Have a little bit better solution.
I changed three files:
In "~/.arduino15/packages/arduino/hardware/mbed_giga/4.2.1/libraries/SPI" folder changes were made to SPI.cpp:
SPI.cpp - wrapper over mbed SPI class
Part of Arduino - http://www.arduino.cc/
Copyright (c) 2018-2019 Arduino SA
This library is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General
Public License along with this library; if not, write to the
Free Software Foundation, Inc., 59 Temple Place, Suite 330,
Boston, MA 02111-1307 USA
#include "SPI.h"
#include "pinDefinitions.h"
#if !defined(ARDUINO_AS_MBED_LIBRARY)
#include "drivers/SPIMaster.h"
#else
#include "drivers/SPI.h"
#endif
struct _mbed_spi {
mbed::SPI* obj;
arduino::MbedSPI::MbedSPI(int miso, int mosi, int sck) :
_miso(digitalPinToPinName(miso)), _mosi(digitalPinToPinName(mosi)), _sck(digitalPinToPinName(sck)) {
arduino::MbedSPI::MbedSPI(PinName miso, PinName mosi, PinName sck) : _miso(miso), _mosi(mosi), _sck(sck) {
uint8_t arduino::MbedSPI::transfer(uint8_t data) {
uint8_t ret;
dev->obj->write((const char*)&data, 1, (char*)&ret, 1);
return ret;
uint16_t arduino::MbedSPI::transfer16(uint16_t data) {
union { uint16_t val; struct { uint8_t lsb; uint8_t msb; }; } t;
t.val = data;
if (settings.getBitOrder() == LSBFIRST) {
t.lsb = transfer(t.lsb);
t.msb = transfer(t.msb);
return t.val;
void arduino::MbedSPI::transfer(void *buf, size_t count) {
dev->obj->write((const char*)buf, count, (char*)buf, count);
// Added: 12-07-24 wwatson
void arduino::MbedSPI::transfer(void *txbuf, void *rxbuf, size_t count) {
if(rxbuf == nullptr) {
dev->obj->write((const char*)txbuf, count, (char*)rxbuf, -1);
dev->obj->write((const char*)txbuf, count, (char*)rxbuf, count);
void arduino::MbedSPI::transfer(void *txbuf, size_t tx_count, void *rxbuf, size_t rx_count) {
dev->obj->write((const char*)txbuf, tx_count, (char*)rxbuf, rx_count);
void arduino::MbedSPI::usingInterrupt(int interruptNumber) {
void arduino::MbedSPI::notUsingInterrupt(int interruptNumber) {
void arduino::MbedSPI::beginTransaction(SPISettings settings) {
if (settings != this->settings) {
dev->obj->format(8, settings.getDataMode());
dev->obj->frequency(settings.getClockFreq());
this->settings = settings;
void arduino::MbedSPI::endTransaction(void) {
// spinlock until transmission is over (if using ASYNC transfer)
void arduino::MbedSPI::attachInterrupt() {
void arduino::MbedSPI::detachInterrupt() {
void arduino::MbedSPI::begin() {
if (dev == NULL) {
dev = new mbed_spi;
dev->obj = NULL;
if (dev->obj == NULL) {
dev->obj = new mbed::SPI(_mosi, _miso, _sck);
void arduino::MbedSPI::end() {
if (dev != NULL && dev->obj != NULL) {
delete dev->obj;
delete dev;
dev = NULL;
#if SPI_HOWMANY > 0
arduino::MbedSPI SPI(SPI_MISO, SPI_MOSI, SPI_SCK);
#endif
#if SPI_HOWMANY > 1
arduino::MbedSPI SPI1(SPI_MISO1, SPI_MOSI1, SPI_SCK1);
#endif
#endif
And in SPI.h:
Copyright (c) 2016 Arduino LLC. All right reserved.
See the GNU Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
#pragma once
#include "Arduino.h"
#include "api/HardwareSPI.h"
typedef struct _mbed_spi mbed_spi;
namespace arduino {
class MbedSPI : public SPIClass
public:
MbedSPI(int miso, int mosi, int sck);
MbedSPI(PinName miso, PinName mosi, PinName sck);
virtual uint8_t transfer(uint8_t data);
virtual uint16_t transfer16(uint16_t data);
virtual void transfer(void *buf, size_t count);
virtual void transfer(void *txbuf, void *rxbuf, size_t count);
virtual void transfer(void *txbuf, size_t tx_count, void *rxbuf, size_t rx_count);
// Transaction Functions
virtual void usingInterrupt(int interruptNumber);
virtual void notUsingInterrupt(int interruptNumber);
virtual void beginTransaction(SPISettings settings);
virtual void endTransaction(void);
// SPI Configuration methods
virtual void attachInterrupt();
virtual void detachInterrupt();
virtual void begin();
virtual void end();
private:
SPISettings settings = SPISettings(0, MSBFIRST, SPI_MODE0);
_mbed_spi* dev = NULL;
PinName _miso;
PinName _mosi;
PinName _sck;
#if SPI_HOWMANY > 0
extern arduino::MbedSPI SPI;
#endif
#if SPI_HOWMANY > 1
#ifdef SPI1
#undef SPI1
#endif
extern arduino::MbedSPI SPI1;
#endif
#endif
And finally in: "~/.arduino15/packages/arduino/hardware/mbed_giga/4.2.1/cores/arduino/api"
Changes were needed in HardwareSPI.h:
HardwareSPI.h - Hardware SPI interface for Arduino
Copyright (c) 2018 Arduino LLC. All right reserved.
#pragma once
#include "Common.h"
#include <inttypes.h>
#include "Stream.h"
#define SPI_HAS_TRANSACTION
namespace arduino {
typedef enum {
SPI_MODE0 = 0,
SPI_MODE1 = 1,
SPI_MODE2 = 2,
SPI_MODE3 = 3,
} SPIMode;
class SPISettings {
public:
SPISettings(uint32_t clock, BitOrder bitOrder, SPIMode dataMode) {
if (__builtin_constant_p(clock)) {
init_AlwaysInline(clock, bitOrder, dataMode);
init_MightInline(clock, bitOrder, dataMode);
SPISettings(uint32_t clock, BitOrder bitOrder, int dataMode) {
init_AlwaysInline(clock, bitOrder, (SPIMode)dataMode);
init_MightInline(clock, bitOrder, (SPIMode)dataMode);
// Default speed set to 4MHz, SPI mode set to MODE 0 and Bit order set to MSB first.
SPISettings() { init_AlwaysInline(4000000, MSBFIRST, SPI_MODE0); }
bool operator==(const SPISettings& rhs) const
if ((this->clockFreq == rhs.clockFreq) &&
(this->bitOrder == rhs.bitOrder) &&
(this->dataMode == rhs.dataMode)) {
return true;
return false;
bool operator!=(const SPISettings& rhs) const
return !(*this == rhs);
uint32_t getClockFreq() const {
return clockFreq;
SPIMode getDataMode() const {
return dataMode;
BitOrder getBitOrder() const {
return (bitOrder);
private:
void init_MightInline(uint32_t clock, BitOrder bitOrder, SPIMode dataMode) {
// Core developer MUST use an helper function in beginTransaction() to use this data
void init_AlwaysInline(uint32_t clock, BitOrder bitOrder, SPIMode dataMode) __attribute__((__always_inline__)) {
this->clockFreq = clock;
this->dataMode = dataMode;
this->bitOrder = bitOrder;
uint32_t clockFreq;
SPIMode dataMode;
BitOrder bitOrder;
friend class HardwareSPI;
const SPISettings DEFAULT_SPI_SETTINGS = SPISettings();
class HardwareSPI
public:
virtual ~HardwareSPI() { }
virtual uint8_t transfer(uint8_t data) = 0;
virtual uint16_t transfer16(uint16_t data) = 0;
virtual void transfer(void *buf, size_t count) = 0;
virtual void transfer(void *txbuf, void *rxbuf, size_t count) = 0;
virtual void transfer(void *txbuf, size_t tx_count, void *rxbuf, size_t rx_count) = 0;
virtual void usingInterrupt(int interruptNumber) = 0;
virtual void notUsingInterrupt(int interruptNumber) = 0;
virtual void beginTransaction(SPISettings settings) = 0;
virtual void endTransaction(void) = 0;
virtual void attachInterrupt() = 0;
virtual void detachInterrupt() = 0;
virtual void begin() = 0;
virtual void end() = 0;
// Alias SPIClass to HardwareSPI since it's already the defacto standard for SPI class name
typedef HardwareSPI SPIClass;
In all three files I marked where I made the additions. Two methods were added:
In the first one a tx and rx buffer can be used. The buffer length count is the same for both buffers.
If you just want to use the tx buffer the set the rx buffer as "NULL". This sets the rx count to -1 which
disables the receive portion of the low level code.
The second method is almost the same except two different size buffers can be used for tx and rx. Again
setting rx count to -1 disables rx buffer reception.
This is pretty much a hack to get away from crashing the GIGA by accidentally using a constant type buffer
on the rx side. As such, every time you update Mbed-OS you would need to reinstall the three files again...
EDIT:
Or maybe this:
int txonly = count;
if(rxbuf == nullptr) txonly = -1;
dev->obj->write((const char*)txbuf, count, (char*)rxbuf, txonly);
instead...
EDIT: Or an example of how to properly use "SPI_DIRECTION_2LINES_TXONLY"?
