SPI Slave Receive then Send
I am using the SPI interrupt example I found on this forum. I have a Mega as an SPI slave, it receives 160 characters for display on an LCD then it needs to send a decoded keypad press back on the same SPI. I have an UNO sending the 160 LCD characters. How would I program both master and slave to transfer the keypress over SPI? My code below does not actually decode any keypad, just want to send a test character for now. I am successfully receiving the 160 lcd characters and displaying on the LCD.
Master:
#include <SPI.h>
#include "pins_arduino.h"
volatile byte c;
void setup (void)
 // Put SCK, MOSI, SS pins into output mode
 // also put SCK, MOSI into LOW state, and SS into HIGH state.
 // Then put SPI hardware into Master mode and turn SPI on
 SPI.begin ();
 SPI.setClockDivider(SPI_CLOCK_DIV8);
 SPI.beginTransaction(SPISettings(1000000, LSBFIRST, SPI_MODE0));
 Serial.begin(38400);
 Serial.println("begin");
}  // end of setup
ISR (SPI_STC_vect)
  c = SPDR;  // grab byte from SPI Data Register
}  // end of interrupt routine SPI_STC_vect
void loop (void)
 // enable Slave Select
 digitalWrite(SS, LOW);    // SS is pin 10
 // send test string
SPI.transfer (0x5f);
for (int a = 0; a <= 2; a++){
 for (const char * p = "1234567890123456789012345678901234567890" ; c = *p; p++)
   SPI.transfer (c);
char millc[40];
sprintf(millc,"%08lu                               X",millis());
for (int a= 0; a <= 39; a++) SPI.transfer(millc[a]);
SPI.transfer (0x7f);
//not sure here.  I just sent the 160 lcd characters, now I need to get the keypad press response from the slave
delay(1);
//SPCR |= _BV(SPE);
SPI.attachInterrupt();
delay(1);
//SPCR |= _BV(SPE);
SPI.detachInterrupt();
Serial.println(c,HEX);//c is volitile byte captured in interrupt
delay(1);
 // disable Slave Select
 digitalWrite(SS, HIGH);
 delay (100);
}  // end of loop
Slave:
The circuit:
 * LCD RS (7) pin to digital pin 9
 * LCD RW (5)pin to digital pin 8
 * LCD Enable (9)Top 2 lines pin to digital pin 7
 * LCD Enable (3)Bottom 2 lines pin to digital pin 6
 * LCD D4 (19)pin to digital pin 5
 * LCD D5 (21)pin to digital pin 4
 * LCD D6 (23)pin to digital pin 3
 * LCD D7(25) pin to digital pin 2
 * 10K resistor:
 * ends to +5V and ground
 * wiper to LCD VO pin (pin 3)
 * Lindsay LCD Pinout:
 * 1 NC 2 NC
 * 3 E2 4 V0
 * 5 RW 6 NC
 * 7 RS 8 VSS
 * 9 E1 10 VSS
 * 11 DBO 12 VSS
 * 13 DB1 14 VSS
 * 15 DB2 16 VSS
 * 17 DB3 18 VSS
 * 19 DB4 20 VSS
 * 21 DB5 22 VDD
 * 23 DB6 24 VDD
 * 25 DB7 26 NC
 * I took a photo and put it in this directory
#include <Arduino.h>
#include <LiquidCrystal.h>
#include <Wire.h>
#include <SPI.h>
int forceSSpin = 30;
// initialize the library with the numbers of the interface pins
LiquidCrystal lcdT(9, 8, 7, 5, 4, 3, 2);//set up top 2 lines
LiquidCrystal lcdB(9, 8, 6, 5, 4, 3, 2);//set up bottom 2 lines
char buf [200];
char lcd [200];
volatile byte pos,clrlcd;
volatile boolean process_it;
volatile int npos,got5f;
int lcdLatch = 0;
unsigned long td = 0;
void software_Reset() // Restarts program from beginning but does not reset the peripherals and registers
  asm volatile ("  jmp 0");
void setup (void)
  Serial.begin (115200);   // debugging
  pinMode(forceSSpin,OUTPUT);
  digitalWrite(forceSSpin,HIGH);
  // have to send on master in, *slave out*
  pinMode(MISO, OUTPUT);
  // turn on SPI in slave mode
  pos = 0;   // buffer empty
  process_it = false;
  init_lcd();
  delay(2000);
  // now turn on interrupts
  SPI.beginTransaction(SPISettings(1500000, LSBFIRST, SPI_MODE0));
  SPCR |= _BV(SPE);
  // get ready for an interrupt
  Serial.println("Begin");
  td = millis();
  delay(100);
  digitalWrite(forceSSpin,LOW);
  Serial.println(pos);
  Serial.println(got5f);
  Serial.println(process_it);
}  // end of setup
// SPI interrupt routine
ISR (SPI_STC_vect)
byte c = SPDR;  // grab byte from SPI Data Register
  // add to buffer if room
  if (pos < sizeof buf)
      if (got5f) buf [pos++] = c;
      if (c == 0x5f && !got5f){
        pos = 0;
        got5f = 1;
      // example: newline means time to process buffer
      if (got5f  && c == 0x7f){
        process_it = true;
        npos = pos;
        pos = 0;
        got5f = 0;
    }  // end of room available
    else{
      pos = 0;
      clrlcd = 1;
// main loop - wait for flag set in interrupt routine
void loop (void)
  if (millis() > td + 2000) {
      delay(100);
      process_it = true;
      td = millis();
  if (process_it)
    SPI.transfer (millis() & 0xff);//not sure here, I just received 160 lcd character and need to send 1 byte keypress back on SPI
    td = millis();
    lcdLatch = 0;
    process_it = false;
    int p = 0;
    int a;
    for (a = 0; a < npos; a++){
      //if (buf[a] < 0x10) Serial.print('0');
      //Serial.print(buf[a],HEX);
      //Serial.print(' ');
      lcd[p++] = buf[a];//( & 0xF) | (buf[a+1] << 4);
    lcd[a-1] = 0;
    String lcdp = lcd;
    got5f = 0;
    npos = 0;
    //DateTime now = rtc.now();
    char line[50];
    String line1;
    line1 = lcdp.substring(0,40);
    line1.toCharArray(line,41);
    lcdT.setCursor(0,0);//column,row
    lcdT.print(line);
    lcdT.display();
    Serial.println(line);
    line1 = lcdp.substring(40,80);
    lcdT.setCursor(0,1);//column,row
    lcdT.print(line);
    lcdT.display();
    line1 = lcdp.substring(80,120);
    lcdB.setCursor(0,0);//column,row
    lcdB.print(line);
    lcdB.display();
    line1 = lcdp.substring(120,160);
    lcdB.setCursor(0,1);//column,row
    lcdB.print(line);  // write something to the internal memory
    lcdB.display();
    }  // end of flag set
}  // end of loop
void init_lcd(){
    // set up the LCD's number of columns and rows:
  lcdT.begin(40, 2);
  lcdB.begin(40, 2);
  // Print a message to the LCD.
  lcdT.clear();
  lcdB.clear();
  lcdT.setCursor(0,2);//column,row
  lcdT.print("Initialization Done...");
  lcdT.display();
  delay(200);
  lcdT.clear();
  lcdB.clear();
On an SPI bus a device is either master or slave, it cannot be both. The good news is that for every byte you transfer from the master to the slave, the slave can send one byte back, you just have to ensure that the byte is ready on the slave when the master starts the transfer.
