SPI vs Analog for Inclinometer
Hey Everyone!
I am currently using an MPU-6050 successfully in a project to keep a platform level but I am finding that it is not quite precise enough.
I was thinking about switching to a muRata SCA103T since I only need to measure 1DOF.
Datasheet
It has two possible ways to interface. Analog and SPI.
I was wondering if there is any advantage of using SPI?
If I go with analog can I simply connect out1 and out2 on the sensor to analog inputs on Arduino?
I will include the resistors and capacitors from the recommended circuit diagram.
The formula for the angle calculation looks straightforward.
Thanks!
Sam
The SCA103T will probably outperform the ..6050. Use the SPI interface, which add the extra bit and eliminate noisy connections
Thanks Ny!
