SPI with multiple slaves
if i use pin 9 to connect to another slave..
what should i change in my code
  Code to test MCP23S08 SPI B-bit I/O expander
  See:
     <http://code.rancidbacon.com/LearningAboutArduinoMCP23S08>
     <http://www.arduino.cc/en/Tutorial/SPIEEPROM>
  Current features:
      * Read input pins
      * Set output pins
      * Write output pins
      * Gratuitous LED fiddling
      * Terrible hacked-together code
// Define SPI-related pins
#define PIN_DATA_OUT 11 // MOSI (Master Out / Slave In)
#define PIN_DATA_IN  12 // MISO (Master In / Slave Out)
#define PIN_SPI_CLOCK  13 // SCK (Serial Clock)
#define PIN_SLAVE_SELECT 10 // SS (Slave Select)
byte deviceOpcodeRead = 0;
byte deviceOpcodeWrite = 0; // TODO: handle this better?
byte pinState = B00000000;
unsigned long clk = 0;
void setup () {
  Serial.println("Setup enter...");
  Serial.print("SPCR: "); Serial.println(SPCR, BIN);
  // Configure SPI
  //   Configure I/O pins
  pinMode(PIN_DATA_OUT, OUTPUT);
  pinMode(PIN_DATA_IN, INPUT);
  pinMode(PIN_SPI_CLOCK, OUTPUT);
  pinMode(PIN_SLAVE_SELECT, OUTPUT);
  digitalWrite(PIN_SLAVE_SELECT, HIGH); // Disable slave
  //    Configure SPI Control Register (SPCR) (All values initially 0)
  //     Bit  Description
  //       7  SPI Interrupt Enable    -- disable  (SPIE --> 0)
  //       6  SPI Enable              -- enable   (SPE  --> 1)
  //       5  Data Order              -- MSB 1st  (DORD --> 0) (Slave specific)
  //       4  Master/Slave Select     -- master   (MSTR --> 1)
  //       3  Clock Polarity          --          (CPOL --> 0) (Slave specific) ("Mode")
  //       2  Clock Phase             --          (CPHA --> 0) (Slave specific)
  //       1  SPI Clock Rate Select 1 -- }        (SPR1 --> 0)
  //       0  SPI Clock Rate Select 0 -- } fOSC/4 (SPR0 --> 0) ("Fastest" but see SPI2X in SPSR)
  SPCR = (1<<SPE)| (1<<MSTR);
  // Clear previous data and status (TODO: Determine if necessary/better way.)
  // (Based on Playground SPI example.)
  byte dummy;
  dummy = SPSR;
  dummy = SPDR;
  delay(10);
  // Serial.println((1 << SPIF), BIN);
# define SLAVE_ADDRESS_BASE    (B01000 << 3)
# define SLAVE_ADDRESS_BIT_A1  (0 << 2)  // TODO: Allow non-zero and define constants
# define SLAVE_ADDRESS_BIT_A0  (0 << 1)  // TODO: Allow non-zero and define constants
# define SLAVE_ADDRESS         (SLAVE_ADDRESS_BASE|SLAVE_ADDRESS_BIT_A1|SLAVE_ADDRESS_BIT_A0)
# define CONTROL_BIT_READ 1
# define CONTROL_BIT_WRITE 0
# define REG_IODIR 0x00
# define REG_IOPOL 0x01
# define REG_GPIO 0x09
//  byte deviceOpcode = 0;
  //TODO: Reset slave?
  deviceOpcodeRead = (SLAVE_ADDRESS | CONTROL_BIT_READ);
  deviceOpcodeWrite = (SLAVE_ADDRESS | CONTROL_BIT_WRITE);
  Serial.print("Device opcode (read): ");
  Serial.println(deviceOpcodeRead, BIN);
  Serial.print("Device opcode (write): ");
  Serial.println(deviceOpcodeWrite, BIN);
  digitalWrite(PIN_SLAVE_SELECT, LOW); // Enable slave
  spi_transfer(deviceOpcode);
  // spi_transfer(REG_IODIR);  // The register we want to read
  // spi_transfer(REG_IOPOL);  // The register we want to read
  spi_transfer(REG_GPIO);  // The register we want to read
  // int data; // Correct type?
  byte data; // Correct type?
  //unsigned long data; // Correct type?
  data = spi_transfer(0xFF); // Transfer dummy byte to get response
  byte iodirVal = 0;
  Serial.print("IODIR response: ");
  iodirVal = getRegister(deviceOpcodeRead, REG_IODIR);
  Serial.println(iodirVal, BIN);
  byte newVal = 0;
  // newVal = iodirVal & B01111111;
  // newVal = B01111111;
  newVal = B00001111;
  Serial.print("newVal: ");
  Serial.println(newVal, BIN);
  setRegister(deviceOpcodeWrite, REG_IODIR, newVal);
  //setRegister(deviceOpcodeWrite, REG_GPIO, B10000000); // on
  //setRegister(deviceOpcodeWrite, REG_GPIO, B00000000); // off
  setRegister(deviceOpcodeWrite, REG_GPIO, pinState);
  Serial.print("Initial GPIO response: ");
  Serial.println(getRegister(deviceOpcodeRead, REG_GPIO), BIN);
  Serial.println("Setup exit...");
  clk = millis();
byte getRegister(byte targetDeviceOpcode, byte registerAddress) {
  spi_transfer(targetDeviceOpcode);
  spi_transfer(registerAddress);  // The register we want to read
  return data;
void setRegister(byte targetDeviceOpcode, byte registerAddress, byte value) {
  // TODO: Do Better?
  spi_transfer(registerAddress);  // The register we want to write
  spi_transfer(value);
// From Playground
char spi_transfer(volatile char data)
  SPDR = data;                    // Start the transmission
  while (!(SPSR & (1<<SPIF)))     // Wait for the end of the transmission
  return SPDR;                    // return the received byte
byte buttonState = 0;
  if (pinState && ((millis() - clk) > 750)) {
    // pinState = B00000000;
    pinState = (pinState >> 1) & B11110000;
    clk = millis() - 500;
  // Serial.println(getRegister(deviceOpcodeRead, REG_GPIO), BIN);
  buttonState = (getRegister(deviceOpcodeRead, REG_GPIO) & B00000001);
  // Serial.println(buttonState, BIN);
  //if (buttonState && !pinState) { // TODO: mask off pin(s) we're interested in & do better.
  if (buttonState) {
    // pinState = B10000000;
    // pinState = B11110000; // Note: You need to set as outputs remember!
    if (!(pinState & B10000000)) { // Compare to top-most output bit
      pinState = (pinState << 1) | B00010000; // Add bottom-most output bit
    delay(75);
    clk = millis();
  else if (!buttonState && pinState) {
  delay(50);
If you just want to have in on another pin, you have to change the definition
to another value. But in the title you're asking for multiple slaves. In this case you have to take care that only one of the slave select pins are LOW at any moment.
if i write my code as for one slave
digitalWrite(10, LOW);
    data = highByte(outputValue);
    data = 0b00001111 & data;
    data = 0b00110000 | data;
    SPI.transfer(data);
    data = lowByte(outputValue);
    SPI.transfer(data);
    digitalWrite(10, HIGH);
can i change it as for two slaves
digitalWrite(9, LOW);
    SPI.transfer(data);
    SPI.transfer(data);
    digitalWrite(9, HIGH);
    SPI.transfer(data);
    SPI.transfer(data);
Yes, you can. It might be more appropriate to put that into a subroutine where the SS pin is a parameter but doesn't change the message.
You have two groups of # defines - those all need to be at the top of the sketch.
Plus you have this line
that is not part of void setup, void loop, or any function. probably want to move it prior to void setup with the other function declarations.
i did change my code to
#define PIN_SLAVE_SELECT 9 // SS
but i didnt get my output response i.e LEDs Glowing
when i change back my ccode to
i am getting my output as required...
why cant i use pin 9 for slave select...
i am using arduino uno.
Probably because the chips SS signal is connected the Arduino's pin 10 and not pin 9.
Remember we know nothing about your setup, how you wired things, etc.etc. Don't expect us to solve your problems if you don't provide the information we need to do that. Best to start with is probably to take a photo of your setup so that we can see the whole cabling.
Then post links to all hardware components you used.
You also have to set up pin 10 as an output whether you use it or not. Lets the Arduino be the SPI master.
ya arduino is the master
i connected spi expander to pin 10 it worked fine
but when i connect to pin 9 it doesnot seem to work..
do i need to change libraries?
When you connect to 9, do you have
pinMode(10, OUTPUT);
included in the file?
