SPI Slave Select lines controlled with port expander/shift register?
Hi all,
I have about 25 SPI digital pots (MCP41HV51) I want to control with an ATMEGA328. Datasheet says these pot aren't capable of being daisy-chained despite having SI and SO pins.
So obviously the MCU won't have enough pins for 25 Slave Select lines... I'm wondering if it's possible to connect an i2c/SPI port expander/shift register and use the expander's pins to control the 25 Slave Select lines? Obviously the clock and MISO/MOSI will be connected straight to the MCU.
Thanks
Jonathan
Yes, that will be fine.
Oh, that's easy. That's the answer I was hoping for thanks!
I'll be sure to come back if I run into any troubles though :slight_smile:
Thanks again
Jonathan
