SPI Slave Receive More than One Byte
Hi, I have setup a Arduino Mkr Zero as an SPI slave with an Arduino NANO as a SPI Master. I've got this code to work from Arduino NANO to Arduino NANO. However, I can't get it to work from Arduino NANO to Arudino Mkr Zero. The way it works is by typing a two byte number into the serial monitor (Arduino Master Side) and then sending it over SPI and displayed on the slave serial monitor. I have managed to send 0xFF to the Mkr Zero constantly (SPI.transfer(0xFF)), however if you want to use the Serial monitor it does not work.
Here is the Arduino Nano Master code;
#include<SPI.h>
unsigned short  x;
  SPI.begin();
  SPI.setClockDivider(SPI_CLOCK_DIV64); //bit rate = 16 MHz/128 = 125 kbit/sec
  digitalWrite(SS, HIGH);   //Slave is selected
  pinMode(7, OUTPUT);
  digitalWrite(7, HIGH);
  Serial.println("Frequency?");
  while(!Serial.available() >0){}
  x = Serial.parseInt();
  if (x > 0){
    digitalWrite(7, LOW);
    digitalWrite(SS, LOW);
    SPI.transfer(highByte(x));
    SPI.transfer(lowByte(x));
    //test interval
   delay(3000);
Here is the Arduino Mkr Zero Slave code;
#include <SPI.h>
volatile int i = 0;
byte myArray[2];
const int slaveAPin = A5; // SS (PA18 / D10 on SAMD21)
  pinMode(slaveAPin, INPUT_PULLUP);
  attachInterrupt(7, SERCOM0_Handler, FALLING);
  spiSlave_init();
void SERCOM0_Handler()
  noInterrupts();
  uint8_t data = 0;
  data = (uint8_t)SERCOM0->SPI.DATA.reg;
  uint8_t interrupts = SERCOM0->SPI.INTFLAG.reg; //Read SPI interrupt register
  if (interrupts & (1 << 3))
    SERCOM0->SPI.INTFLAG.bit.SSL = 1; //clear slave select interrupt
  if (interrupts & (1 << 2))
    data = SERCOM0->SPI.DATA.reg; //Read data register
    SERCOM0->SPI.INTFLAG.bit.RXC = 1; //clear receive complete interrupt
  if (interrupts & (1 << 1))
    SERCOM0->SPI.INTFLAG.bit.TXC = 1; //clear receive complete interrupt
  if (interrupts & (1 << 0))
    SERCOM0->SPI.DATA.reg = 0xAA;
  uint8_t _data = data;
  Serial.println(_data);
   // print received data
  interrupts();
void spiSlave_init()
  PORT->Group[PORTA].PINCFG[4].bit.PMUXEN = 0x1; //Enable Peripheral Multiplexing for SERCOM0 SPI PA18 Arduino PIN10
  PORT->Group[PORTA].PMUX[2].bit.PMUXE = 0x3; //SERCOM 1 is selected for peripherial use of this pad
  PORT->Group[PORTA].PINCFG[5].bit.PMUXEN = 0x1; //Enable Peripheral Multiplexing for SERCOM0 SPI PA18 Arduino PIN10
  PORT->Group[PORTA].PMUX[2].bit.PMUXO = 0x3; //SERCOM 1 is selected for peripherial use of this pad
  PORT->Group[PORTA].PINCFG[6].bit.PMUXEN = 0x1; //Enable Peripheral Multiplexing for SERCOM0 SPI PA18 Arduino PIN10
  PORT->Group[PORTA].PMUX[3].bit.PMUXE = 0x3; //SERCOM 1 is selected for peripherial use of this pad
  PORT->Group[PORTA].PINCFG[7].bit.PMUXEN = 0x1; //Enable Peripheral Multiplexing for SERCOM0 SPI PA18 Arduino PIN10
  PORT->Group[PORTA].PMUX[3].bit.PMUXO = 0x3; //SERCOM 1 is selected for peripherial use of this pad
  //Disable SPI 1
  SERCOM0->SPI.CTRLA.bit.ENABLE = 0;
  while (SERCOM0->SPI.SYNCBUSY.bit.ENABLE);
  //Reset SPI 1
  SERCOM0->SPI.CTRLA.bit.SWRST = 1;
  while (SERCOM0->SPI.CTRLA.bit.SWRST || SERCOM0->SPI.SYNCBUSY.bit.SWRST);
  //Setting up NVIC
  NVIC_EnableIRQ(SERCOM0_IRQn);
  NVIC_SetPriority(SERCOM0_IRQn, 2);
  //Setting Generic Clock Controller!!!!
  GCLK->CLKCTRL.reg = GCLK_CLKCTRL_ID(GCM_SERCOM0_CORE) | //Generic Clock 0
                      GCLK_CLKCTRL_GEN_GCLK0 | // Generic Clock Generator 0 is the source
                      GCLK_CLKCTRL_CLKEN; // Enable Generic Clock Generator
  while (GCLK->STATUS.reg & GCLK_STATUS_SYNCBUSY); //Wait for synchronisation
  //Set up SPI Control A Register
  SERCOM0->SPI.CTRLA.bit.DORD = 0; //MSB first
  SERCOM0->SPI.CTRLA.bit.CPOL = 0; //SCK is low when idle, leading edge is rising edge
  SERCOM0->SPI.CTRLA.bit.CPHA = 0; //data sampled on leading sck edge and changed on a trailing sck edge
  SERCOM0->SPI.CTRLA.bit.FORM = 0x0; //Frame format = SPI
  SERCOM0->SPI.CTRLA.bit.DIPO = 0; //DATA PAD0 MOSI is used as input (slave mode)
  SERCOM0->SPI.CTRLA.bit.DOPO = 0x2; //DATA PAD3 MISO is used as output
  SERCOM0->SPI.CTRLA.bit.MODE = 0x2; //SPI in Slave mode
  SERCOM0->SPI.CTRLA.bit.IBON = 0x1; //Buffer Overflow notification
  SERCOM0->SPI.CTRLA.bit.RUNSTDBY = 1; //wake on receiver complete
  //Set up SPI control B register
  //SERCOM0->SPI.CTRLB.bit.RXEN = 0x1; //Enable Receiver
  SERCOM0->SPI.CTRLB.bit.SSDE = 0x1; //Slave Selecte Detection Enabled
  SERCOM0->SPI.CTRLB.bit.CHSIZE = 0; //character size 8 Bit
  //SERCOM0->SPI.CTRLB.bit.PLOADEN = 0x1; //Enable Preload Data Register
  //while (SERCOM0->SPI.SYNCBUSY.bit.CTRLB);
  //Set up SPI interrupts
  SERCOM0->SPI.INTENSET.bit.SSL = 0x1; //Enable Slave Select low interrupt
  SERCOM0->SPI.INTENSET.bit.RXC = 0x1; //Receive complete interrupt
  SERCOM0->SPI.INTENSET.bit.TXC = 0x1; //Receive complete interrupt
  SERCOM0->SPI.INTENSET.bit.ERROR = 0x1; //Receive complete interrupt
  SERCOM0->SPI.INTENSET.bit.DRE = 0x1; //Data Register Empty interrupt
  //init SPI CLK
  //SERCOM0->SPI.BAUD.reg = SERCOM_FREQ_REF / (2*4000000u)-1;
  //Enable SPI
  SERCOM0->SPI.CTRLA.bit.ENABLE = 1;
  SERCOM0->SPI.CTRLB.bit.RXEN = 0x1; //Enable Receiver, this is done here due to errate issue
  while (SERCOM0->SPI.SYNCBUSY.bit.CTRLB); //wait until receiver is enabled
Type 1234 in serial monitor Master side. This is what I receive on the Serial monitor Slave side;
11:16:29.501 -> 0
11:16:29.501 -> 4
11:16:29.501 -> 210
Any ideas as to what I should be doing?
Serial.println() while interrupts are disabled (noInterrupts) is a very bad idea on any system.
