I've set up my Uno as an SPI slave to another microcontroller (uC2). I am able to send a byte from the uC2 to the Uno, and forward it to the serial monitor.
I have set up an oscilloscope to monitor the slave select (yellow), MOSI (green), MISO (blue), and clock (red) and I discover that with each subsequent transmission, the data transmitted from uC2 to Uno on MOSI in the previous transmission is returned on MISO at the point of the new transmission.
I have not set the Arduino up to do this. Is this the default behaviour? Is there an explanation which would be obvious to someone more advanced than me?
My Arduino code is as follows:
// Arduino SPI Slave
#include <SPI.h>
char buff[8];
volatile boolean process_it = false;
void setup(void)
// Reset data I/O pins
pinMode(MISO, OUTPUT);
pinMode(MOSI, INPUT);
// Set clock speed to 1MHz
SPI.setClockDivider(SPI_CLOCK_DIV16);
// Turn on in slave mode
SPCR |= 1 << SPE;
// Enable interrupt
SPI.attachInterrupt();
ISR (SPI_STC_vect)
buff[0] = SPDR; // Get byte from SPI Data Reg
process_it = true;
void loop(void)
static word my_tick = 0;
// if (my_tick == 50000)
// Serial.println("Tick");
// my_tick = 0;
// else
// my_tick++;
if (true == process_it)
Serial.println((int) buff[0], HEX);
process_it = false;
