I have encountered a rather peculiar problem while attempting to use DMA to transmit data using the SPI module. I have the following code:
// Disable interrupt handling.
__disable_irq();
/* PIN SETUP
SPI0 MOSI = PA26 peripheral A. */
// Enable PIOA internal clock supply.
pmc_enable_periph_clk(ID_PIOA);
// Set PA26 to peripheral A mode.
PIO_SetPeripheral(PIOA, EPioType::PIO_PERIPH_A, 1u << 26);
// Disable pull-up resistor on PA26.
REG_PIOA_PUDR = 1u << 26;
// SPI CS0.
PIO_SetPeripheral(PIOA, EPioType::PIO_PERIPH_A, 1u << 28);
REG_PIOA_PUDR = 1u << 28;
/* SPI SETUP
Using SPI module 0. */
// Enable SPI0 clock supply.
pmc_enable_periph_clk(ID_SPI0);
// Disable SPI0 for now, will be enabled once DMAC is set up.
REG_SPI0_CR = SPI_CR_SPIDIS;
// Disable SPI0 interrupts.
REG_SPI0_IDR = 0x70Fu;
// Set SPI0 to master mode, using CS0, fault protection disabled.
REG_SPI0_MR = SPI_MR_MSTR | SPI_MR_MODFDIS;
// Set SPI0 to data on rising clock, 16 bits per transfer, clock = MCK/105, CS-SCK delay is minimum.
REG_SPI0_CSR = SPI_CSR_NCPHA | SPI_CSR_BITS_16_BIT | 105u << 8 | 1u << 16;
/* DMAC SETUP
Using DMAC channel 5 (highest priority), with hardware handshaking interface 1 (SPI0 transmit). */
// Enable DMAC clock supply.
pmc_enable_periph_clk(ID_DMAC);
// Enable DMAC.
REG_DMAC_EN = DMAC_EN_ENABLE;
// Disable DMAC channel while we modify settings.
REG_DMAC_CHDR = DMAC_CHDR_DIS5;
// Set DMAC to fixed channel priority.
REG_DMAC_GCFG = DMAC_GCFG_ARB_CFG_FIXED;
// Disable DMAC interrupts.
REG_DMAC_EBCIDR = 0x3F3F3F;
// Data to send over SPI.
uint32_t data = 0x1117;
// Set transfer source address.
REG_DMAC_SADDR5 = reinterpret_cast<uint32_t>(&data);
// Set transfer destination address.
REG_DMAC_DADDR5 = reinterpret_cast<uint32_t>(®_SPI0_TDR);
// Set descriptor address to 0 (linked-list mode disabled).
REG_DMAC_DSCR5 = 0;
/* Transfer size = 1 (1 word to be transferred in total)
Source and destination widths = word = 32 bits (SPI_TDR register is 32-bit)
Source and destination chunk sizes = 1 (1 word is transferred per handshake (request from SPI module)) */
REG_DMAC_CTRLA5 = 1u | DMAC_CTRLA_SRC_WIDTH_WORD | DMAC_CTRLA_DST_WIDTH_WORD | DMAC_CTRLA_SCSIZE_CHK_1 | DMAC_CTRLA_DCSIZE_CHK_1;
/* Set linked-list mode disabled, flow controller to memory-to-peripheral controller,
transfer source address fixed, transfer destination address fixed. */
REG_DMAC_CTRLB5 = DMAC_CTRLB_SRC_DSCR_FETCH_DISABLE | DMAC_CTRLB_DST_DSCR_FETCH_DISABLE | DMAC_CTRLB_FC_MEM2PER_DMA_FC
| DMAC_CTRLB_SRC_INCR_FIXED | DMAC_CTRLB_DST_INCR_FIXED;
// Set destination handshaking to hardware, peripheral 1 (SPI0 transmit).
REG_DMAC_CFG5 = DMAC_CFG_DST_H2SEL_HW | (1u << 4);
// Enable channel.
REG_DMAC_CHER = DMAC_CHER_ENA5;
delayMicroseconds(1000);
// Enable SPI0 and trigger DMAC request.
REG_SPI0_CR = SPI_CR_SPIEN;
Which as far I can tell should work fine. Yet for some reason, while the DMAC transfer does occur and the SPI module transmits data, it transmits the wrong data. It always sends something like 0x0100 or 0x0000, no matter what I put in the source buffer. If I replace the DMA destination address with, for example, a normal memory address, instead of the SPI_TDR register, I observe that the correct data is in fact transferred by the DMA controller. Yet it refuses to work with SPI_TDR.
What’s stranger is that the code works exactly as expected if I add a read to the DMAC_CHSR register at the end of setup(). I don’t understand how this can possibly make any difference. Nothing in the datasheet says anything about reading DMAC_CHSR having any effect on the behaviour.
The actual execution of the read doesn’t seem to be the cause, though. Adding a considerable delay (e.g. 10ms) after the enable of the SPI channel and before the read of DMAC_CHSR still makes it work.
Additionally, it is not anything weird from the end of setup() or the beginning of loop(). Adding an infinite while loop after the SPI channel enable still results in the incorrect transmission.
It seems as though just the presence of a read from DMAC_CHSR somewhere in the code affects the behaviour, which makes me think it could be some sort of compiler thing. But I don’t see anything the compiler could do to produce this specific effect. Alternatively, perhaps it’s a similar thing but at the CPU level? Again, I don’t see what it could be, though.
If anyone has any idea what’s going on here, that’d be great.
Thanks.
