SPI Transfer Crashing Arduino with ArduCAM
Hey Guys,
This issue was found utilizing the OV2640 Mini module, as well as an Arduino Zero clone using copied and pasted example code. There is a flash storage chip as well as a SX127X LoRa radio utilizing the same bus. When this issue occurs, the Arduino will crash while executing an SPI transfer as used during photo capture on lines such as while (!myCAM.get_bit(ARDUCHIP_TRIG , CAP_DONE_MASK)); and temp = SPI.transfer(0x00);. Crashing being defined as locked up, no longer executing further code.
On the capture before the crash, using an Oscilloscope we noticed the chip select line not returning back to high after capture randomly (line stays low, the camera continues to believe to be the active device on the SPI bus), then while transceiving data with the LoRa radio, some information is incorrect. During the next capture, the temp = SPI.transfer(0x00) line will crash.
The issue seems to arise with a pattern of utilizing the radio and camera in a specific pattern, have not figured out the pattern, but it has been a noticeable issue for a while, it seems random when just trying to diagnose with no tools. I have seen others online complain about soundingly similar issues.
If you look within the library, it uses cbi and sbi a lot, and it's switching the chip select many, many times a capture.
void capture() {
  char str[8];
  byte buf[256];
  static int i = 0;
  static int k = 0;
  uint8_t temp = 0, temp_last = 0;
  uint32_t length = 0;
  bool is_header = false;
  File outFile;
  //Flush the FIFO
  myCAM.flush_fifo();
  //Clear the capture done flag
  myCAM.clear_fifo_flag();
  //Start capture
  myCAM.start_capture();
  Serial.println(F("start Capture"));
  while (!myCAM.get_bit(ARDUCHIP_TRIG , CAP_DONE_MASK)); // CAN CRASH HERE
  Serial.println(F("Capture Done."));
  length = myCAM.read_fifo_length(); // CAN CRASH HERE
  Serial.print(F("The fifo length is :"));
  Serial.println(length, DEC);
  if (length >= MAX_FIFO_SIZE) //384K
    Serial.println(F("Over size."));
    return ;
  if (length == 0 ) //0 kb
    Serial.println(F("Size is 0."));
    return ;
  //Construct a file name
  k = k + 1;
  itoa(k, str, 10);
  strcat(str, ".jpg");
  //Open the new file
  outFile = SD.open(str, O_WRITE | O_CREAT | O_TRUNC);
  if (!outFile) {
    Serial.println(F("File open faild"));
    return;
  myCAM.CS_LOW();
  myCAM.set_fifo_burst();
  while ( length-- )
    temp_last = temp;
    temp =  SPI.transfer(0x00); // CAN CRASH HERE
    //Read JPEG data from FIFO
    if ( (temp == 0xD9) && (temp_last == 0xFF) ) //If find the end ,break while,
      buf[i++] = temp;  //save the last  0XD9
      //Write the remain bytes in the buffer
      myCAM.CS_HIGH();
      outFile.write(buf, i);
      //Close the file
      outFile.close();
      Serial.println(F("Image save OK."));
      is_header = false;
      i = 0;
    if (is_header == true)
      //Write image data to buffer if not full
      if (i < 256)
        buf[i++] = temp;
        //Write 256 bytes image data to file
        myCAM.CS_HIGH();
        outFile.write(buf, 256);
        i = 0;
        buf[i++] = temp;
        myCAM.CS_LOW();
        myCAM.set_fifo_burst(); // CAN CRASH HERE
    else if ((temp == 0xD8) & (temp_last == 0xFF))
      is_header = true;
      buf[i++] = temp_last;
      buf[i++] = temp;
For now, I can't put the camera on another bus, but I require a software fix, has anyone had this issue with possibly a different Arduino accessory, and if so, what was your fix? I have wasted so much time on this and I'm this close to rewriting the library.
