I am using a breadboard ATMEGA328p with a set of shift registers controlling three 3x3 rgb led matrices (formed into a cube). I have one shift register hooked up with the first two columns and two common cathode rows on one matrix, thereby controlling the bottom 4 LEDs in a square. As suggested here, I put a .1 uF capacitor in series with the Latch line. The setup can be controlled with a 9V battery or the Arduino.
Here’s my problem: With the Latch line connected, sometimes the display doesn’t start at all! Sometimes, it will work, but out of tempo. Sometimes, it skips frames. Sometimes it makes up sequences I didn’t code! When I switch from 9v to Arduino +5v, the above happens much less frequently.
So I disconnected Latch, and it starts making horrible, but extremely brief flashing in LEDs that shouldn’t turn on. This still happens even with Arduino power. It works for about ~5 seconds, then starts getting out of sync and starts making up frames. If I reconnect Latch during the sketch, the flashing goes away, but then the sketch loses sync. It doesn’t lose sync without Latch with Arduino, but with Latch, it starts to lag again.
Reset returns the sketch to sync at the beginning.
Here is my code:
// RGB LED Cube Sketch
// Uses an ATMEGA328 to control a 3x3x3 cube of RGB LEDs with
// five 595 shift registers (8 bit).
//CURRENTLY USING ONLY ONE REGISTER!
// SPI code examples from http://www.gammon.com.au/forum/?id=11518
// and http://www.gammon.com.au/spi
// Shift register wiring and other example code can be found
// at http://www.arduino.cc/en/tutorial/ShiftOut
#include <SPI.h>
const byte LATCH = 9; // Edit to change Latch pin on Arduino
const byte maxSize = 16; // Edit this to change size of Array (Counting 0 --> (2^x)-1). Try to make divisible by numOfReg.
byte dataArray[maxSize]; // If you are using an absurdly large array (i.e. >256 bytes) then change to int
byte data; // If you are using an absurdly large array (i.e. >256 bytes) then change to int
const byte numOfReg = 1; //Edit to change # of registers
byte j = 0; // Start at byte 0
SPI.setClockDivider(SPI_CLOCK_DIV128);
pinMode(13, OUTPUT);
digitalWrite(13, HIGH);
delay(20);
digitalWrite(14, LOW);
SPI.begin ();
digitalWrite(LATCH, HIGH);
delay(100);
digitalWrite(LATCH, LOW);
Serial.begin(1200);
// DEFINE EACH BYTE OF THE ARRAY IN HEX HERE!
// For example, if maxSize = 8, then define dataArray[0] through [7]
// Each item here adds about 6 bytes to the program size. (Out of 32K)
// Each frame is (# of SR's) backwards.
// This example turns each LED blue, red, green, then white!
dataArray[0]=0x09;
dataArray[1]=0x0A;
dataArray[2]=0x0C;
dataArray[3]=0x0F; // End of LED #6
dataArray[4]=0x18;
dataArray[5]=0x28;
dataArray[6]=0x48;
dataArray[7]=0x78; // End of LED #5
dataArray[8]=0x81;
dataArray[9]=0x82;
dataArray[10]=0x84;
dataArray[11]=0x87; // End of LED #9
dataArray[12]=0x90;
dataArray[13]=0xA0;
dataArray[14]=0xC0;
dataArray[15]=0xF0; // End of LED #8
// Continue to define each unit of the array
// HERE WE TRANSFER EACH BYTE OF DATA!
// For example, if sending bytes 0x13, 0xde, 0x4a:
// 0x13 xx xx
// 0xde 0x13 xx
// 0x4a 0xde 0x13
for (int i = 0; i < numOfReg; i++) {
data = dataArray[j];
SPI.transfer(data);
delay(10);
j++; // This is j, not i!
// In a nutshell: Write each byte j sequentially (so it ends up backwards) in groups of numOfReg, then LATCH, then REPEAT.
if (j == maxSize) {
j = 0; // Loops back to the beginning. You can change to create an 'intro' then a main 'loop'.
What could be wrong?
