I'm using an ad8402 digipot (1) to control a PWM motor controller and I'd like to get motor feedback on an LED display (2). I'm using a remote control device to set the motor speed (3). I've followed the digipot tutorial (4) and alfa66's last comment in this thread (5) to setup the digipot.
When I run code that only controls the motor, it works great with the remote (press 0: stop, 3: slow, 6: medium, 9: fast) -- this is with the display wired in. The display is sharing CLK and MOSI with the digipot, although I've tried it with all the display pins separated from the digipot. The display comes with some libraries that use SPI (6).
When I run code that only operates the display (digipot in the circuit), the display shows what I want when I press those buttons.
But, when I try to combine the display and digipot code into a single program, I either get motor control or display control, depending on the order I call the those parts in setup. So I got to thinking that I'm not using CS correctly (the display and the digipot are on separate pins for CS) and that I'm really only activating the pin for the first device I communicate with in setup.
Clearly, I'm not handling CS correctly and any hints on how I can address both parts would be appreciated.
(1) Monochrome 128x32 SPI OLED graphic display : ID 661 : $17.50 : Adafruit Industries, Unique & fun DIY electronics and kits
(2) http://www.digikey.com/product-search/en?pv1=112&pv154=756&pv69=80&k=ad8402&mnonly=0&newproducts=0&ColumnSort=0&page=1&quantity=0&ptm=0&fid=0&pageSize=100
(3) Mini Remote Control : ID 389 : $4.95 : Adafruit Industries, Unique & fun DIY electronics and kits
(4) http://arduino.cc/en/Tutorial/SPIDigitalPot
(5) Problem with Arduino Tutorial "Controlling a Digital Potentiometer Using SPI" - #8 by system - LEDs and Multiplexing - Arduino Forum
(6) GitHub - adafruit/Adafruit_SSD1306: Arduino library for SSD1306 monochrome 128x64 and 128x32 OLEDs
My code -- my most recent failed attempt involved using digitalWrite to the two devices identified as "lcd" and "digipot" -- I've added the lines "//last failed try" by those, but it seems the display library handles this, so I'm only sort of repeating things:
//omitted adafruit info to save space
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include "Adafruit_NECremote.h"
#include <SPI.h>
#include <Wire.h>
//setup digipot
//MOSI=11
//CLK=13
const int digipot = 10; //digipot CS
const int lcd = 12; //display CS
//setup the motor to off
byte channel=1;
byte level=255;
String velocity="default";
//setup remote
#define IRpin 4
Adafruit_NECremote remote(IRpin);
// setup display
#define OLED_MOSI 11
#define OLED_CLK 13
#define OLED_DC 8
#define OLED_CS 12
#define OLED_RESET 9
Adafruit_SSD1306 display(OLED_MOSI, OLED_CLK, OLED_DC, OLED_RESET, OLED_CS);
Serial.println("started");
pinMode(digipot, OUTPUT);
pinMode(lcd, OUTPUT);
SPI.begin();
// setup motor in stopped
digitalPotWrite(channel,level);
//setup display to be OK on 5v
display.begin(SSD1306_SWITCHCAPVCC);
// You can set the listen() time out to 'n' seconds
int c = remote.listen(5); // seconds to wait before timing out!
Serial.println(c);
if (c >= 0) {
if (c == 12){
level=255;
velocity="stopped";
if (c == 18){
level=180;
velocity="slow";
if (c == 22){
level=60;
velocity="medium";
if (c == 26){
level=0;
velocity="fast";
displaySpeed(velocity);
Serial.println(level);
Serial.println(velocity);
Serial.println(c);
Serial.println("");
void digitalPotWrite(byte address, byte value){
digitalWrite(digipot, LOW);
digitalWrite(lcd, HIGH); //last failed try
SPI.transfer(address);
SPI.transfer(value);
digitalWrite(digipot, HIGH);
void displaySpeed(String velocity){
digitalWrite(digipot, HIGH); //last failed try
digitalWrite(lcd, LOW); //last failed try
display.clearDisplay();
display.setTextSize(2);
display.setTextColor(WHITE);
display.setCursor(0,0);
display.println("Level:");
display.println(velocity);
display.display();
