
  buf_in[0] = 0x9A;
  buf_in[1] = 0x00;
  buf_in[2] = 0x00;
  buf_in[3] = 0x00;
  buf_in[4] = 0x00;
  buf_in[5] = 0x00;
  buf_in[6] = 0x00;
  buf_in[7] = 0x00;
  temp = buf_out[1];
  brake = buf_out[3];
  voltage = (((uint16_t)buf_out[5] << 8) | ((uint16_t)buf_out[4]));
  errStat = (((uint16_t)buf_out[7] << 8) | ((uint16_t)buf_out[6]));
  //read error frame two
  buf_in[0] = 0x9C;
  buf_in[1] = 0x00;
  buf_in[2] = 0x00;
  buf_in[3] = 0x00;
  buf_in[4] = 0x00;
  buf_in[5] = 0x00;
  buf_in[6] = 0x00;
  buf_in[7] = 0x00;
  torqueCurrent = (((uint16_t)buf_out[3] << 8) | ((uint16_t)buf_out[2]));
  motorSpeed = (((uint16_t)buf_out[5] << 8) | ((uint16_t)buf_out[4]));
  outputAngle = (((uint16_t)buf_out[7] << 8) | ((uint16_t)buf_out[6]));
  SERIAL.println("");
  SERIAL.print("Motor Temp: ");
  SERIAL.println(temp);
  SERIAL.print("Brake State: ");
  SERIAL.println(brake);
  SERIAL.print("Voltage: ");
  SERIAL.println(voltage);
  SERIAL.print("Error State: ");
  SERIAL.println(errStat);
  SERIAL.print("Torque Current: ");
  SERIAL.println(torqueCurrent);
  SERIAL.print("Motor Speed: ");
  SERIAL.println(motorSpeed);
  SERIAL.print("Output Angle: ");
  SERIAL.println(outputAngle);
uint32_t lcg_rnd(void) {
  z = (uint8_t)((uint16_t)65 * (uint16_t)z + (uint16_t)17);
  return (uint32_t)z;
void ucglib_graphics_test(void) {
  //ucg.setMaxClipRange();
  ucg.setColor(0, 0, 40, 80);
  ucg.setColor(1, 80, 0, 40);
  ucg.setColor(2, 255, 0, 255);
  ucg.setColor(3, 0, 255, 255);
  ucg.drawGradientBox(0, 0, ucg.getWidth(), ucg.getHeight());
  ucg.setColor(255, 168, 0);
  ucg.setPrintDir(0);
  ucg.setPrintPos(2, 18);
  ucg.print("Ucglib");
  ucg.setPrintPos(2, 18 + 20);
  ucg.print("GraphicsTest");
  DLY();
void gradient(void) {
  ucg.setColor(0, 0, 255, 0);
  ucg.setColor(1, 255, 0, 0);
  ucg.setColor(255, 255, 255);
  ucg.setPrintDir(0);
  ucg.print("GradientBox");
  ucg.drawBox(2, 25, 8, 8);
  ucg.setColor(0, 255, 0, 0);
  ucg.drawBox(2 + 10, 25, 8, 8);
  ucg.setColor(0, 255, 0, 255);
  ucg.drawBox(2, 25 + 10, 8, 8);
  ucg.setColor(0, 0, 255, 255);
  ucg.drawBox(2 + 10, 25 + 10, 8, 8);
  DLY();
void box(void) {
  ucg_int_t x, y, w, h;
  unsigned long m;
  ucg.setColor(1, 60, 0, 40);
  ucg.setColor(2, 128, 0, 140);
  ucg.setColor(3, 0, 128, 140);
  ucg.setPrintDir(0);
  ucg.print("Box");
  m = millis() + T;
  while (millis() < m) {
    ucg.setColor((lcg_rnd() & 127) + 127, (lcg_rnd() & 127) + 64, lcg_rnd() & 31);
    w = lcg_rnd() & 31;
    h = lcg_rnd() & 31;
    w += 10;
    h += 10;
    x = (lcg_rnd() * (ucg.getWidth() - w)) >> 8;
    y = (lcg_rnd() * (ucg.getHeight() - h - 20)) >> 8;
    ucg.drawBox(x, y + 20, w, h);
void pixel_and_lines(void) {
  ucg_int_t mx;
  ucg_int_t x, xx;
  mx = ucg.getWidth() / 2;
  //my = ucg.getHeight() / 2;
  ucg.setColor(0, 0, 0, 150);
  ucg.setColor(1, 0, 60, 40);
  ucg.setColor(2, 60, 0, 40);
  ucg.setColor(3, 120, 120, 200);
  ucg.setPrintDir(0);
  ucg.print("Pix&Line");
  ucg.drawPixel(0, 0);
  ucg.drawPixel(1, 0);
  //ucg.drawPixel(ucg.getWidth()-1, 0);
  //ucg.drawPixel(0, ucg.getHeight()-1);
  ucg.drawPixel(ucg.getWidth() - 1, ucg.getHeight() - 1);
  ucg.drawPixel(ucg.getWidth() - 1 - 1, ucg.getHeight() - 1);
  for (x = 0; x < mx; x++) {
    xx = (((uint16_t)x) * 255) / mx;
    ucg.setColor(255, 255 - xx / 2, 255 - xx);
    ucg.drawPixel(x, 24);
    ucg.drawVLine(x + 7, 26, 13);
  DLY();
void color_test(void) {
  ucg_int_t mx;
  uint16_t c, x;
  ucg.setColor(0, 0, 0, 0);
  ucg.drawBox(0, 0, ucg.getWidth(), ucg.getHeight());
  ucg.setPrintDir(0);
  ucg.print("Color Test");
  ucg.setColor(0, 127, 127, 127);
  ucg.drawBox(0, 20, 16 * 4 + 4, 5 * 8 + 4);
  for (c = 0, x = 2; c <= 255; c += 17, x += 4) {
    ucg.setColor(0, c, c, c);
    ucg.drawBox(x, 22, 4, 8);
    ucg.setColor(0, c, 0, 0);
    ucg.drawBox(x, 22 + 8, 4, 8);
    ucg.setColor(0, 0, c, 0);
    ucg.drawBox(x, 22 + 2 * 8, 4, 8);
    ucg.setColor(0, 0, 0, c);
    ucg.drawBox(x, 22 + 3 * 8, 4, 8);
    ucg.setColor(0, c, 255 - c, 0);
    ucg.drawBox(x, 22 + 4 * 8, 4, 8);
  DLY();
void cross(void) {
  ucg_int_t mx, my;
  ucg.setColor(0, 250, 0, 0);
  ucg.setColor(1, 255, 255, 30);
  ucg.setColor(2, 220, 235, 10);
  ucg.setColor(3, 205, 0, 30);
  ucg.setColor(0, 255, 255, 255);
  ucg.print("Cross");
  ucg.setColor(0, 0, 0x66, 0xcc);
  ucg.setPrintPos(mx + 15, my - 5);
  ucg.print("dir0");
  ucg.setPrintPos(mx + 5, my + 26);
  ucg.print("dir1");
  ucg.setPrintPos(mx - 40, my + 20);
  ucg.print("dir2");
  ucg.setPrintPos(mx + 5, my - 25);
  ucg.print("dir3");
  ucg.setColor(0, 0, 0x66, 0xff);
  ucg.setColor(1, 0, 0x66, 0xcc);
  ucg.setColor(2, 0, 0, 0x99);
  ucg_Draw90Line(ucg.getUcg(), mx + 2, my - 1, 20, 0, 0);
  ucg_Draw90Line(ucg.getUcg(), mx + 2, my, 20, 0, 1);
  ucg_Draw90Line(ucg.getUcg(), mx + 2, my + 1, 20, 0, 2);
  ucg_Draw90Line(ucg.getUcg(), mx + 1, my + 2, 20, 1, 0);
  ucg_Draw90Line(ucg.getUcg(), mx, my + 2, 20, 1, 1);
  ucg_Draw90Line(ucg.getUcg(), mx - 1, my + 2, 20, 1, 2);
  ucg_Draw90Line(ucg.getUcg(), mx - 2, my + 1, 20, 2, 0);
  ucg_Draw90Line(ucg.getUcg(), mx - 2, my, 20, 2, 1);
  ucg_Draw90Line(ucg.getUcg(), mx - 2, my - 1, 20, 2, 2);
  ucg_Draw90Line(ucg.getUcg(), mx - 1, my - 2, 20, 3, 0);
  ucg_Draw90Line(ucg.getUcg(), mx, my - 2, 20, 3, 1);
  ucg_Draw90Line(ucg.getUcg(), mx + 1, my - 2, 20, 3, 2);
  DLY();
void triangle(void) {
  unsigned long m;
  ucg.setColor(0, 0, 80, 20);
  ucg.setColor(1, 60, 80, 20);
  ucg.setColor(2, 60, 120, 0);
  ucg.setColor(3, 0, 140, 30);
  ucg.print("Triangle");
  m = millis() + T;
    ucg.setColor((lcg_rnd() & 127) + 127, lcg_rnd() & 31, (lcg_rnd() & 127) + 64);
    ucg.drawTriangle(
      (lcg_rnd() * (ucg.getWidth())) >> 8,
      ((lcg_rnd() * (ucg.getHeight() - 20)) >> 8) + 20,
      ((lcg_rnd() * (ucg.getHeight() - 20)) >> 8) + 20);
void text(void) {
  ucg_int_t x, y, w, h, i;
  unsigned long m;
  ucg.setColor(0, 80, 40, 0);
  ucg.setColor(2, 20, 0, 20);
  ucg.setColor(3, 60, 0, 0);
  ucg.setPrintDir(0);
  ucg.print("Text");
  m = millis() + T;
  i = 0;
    ucg.setColor(lcg_rnd() & 31, (lcg_rnd() & 127) + 127, (lcg_rnd() & 127) + 64);
    w = 40;
    h = 22;
    y = (lcg_rnd() * (ucg.getHeight() - h)) >> 8;
    ucg.setPrintPos(x, y + h);
    ucg.setPrintDir((i >> 2) & 3);
    i++;
  ucg.setPrintDir(0);
void fonts(void) {
  ucg_int_t d = 5;
  ucg.setColor(1, 150, 0, 200);
  ucg.setColor(3, 0, 160, 160);
  ucg.setPrintDir(0);
  ucg.print("Fonts");
  ucg.setFontMode(UCG_FONT_MODE_TRANSPARENT);
  ucg.setColor(255, 200, 170);
  ucg.setFont(ucg_font_helvB08_hr);
  ucg.setPrintPos(2, 30 + d);
  ucg.print("ABC abc 123");
  ucg.setFont(ucg_font_helvB10_hr);
  ucg.setPrintPos(2, 45 + d);
  ucg.setFont(ucg_font_helvB12_hr);
  //ucg.setPrintPos(2,62+d);
  //ucg.print("ABC abc 123");
  ucg.drawString(2, 62 + d, 0, "ABC abc 123");  // test drawString
  ucg.setFontMode(UCG_FONT_MODE_SOLID);
  ucg.setColor(1, 0, 100, 120);  // background color in solid mode
  ucg.setPrintPos(2, 75 + 30 + d);
  ucg.setPrintPos(2, 75 + 45 + d);
  ucg.setPrintPos(2, 75 + 62 + d);
  /* big fonts removed, some trouble with the Arduino IDE */
  ucg.setFont(ucg_font_helvB14_hr);
  ucg.setPrintPos(2,79+d);
  ucg.setFont(ucg_font_helvB18_hr);
  ucg.setPrintPos(2,79+22+d);
  DLY();
void clip(void) {
  ucg.setColor(0, 0x00, 0xd1, 0x5e);  // dark green
  ucg.setColor(1, 0xff, 0xf7, 0x61);  // yellow
  ucg.setColor(2, 0xd1, 0xc7, 0x00);  // dark yellow
  ucg.setColor(3, 0x61, 0xff, 0xa8);  // green
  ucg.setPrintDir(0);
  ucg.print("ClipRange");
  ucg.setColor(0xd1, 0x00, 0x073);
  ucg.setPrintPos(25, 45);
  ucg.setPrintDir(0);
  ucg.print("Ucg");
  ucg.setPrintDir(1);
  ucg.print("Ucg");
  ucg.setPrintDir(2);
  ucg.print("Ucg");
  ucg.setPrintDir(3);
  ucg.print("Ucg");
  ucg.setColor(0xff, 0xff, 0xff);
  ucg.drawFrame(20 - 1, 30 - 1, 15 + 2, 20 + 2);
  ucg.setClipRange(20, 30, 15, 20);
  ucg.setColor(0xff, 0x61, 0x0b8);
  ucg.setPrintDir(0);
  ucg.print("Ucg");
  ucg.setPrintDir(1);
  ucg.print("Ucg");
  ucg.setPrintDir(2);
  ucg.print("Ucg");
  ucg.setPrintDir(3);
  ucg.print("Ucg");
  ucg.drawFrame(60 - 1, 35 - 1, 25 + 2, 18 + 2);
  ucg.setClipRange(60, 35, 25, 18);
  ucg.setPrintDir(0);
  ucg.print("Ucg");
  ucg.setPrintDir(1);
  ucg.print("Ucg");
  ucg.setPrintDir(2);
  ucg.print("Ucg");
  ucg.setPrintDir(3);
  ucg.print("Ucg");
  ucg.drawFrame(7 - 1, 58 - 1, 90 + 2, 4 + 2);
  ucg.setClipRange(7, 58, 90, 4);
  ucg.setPrintDir(0);
  ucg.print("Ucg");
  ucg.setPrintDir(1);
  ucg.print("Ucg");
  ucg.setPrintDir(2);
  ucg.print("Ucg");
  ucg.setPrintDir(3);
  ucg.print("Ucg");
  DLY();
void set_clip_range(void) {
  w = lcg_rnd() & 31;
  h = lcg_rnd() & 31;
  w += 25;
  h += 25;
  ucg.setClipRange(x, y, w, h);
// END FILE
Ucglib library
MCP_CAN Library
I can use example sketches from the Ucglib library without issues and I can run my main code without issue. However when I insert body from an example sketch into my main in runs until the below block then the screen goes grey
    delay(250);
My guess is the libraries aren't setup to play well together but I could easily be totally out of pocket here.
You need trust level 1, you can get there by:
  • Entering at least 5 topics
  • Reading at least 30 posts
  • Spend a total of 10 minutes reading posts
Users at trust level 1 can…
  • Use all core Discourse functions; all new user restrictions are removed
  • Send PMs
  • Upload images and attachments
