I have been searching everywhere to help me see why my project is not working. Where can I find out more information on using UNO R3 as a master and the ESP32-Cam and a 2-wire fan as slaves?
Is that you cannot do communication with ESP32-CAM using 2-wire (TWI/I2C) Bus?
What's the purpose of wanting I2C communications between a ESP32 and a UNO? What code have you tried so far? Where does your code fail?
If you have an ESP32, why would you want to use an Arduino UNO? ![]()
I could see where an Uno might be useful with a ESP32CAM but using another 3.3V device with the cam would settle some 5V/3.3V interface issues.
Vaguely possible, but very unlikely. ![]()
Thank you everyone. I am new to this and find it all fascinating. I am just getting stuck with my big ideas and my months of research has not yielded the results I am looking for.
Here is the sketch I am working on. It is a combination of sketches that work independent of each other. My problem is that the ESP32-Cam does not have enough pins to control the fan and the sensor. Someone said I could get additional sensors by using SPI mode. So, I have been researching how to do that as a newbie. I have not put the SPI code in yet.
I want to turn on the fan for 3 seconds then shut it off for 30 minutes. I want the sensor to pick up movement then turn the camera on so that I can see what the movement is from. I want to send an email picture of the movement or live stream the movement via Blynk.
// Fill-in information from your Blynk Template here
#define BLYNK_TEMPLATE_ID ""
#define BLYNK_DEVICE_NAME ""
#define BLYNK_FIRMWARE_VERSION "0.1.0"
#define BLYNK_PRINT Serial
//#define BLYNK_DEBUG
#define APP_DEBUG
// Uncomment your board, or configure a custom board in Settings.h
//#define USE_WROVER_BOARD
//#define USE_TTGO_T7
//#define USE_CAMERA_MODEL_AI_THINKER
#include "BlynkEdgent.h"
// INCLUDES
#include <SPI.h>
#include "Arduino.h" // General functionality
#include "esp_camera.h" // Camera
#include <SD.h> // SD Card
#include "FS.h" // File System
#include "soc/soc.h" // System settings (e.g. brownout)
#include "soc/rtc_cntl_reg.h"
#include "driver/rtc_io.h"
#include <EEPROM.h> // EEPROM flash memory
#include <WiFi.h> // WiFi
#include "time.h" // Time functions
// "ESP Mail Client" by Mobizt, tested with v1.6.4
#include "ESP_Mail_Client.h" // e-Mail
// DEFINES
//#define USE_INCREMENTAL_FILE_NUMBERING //Uses EEPROM to store latest file stored
#define USE_TIMESTAMP // Uses Wi-Fi to retrieve current time value
#define SEND_EMAIL // Uses Wi-Fi to email photo attachment
#define TRIGGER_MODE // Photo capture triggered by GPIO pin rising/falling
//#define TIMED_MODE // Photo capture automated according to regular delay
// Wi-Fi settings
#define SMTP_HOST "smtp.office365.com"
#define SMTP_PORT 25
#define AUTHOR_EMAIL ""
#define AUTHOR_PASSWORD ""
// CONSTANTS
// GPIO Pin 33 is small red LED near to RESET button on the back of the board
const byte ledPin = GPIO_NUM_33;
// GPIO Pin 4 is bright white front-facing LED
const byte flashPin = GPIO_NUM_4;
// When using TRIGGER_MODE, this pin will be used to initiate photo capture
const byte triggerPin = GPIO_NUM_13;
// Flash strength (0=Off, 255=Max Brightness)
// Setting a low flash value can provide a useful visual indicator of when a photo is being taken
const byte flashPower = 1;
//#ifdef TIMED_MODE
// const int timeLapseInterval = 30; // seconds between successive shots in TIMELAPSE mode
//#endif
const int startupDelayMillis = 3000; // time to wait after initialising camera before taking photo
// constants won't change. They're used here to set pin numbers:
const int pb = 13; // the number of the pushbutton pin this pin needs to be virtual
const int en = 3; // the number of the LED pin
const int in1 = 2;
int speedPin=5;
int dir1=4;
int dir2=8;
int mSpeed=255;
// variables will change:
int buttonState = 0; // variable for reading the pushbutton status
// GLOBALS
// Keep track of number of pictures taken for incremental file naming
int pictureNumber = 0;
// Full path of filename of the last photo saved
String path;
#ifdef SEND_EMAIL
// SMTP session used for eMail sending
SMTPSession smtp;
// Function fired on email success/failure
void smtpCallback(SMTP_Status status);
// Callback function after eMail sending
void smtpCallback(SMTP_Status status) {
// Print the current status
Serial.println(status.info());
// Show details of successful delivery
if (status.success()) {
Serial.println("----------------");
Serial.printf("Message sent success: %d\n", status.completedCount());
Serial.printf("Message sent failed: %d\n", status.failedCount());
Serial.println("----------------\n");
struct tm dt;
for (size_t i=0; i<smtp.sendingResult.size(); i++) {
SMTP_Result result = smtp.sendingResult.getItem(i);
time_t ts = (time_t)result.timestamp;
localtime_r(&ts, &dt);
Serial.printf("Message No: %d\n", i + 1);
Serial.printf("Status: %s\n", result.completed ? "success" : "failed");
Serial.printf("Date/Time: %d/%d/%d %d:%d:%d\n", dt.tm_year + 1900, dt.tm_mon + 1, dt.tm_mday, dt.tm_hour, dt.tm_min, dt.tm_sec);
Serial.printf("Recipient: %s\n", result.recipients);
Serial.printf("Subject: %s\n", result.subject);
#endif
void sleep() {
// IMPORTANT - we define pin mode for the trigger pin at the end of setup, because most pins on the ESP32-CAM
// have dual functions, and may have previously been used by the camera or SD card access. So we overwrite them here
pinMode(triggerPin, INPUT_PULLDOWN);
// Ensure the flash stays off while we sleep
rtc_gpio_hold_en(GPIO_NUM_4);
// Turn off the LED
digitalWrite(ledPin, HIGH);
#ifdef TRIGGER_MODE
// Use this to wakeup when trigger pin goes HIGH
esp_sleep_enable_ext0_wakeup(GPIO_NUM_13, 1);
// Use this to wakeup when trigger pin goes LOW
//esp_sleep_enable_ext0_wakeup(GPIO_NUM_13, 0);
//#elif defined(TIMED_MODE)
// Or, use this to wakeup after a certain amount of time has elapsed (parameter specified in uS, so multiply secs by 1000000)
//esp_sleep_enable_timer_wakeup(timeLapseInterval * 1000000);
#endif
Serial.println("Going to sleep now");
esp_deep_sleep_start();
Serial.println("This will never be printed");
// Light up the discrete red LED on the back of the board to show the device is active
pinMode(ledPin, OUTPUT);
// It's an active low pin, so we write a LOW value to turn it on
digitalWrite(ledPin, LOW);
// CAUTION - We'll disable the brownout detection
WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0);
// Start serial connection for debugging purposes
while (!Serial); delay(200);
delay(100);
Serial.println("Starting up...");
// initialize the LED pin as an output:
// any code you place here will execute when the virtual pin value changes
pinMode (speedPin, OUTPUT);
pinMode (dir1, OUTPUT);
pinMode (dir2, OUTPUT);
pinMode(en, OUTPUT);
pinMode(in1, OUTPUT);
// initialize the pushbutton pin as an input:
// Note: Pullup makes HIGH/LOW state backward from what we typically think.
// So, HIGH = not pressed, LOW = pressed
pinMode(pb, INPUT_PULLUP);
// Keep en pin on all the time:
// If fanciness is needed, you can modulate this pin to control the speed of the fan.
Serial.println("en pin set HIGH");
digitalWrite(en, HIGH);
BlynkEdgent.begin();
Serial.println(__FILE__ __DATE__);
//Pin definition for CAMERA_MODEL_AI_THINKER
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = 5;
config.pin_d1 = 18;
config.pin_d2 = 19;
config.pin_d3 = 21;
config.pin_d4 = 36;
config.pin_d5 = 39;
config.pin_d6 = 34;
config.pin_d7 = 35;
config.pin_xclk = 0;
config.pin_pclk = 22;
config.pin_vsync = 25;
config.pin_href = 23;
config.pin_sscb_sda = 26;
config.pin_sscb_scl = 27;
config.pin_pwdn = 32;
config.pin_reset = -1;
config.xclk_freq_hz = 20000000;
config.pixel_format = PIXFORMAT_JPEG;
// If the board has additional "pseudo RAM", we can create larger images
if(psramFound()){
config.frame_size = FRAMESIZE_UXGA; // UXGA=1600x1200. Alternative values: FRAMESIZE_ + QVGA|CIF|VGA|SVGA|XGA|SXGA|UXGA
config.jpeg_quality = 10;
config.fb_count = 2;
config.frame_size = FRAMESIZE_SVGA;
config.jpeg_quality = 12;
config.fb_count = 1;
// Disable any hold on pin 4 that was placed before ESP32 went to sleep
rtc_gpio_hold_dis(GPIO_NUM_4);
// Use PWM channel 7 to control the white on-board LED (flash) connected to GPIO 4
ledcSetup(7, 5000, 8);
ledcAttachPin(4, 7);
// Turn the LED on at specified power
ledcWrite(7, flashPower);
// Initialise the camera
// Short pause helps to ensure the I2C interface has initialised properly before attempting to detect the camera
delay(250);
esp_err_t err = esp_camera_init(&config);
if (err != ESP_OK) {
Serial.printf("Camera init failed with error 0x%x", err);
sleep();
// Image settings
sensor_t * s = esp_camera_sensor_get();
// Gain
s->set_gain_ctrl(s, 1); // Auto-Gain Control 0 = disable , 1 = enable
s->set_agc_gain(s, 0); // Manual Gain 0 to 30
s->set_gainceiling(s, (gainceiling_t)0); // 0 to 6
// Exposure
s->set_exposure_ctrl(s, 1); // Auto-Exposure Control 0 = disable , 1 = enable
s->set_aec_value(s, 300); // Manual Exposure 0 to 1200
// Exposure Correction
s->set_aec2(s, 0); // Automatic Exposure Correction 0 = disable , 1 = enable
s->set_ae_level(s, 0); // Manual Exposure Correction -2 to 2
// White Balance
s->set_awb_gain(s, 1); // Auto White Balance 0 = disable , 1 = enable
s->set_wb_mode(s, 0); // White Balance Mode 0 to 4 - if awb_gain enabled (0 - Auto, 1 - Sunny, 2 - Cloudy, 3 - Office, 4 - Home)
s->set_whitebal(s, 1); // White Balance 0 = disable , 1 = enable
s->set_bpc(s, 0); // Black Pixel Correction 0 = disable , 1 = enable
s->set_wpc(s, 1); // White Pixel Correction 0 = disable , 1 = enable
s->set_brightness(s, 0); // Brightness -2 to 2
s->set_contrast(s, 0); // Contrast -2 to 2
s->set_saturation(s, 0); // Saturation -2 to 2
s->set_special_effect(s, 0); // (0 - No Effect, 1 - Negative, 2 - Grayscale, 3 - Red Tint, 4 - Green Tint, 5 - Blue Tint, 6 - Sepia)
// Additional settings
s->set_lenc(s, 1); // Lens correction 0 = disable , 1 = enable
s->set_hmirror(s, 0); // Horizontal flip image 0 = disable , 1 = enable
s->set_vflip(s, 0); // Vertical flip image 0 = disable , 1 = enable
s->set_colorbar(s, 0); // Colour Testbar 0 = disable , 1 = enable
s->set_raw_gma(s, 1); // 0 = disable , 1 = enable
s->set_dcw(s, 1); // 0 = disable , 1 = enable
// We want to take the picture as soon as possible after the sensor has been triggered, so we'll do that first, before
// setting up the SD card, Wifi etc.
// Initialise a framebuffer
camera_fb_t *fb = NULL;
// But... we still need to give the camera a few seconds to adjust the auto-exposure before taking the picture
// Otherwise you get a green-tinged image as per https://github.com/espressif/esp32-camera/issues/55
// Two seconds should be enough
delay(startupDelayMillis);
// Take picture
fb = esp_camera_fb_get();
// Check it was captured ok
if(!fb) {
Serial.println("Camera capture failed");
sleep();
// Turn flash off after taking picture
ledcWrite(7, 0);
// Build up the string of the filename we'll use to save the file
path = "/pic";
// Following section creates filename based on increment value saved in EEPROM
#ifdef USE_INCREMENTAL_FILE_NUMBERING
// We only need 2 bytes of EEPROM to hold a single int value, but according to
// https://arduino-esp8266.readthedocs.io/en/latest/libraries.html#eeprom
// Minimum reserved size is 4 bytes, so we'll use that
EEPROM.begin(4);
// Read the value from the EEPROM cache
EEPROM.get(0, pictureNumber);
pictureNumber += 1;
// Path where new picture will be saved in SD Card
path += String(pictureNumber) + "_";
// Update the EEPROM cache
EEPROM.put(0, pictureNumber);
// And then actually write the modified cache values back to EEPROM
EEPROM.commit();
#endif
// Connect to Wi-Fi if required
#if defined(SEND_EMAIL) || defined(USE_TIMESTAMP)
WiFi.mode(WIFI_STA);
WiFi.setHostname("Pest Memo");
int connAttempts = 0;
// WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
while (WiFi.status() != WL_CONNECTED && connAttempts < 10) {
Serial.print(".");
connAttempts++;
if(WiFi.isConnected()){
Serial.println("");
Serial.println("WiFi connected.");
Serial.println("IP address: ");
Serial.print(" Signal Level: ");
Serial.println(WiFi.RSSI());
else {
Serial.println(F("Failed to connect to Wi-Fi"));
sleep();
#endif
#ifdef USE_TIMESTAMP
// Following section creates filename based on timestamp
const long gmtOffset_sec = 0;
const int daylightOffset_sec = 0;
// Synchronise time from specified NTP server - e.g. "pool.ntp.org", "time.windows.com", "time.nist.gov"
// From https://github.com/espressif/arduino-esp32/blob/master/libraries/ESP32/examples/Time/SimpleTime/SimpleTime.ino
configTime(gmtOffset_sec, daylightOffset_sec, "pool.ntp.org");
struct tm timeinfo;
if(!getLocalTime(&timeinfo)){
Serial.println("Failed to obtain time");
sleep();
else {
Serial.print("Current time is ");
Serial.println(&timeinfo, "%A, %B %d %Y %H:%M:%S");
char timeStringBuff[50]; //50 chars should be enough
strftime(timeStringBuff, sizeof(timeStringBuff), "%Y%m%d_%H%M%S", &timeinfo);
path += (String)timeStringBuff;
#endif
// Add the file extension
path += ".jpg";
// Next, we need to start the SD card
Serial.println("Starting SD Card");
if(!MailClient.sdBegin(14, 2, 15, 13)) {
Serial.println("SD Card Mount Failed");
sleep();
// Access the file system on the SD card
fs::FS &fs = SD;
// Attempt to save the image to the specified path
File file = fs.open(path.c_str(), FILE_WRITE);
if(!file){
Serial.printf("Failed to save to path: %s\n", path.c_str());
sleep();
else {
file.write(fb->buf, fb->len); // payload (image), payload length
Serial.printf("Saved file to path: %s\n", path.c_str());
file.close();
// Now that we've written the file to SD card, we can release the framebuffer memory of the camera
esp_camera_fb_return(fb);
// And breathe for a moment...
#ifdef SEND_EMAIL
// Get verbose output of emailing process
smtp.debug(1);
// Assign the callback function called after sending
smtp.callback(smtpCallback);
// Define the session config data which used to store the TCP session configuration
ESP_Mail_Session session;
session.server.host_name = SMTP_HOST;
session.server.port = SMTP_PORT;
session.login.email = AUTHOR_EMAIL;
session.login.password = AUTHOR_PASSWORD;
session.login.user_domain = "mydomain.net";
// Define the SMTP_Message class variable to hold the config of the eMail itself
SMTP_Message message;
//message.enable.chunking = true; // Enable chunked data transfer for large messages if server supported
message.sender.name = "ESP32-CAM";
message.sender.email = AUTHOR_EMAIL;
message.subject = "Motion Detected - ESP32-CAM";
message.addRecipient("", "");
//message.addRecipient("name2", "email2");
//message.addCc("email3");
//message.addBcc("email4");
// Set the message content
message.text.content = "Motion has been detected in your Pest Memo. Please take a look inside of it.";
message.text.transfer_encoding = Content_Transfer_Encoding::enc_base64;
// Now define the attachment properties
SMTP_Attachment att;
att.descr.filename = "photo.jpg";
att.descr.mime = "application/octet-stream"; //binary data
att.file.path = path.c_str();
att.file.storage_type = esp_mail_file_storage_type_sd;
att.descr.transfer_encoding = Content_Transfer_Encoding::enc_base64;
// Add attachment to the message
message.addAttachment(att);
// Connect to server with the session config
Serial.println("Connecting to SMTP");
if(!smtp.connect(&session)) {
Serial.println("Couldn't connect");
sleep();
// Start sending Email and close the session
Serial.println("Sending Mail");
if(!MailClient.sendMail(&smtp, &message)) {
Serial.println("Error sending Email, " + smtp.errorReason());
sleep();
#endif
// Now that email is sent, we can turn the Wi-Fi off
WiFi.disconnect(true);
WiFi.mode(WIFI_OFF);
// And go to bed until the next time we are triggered to take a photo
sleep();
BlynkEdgent.run();
It has a few GPIO pins. At first glance, you only need 2 pins.
A single output pin connected to a suitable relay module should be able to do this.
A PIR sensor maybe? It usually has 1 pin that changes from low to high (or high to low) when motion is detected.
Surprising. As @markd833 points out, you only need two pins so far.
Is there in fact something you are not telling us?
How many other things are involved in your "multiple sketches"?
A "port expander" connects with two pins using I²C and gives you up to 16 I/O pins.
Easy to program and much simpler (and cheaper) than trying to code a UNO - which is a very poor choice anyway for an actual project such as this. ![]()
Sorry, I was at work.
I am new. So, when I read that I need a pin for a push button, for the fan, for the sensor, for an LED, and for Blynk I feel I don't have enough pins.
Thank you. Will I need a pin for the push button, to reset the wi-fi provisioning, or to have an LED to show the device is getting power?
