nankie
August 13, 2022, 3:12pm
1
Recently I bought a led matrix display controlled by MAX7219.
When I opened a sketch of the parola library I get an error:
SPIClass has not been declared.
Sketch name is: Parola_print_test.
I tested Parola_scrolling, with the same result.
In the MD_Parola.h file this line has an error:
MD_Parola(MD_MAX72XX::moduleType_t mod, SPIClass &spi, uint8_t csPin, uint8_t numDevices = 1):
Does anybody know what to do?
Post the exact code that you uploaded. Read the forum guidelines to see how to properly post code and some good information on making a good post.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
Please include the entire error message. It is easy to do. There is a button (lower right of the IDE window) called "copy error message". Copy the error and paste into a post in code tags. Paraphrasing the error message leaves out important information.
What Arduino board are you using?
b707
August 13, 2022, 6:32pm
4
what arduino board are you using?
Most likely... but pretty hard to help because you forgot to post your code.
nankie
August 14, 2022, 2:13pm
7
Yes.
The program is an example of parola library
See program:
#include <MD_Parola.h>
#include <MD_MAX72xx.h>
#include <SPI.h>
// set to 1 if we are implementing the user interface pot, switch, etc
#define USE_UI_CONTROL 0
#if USE_UI_CONTROL
#include <MD_UISwitch.h>
#endif
// Turn on debug statements to the serial output
#define DEBUG 0
#if DEBUG
#define PRINT(s, x) { Serial.print(F(s)); Serial.print(x); }
#define PRINTS(x) Serial.print(F(x))
#define PRINTX(x) Serial.println(x, HEX)
#else
#define PRINT(s, x)
#define PRINTS(x)
#define PRINTX(x)
#endif
// Define the number of devices we have in the chain and the hardware interface
// NOTE: These pin numbers will probably not work with your hardware and may
// need to be adapted
#define HARDWARE_TYPE MD_MAX72XX::FC16_HW
#define MAX_DEVICES 4
#define CLK_PIN 13
#define DATA_PIN 11
#define CS_PIN 10
// HARDWARE SPI
MD_Parola P = MD_Parola(HARDWARE_TYPE, CS_PIN, MAX_DEVICES);
// SOFTWARE SPI
//MD_Parola P = MD_Parola(HARDWARE_TYPE, DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES);
// Scrolling parameters
#if USE_UI_CONTROL
const uint8_t SPEED_IN = A5;
const uint8_t DIRECTION_SET = 8; // change the effect
const uint8_t INVERT_SET = 9; // change the invert
const uint8_t SPEED_DEADBAND = 5;
#endif // USE_UI_CONTROL
uint8_t scrollSpeed = 25; // default frame delay value
textEffect_t scrollEffect = PA_SCROLL_LEFT;
textPosition_t scrollAlign = PA_LEFT;
uint16_t scrollPause = 2000; // in milliseconds
// Global message buffers shared by Serial and Scrolling functions
#define BUF_SIZE 75
char curMessage[BUF_SIZE] = { "" };
char newMessage[BUF_SIZE] = { "Hello! Enter new message?" };
bool newMessageAvailable = true;
#if USE_UI_CONTROL
MD_UISwitch_Digital uiDirection(DIRECTION_SET);
MD_UISwitch_Digital uiInvert(INVERT_SET);
void doUI(void)
// set the speed if it has changed
int16_t speed = map(analogRead(SPEED_IN), 0, 1023, 10, 150);
if ((speed >= ((int16_t)P.getSpeed() + SPEED_DEADBAND)) ||
(speed <= ((int16_t)P.getSpeed() - SPEED_DEADBAND)))
P.setSpeed(speed);
scrollSpeed = speed;
PRINT("\nChanged speed to ", P.getSpeed());
if (uiDirection.read() == MD_UISwitch::KEY_PRESS) // SCROLL DIRECTION
PRINTS("\nChanging scroll direction");
scrollEffect = (scrollEffect == PA_SCROLL_LEFT ? PA_SCROLL_RIGHT : PA_SCROLL_LEFT);
P.setTextEffect(scrollEffect, scrollEffect);
P.displayClear();
P.displayReset();
if (uiInvert.read() == MD_UISwitch::KEY_PRESS) // INVERT MODE
PRINTS("\nChanging invert mode");
P.setInvert(!P.getInvert());
void readSerial(void)
static char *cp = newMessage;
while (Serial.available())
*cp = (char)Serial.read();
if ((*cp == '\n') || (cp - newMessage >= BUF_SIZE-2)) // end of message character or full buffer
*cp = '\0'; // end the string
// restart the index for next filling spree and flag we have a message waiting
cp = newMessage;
else // move char pointer to next position
cp++;
Serial.begin(57600);
Serial.print("\n[Parola Scrolling Display]\nType a message for the scrolling display\nEnd message line with a newline");
#if USE_UI_CONTROL
uiDirection.begin();
uiInvert.begin();
pinMode(SPEED_IN, INPUT);
doUI();
P.begin();
P.displayText(curMessage, scrollAlign, scrollSpeed, scrollPause, scrollEffect, scrollEffect);
#if USE_UI_CONTROL
doUI();
if (P.displayAnimate())
if (newMessageAvailable)
strcpy(curMessage, newMessage);
newMessageAvailable = false;
P.displayReset();
readSerial();
Did you ignore the request to post code properly on purpose? Please re-read post #2 . Not posting in code tags makes it more difficult to help you. You can go back and fix your original post by highlighting the code and clicking the </> in the menu bar.
Your posted code was a PITA to copy into my IDE (version 1.8.19), but I did copy it and it compiles with no errors for my Uno.
What IDE version are you using?
Are you sure that the posted code is the code that generated the error?
nankie
August 14, 2022, 10:08pm
10
I am using IDE 1.8.19
Yes, the code which I posted is the same.
It is an example of the parola library. Its name is Parola_scrolling.
I tried it, and it keeps giving the error: SPIClass has not been declared
Thank you for fixing your original post by putting the code in code tags. It is so much easier to copy to my IDE. Unfortunately the code is incomplete. It is, at least, missing a closing } at the end of the code.
If I add a } to close the code it compiles for me with no errors. This leads me to wonder if your IDE installation can be flawed. Have you compiled other code using the IDE?
nankie
August 15, 2022, 1:04pm
12
You are right, It was missing a closing }. I am using the IDE for several other sketches without problems. I loaded this example from the parola library (Parola_scrolling) and it gives the same error. See code :
Arduino:1.8.19 (Windows 10), Board:"Arduino Uno"
D:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware D:\Program Files (x86)\Arduino\hardware -hardware C:\Users\jgell\AppData\Local\Arduino15\packages -tools D:\Program Files (x86)\Arduino\tools-builder -tools D:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\jgell\AppData\Local\Arduino15\packages -built-in-libraries D:\Program Files (x86)\Arduino\libraries -libraries D:\Mijn documenten\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10819 -build-path C:\Users\jgell\AppData\Local\Temp\arduino_build_407610 -warnings=none -build-cache C:\Users\jgell\AppData\Local\Temp\arduino_cache_535886 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\jgell\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\jgell\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=C:\Users\jgell\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\jgell\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Users\jgell\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\jgell\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -verbose C:\Users\jgell\AppData\Local\Temp\arduino_modified_sketch_414680\Parola_Scrolling.ino
D:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware D:\Program Files (x86)\Arduino\hardware -hardware C:\Users\jgell\AppData\Local\Arduino15\packages -tools D:\Program Files (x86)\Arduino\tools-builder -tools D:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\jgell\AppData\Local\Arduino15\packages -built-in-libraries D:\Program Files (x86)\Arduino\libraries -libraries D:\Mijn documenten\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10819 -build-path C:\Users\jgell\AppData\Local\Temp\arduino_build_407610 -warnings=none -build-cache C:\Users\jgell\AppData\Local\Temp\arduino_cache_535886 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\jgell\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\jgell\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=C:\Users\jgell\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\jgell\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Users\jgell\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\jgell\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -verbose C:\Users\jgell\AppData\Local\Temp\arduino_modified_sketch_414680\Parola_Scrolling.ino
Using board 'uno' from platform in folder: C:\Users\jgell\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5
Using core 'arduino' from platform in folder: C:\Users\jgell\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5
Detecting libraries used...
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "C:\\Users\\jgell\\AppData\\Local\\Temp\\arduino_build_407610\\sketch\\Parola_Scrolling.ino.cpp" -o nul
Alternatives for MD_Parola.h: [MD_Parola-main@3.6.1]
ResolveLibrary(MD_Parola.h)
-> candidates: [MD_Parola-main@3.6.1]
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "C:\\Users\\jgell\\AppData\\Local\\Temp\\arduino_build_407610\\sketch\\Parola_Scrolling.ino.cpp" -o nul
Alternatives for MD_MAX72xx.h: [MD_MAX72XX@3.2.5]
ResolveLibrary(MD_MAX72xx.h)
-> candidates: [MD_MAX72XX@3.2.5]
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "C:\\Users\\jgell\\AppData\\Local\\Temp\\arduino_build_407610\\sketch\\Parola_Scrolling.ino.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "C:\\Users\\jgell\\AppData\\Local\\Temp\\arduino_build_407610\\sketch\\Parola_Scrolling.ino.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src\\MD_PZone.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src\\MD_Parola.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src\\MD_Parola_Blinds.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src\\MD_Parola_Close.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src\\MD_Parola_Diag.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src\\MD_Parola_Dissolve.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src\\MD_Parola_Fade.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src\\MD_Parola_Grow.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src\\MD_Parola_HScroll.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src\\MD_Parola_Mesh.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src\\MD_Parola_Open.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src\\MD_Parola_Print.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src\\MD_Parola_Random.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src\\MD_Parola_Scan.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src\\MD_Parola_Slice.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src\\MD_Parola_Sprite.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src\\MD_Parola_VScroll.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src\\MD_Parola_Wipe.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src\\MD_MAX72xx.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src\\MD_MAX72xx_buf.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src\\MD_MAX72xx_font.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src\\MD_MAX72xx_pix.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src\\SPI.cpp" -o nul
Generating function prototypes...
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "C:\\Users\\jgell\\AppData\\Local\\Temp\\arduino_build_407610\\sketch\\Parola_Scrolling.ino.cpp" -o "C:\\Users\\jgell\\AppData\\Local\\Temp\\arduino_build_407610\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"D:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\jgell\\AppData\\Local\\Temp\\arduino_build_407610\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Sketch aan het compileren...
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "C:\\Users\\jgell\\AppData\\Local\\Temp\\arduino_build_407610\\sketch\\Parola_Scrolling.ino.cpp" -o "C:\\Users\\jgell\\AppData\\Local\\Temp\\arduino_build_407610\\sketch\\Parola_Scrolling.ino.cpp.o"
In file included from C:\Users\jgell\AppData\Local\Temp\arduino_modified_sketch_414680\Parola_Scrolling.ino:16:0:
D:\Mijn documenten\Arduino\libraries\MD_Parola-main\src/MD_Parola.h:1239:44: error: 'SPIClass' has not been declared
Bibliotheek MD_Parola-main op versie 3.6.1 in map: D:\Mijn documenten\Arduino\libraries\MD_Parola-main wordt gebruikt
Bibliotheek MD_MAX72XX op versie 3.2.5 in map: D:\Mijn documenten\Arduino\libraries\MD_MAX72XX wordt gebruikt
Bibliotheek SPI op versie 1.0 in map: C:\Users\jgell\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI wordt gebruikt
exit status 1
Fout bij het compileren voor board Arduino Uno
At this point my best suggestion is to delete the MD_Parola library from your sketchbook/libraries folder and re-install the MD_Parola library using the IDE library manager.
nankie
August 15, 2022, 9:45pm
14
I removed the parola library and the zip-file, and downloaded it again. Then I reinstalled the IDE, and reinstalled the parola library, but with the same result: SPIClas has not been declared.
As you can see at the top of the sketch, there are three lines: #include
#include <SPI.h>
When I grey out the last one: like this: //#include <SPI.h>,
the error is the same: SPIClass not declared.
When I put the <SPI.h> line as the first one, then there are 4 complete different errors, but no SPIClass error.
Very strange.
What are those errors?
Yes, it is a mystery to me, too. I have compiled that code several times. It always compiles fine.
Is your board an Uno R3 with the DIP mega328 chip, or a clone Uno R3 with the surface mount mega328? It is not, by chance, one of those Uno WiFi is it?
How about some photos of your setup and wiring?
nankie
August 16, 2022, 9:50am
16
I am using an arduino UNO : See photo
The 4 different errors are when I placed the <SPI.h> as first line:
D:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware D:\Program Files (x86)\Arduino\hardware -hardware C:\Users\jgell\AppData\Local\Arduino15\packages -tools D:\Program Files (x86)\Arduino\tools-builder -tools D:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\jgell\AppData\Local\Arduino15\packages -built-in-libraries D:\Program Files (x86)\Arduino\libraries -libraries D:\Mijn documenten\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=2341_0043 -ide-version=10819 -build-path C:\Users\jgell\AppData\Local\Temp\arduino_build_332906 -warnings=none -build-cache C:\Users\jgell\AppData\Local\Temp\arduino_cache_753676 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\jgell\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\jgell\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avrdude.path=C:\Users\jgell\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\jgell\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Users\jgell\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\jgell\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -verbose C:\Users\jgell\AppData\Local\Temp\arduino_modified_sketch_255319\Parola_Scrolling.ino
D:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware D:\Program Files (x86)\Arduino\hardware -hardware C:\Users\jgell\AppData\Local\Arduino15\packages -tools D:\Program Files (x86)\Arduino\tools-builder -tools D:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\jgell\AppData\Local\Arduino15\packages -built-in-libraries D:\Program Files (x86)\Arduino\libraries -libraries D:\Mijn documenten\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=2341_0043 -ide-version=10819 -build-path C:\Users\jgell\AppData\Local\Temp\arduino_build_332906 -warnings=none -build-cache C:\Users\jgell\AppData\Local\Temp\arduino_cache_753676 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\jgell\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\jgell\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avrdude.path=C:\Users\jgell\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\jgell\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Users\jgell\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\jgell\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -verbose C:\Users\jgell\AppData\Local\Temp\arduino_modified_sketch_255319\Parola_Scrolling.ino
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "C:\\Users\\jgell\\AppData\\Local\\Temp\\arduino_build_332906\\sketch\\Parola_Scrolling.ino.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "C:\\Users\\jgell\\AppData\\Local\\Temp\\arduino_build_332906\\sketch\\Parola_Scrolling.ino.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "C:\\Users\\jgell\\AppData\\Local\\Temp\\arduino_build_332906\\sketch\\Parola_Scrolling.ino.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "C:\\Users\\jgell\\AppData\\Local\\Temp\\arduino_build_332906\\sketch\\Parola_Scrolling.ino.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src\\SPI.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src\\MD_PZone.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src\\MD_Parola.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src\\MD_Parola_Blinds.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src\\MD_Parola_Close.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src\\MD_Parola_Diag.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src\\MD_Parola_Dissolve.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src\\MD_Parola_Fade.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src\\MD_Parola_Grow.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src\\MD_Parola_HScroll.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src\\MD_Parola_Mesh.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src\\MD_Parola_Open.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src\\MD_Parola_Print.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src\\MD_Parola_Random.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src\\MD_Parola_Scan.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src\\MD_Parola_Slice.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src\\MD_Parola_Sprite.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src\\MD_Parola_VScroll.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src\\MD_Parola_Wipe.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src\\MD_MAX72xx.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src\\MD_MAX72xx_buf.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src\\MD_MAX72xx_font.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "D:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src\\MD_MAX72xx_pix.cpp" -o nul
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "C:\\Users\\jgell\\AppData\\Local\\Temp\\arduino_build_332906\\sketch\\Parola_Scrolling.ino.cpp" -o "C:\\Users\\jgell\\AppData\\Local\\Temp\\arduino_build_332906\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\builtin\\tools\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\jgell\\AppData\\Local\\Temp\\arduino_build_332906\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\jgell\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_Parola-main\\src" "-ID:\\Mijn documenten\\Arduino\\libraries\\MD_MAX72XX\\src" "C:\\Users\\jgell\\AppData\\Local\\Temp\\arduino_build_332906\\sketch\\Parola_Scrolling.ino.cpp" -o "C:\\Users\\jgell\\AppData\\Local\\Temp\\arduino_build_332906\\sketch\\Parola_Scrolling.ino.cpp.o"
In file included from C:\Users\jgell\AppData\Local\Temp\arduino_modified_sketch_255319\Parola_Scrolling.ino:16:0:
D:\Mijn documenten\Arduino\libraries\MD_Parola-main\src/MD_Parola.h: In constructor 'MD_Parola::MD_Parola(MD_MAX72XX::moduleType_t, SPIClass&, uint8_t, uint8_t)':
D:\Mijn documenten\Arduino\libraries\MD_Parola-main\src/MD_Parola.h:1238:60: error: no matching function for call to 'MD_MAX72XX::MD_MAX72XX(MD_MAX72XX::moduleType_t&, SPIClass&, uint8_t&, uint8_t&)'
_D(mod, spi, csPin, numDevices), _numModules(numDevices)
In file included from D:\Mijn documenten\Arduino\libraries\MD_Parola-main\src/MD_Parola.h:443:0,
D:\Mijn documenten\Arduino\libraries\MD_MAX72XX\src/MD_MAX72xx.h:432:3: note: candidate: MD_MAX72XX::MD_MAX72XX(MD_MAX72XX::moduleType_t, uint8_t, uint8_t)
MD_MAX72XX(moduleType_t mod, uint8_t csPin, uint8_t numDevices=1);
D:\Mijn documenten\Arduino\libraries\MD_MAX72XX\src/MD_MAX72xx.h:432:3: note: candidate expects 3 arguments, 4 provided
D:\Mijn documenten\Arduino\libraries\MD_MAX72XX\src/MD_MAX72xx.h:415:3: note: candidate: MD_MAX72XX::MD_MAX72XX(MD_MAX72XX::moduleType_t, uint8_t, uint8_t, uint8_t, uint8_t)
MD_MAX72XX(moduleType_t mod, uint8_t dataPin, uint8_t clkPin, uint8_t csPin, uint8_t numDevices=1);
D:\Mijn documenten\Arduino\libraries\MD_MAX72XX\src/MD_MAX72xx.h:415:3: note: no known conversion for argument 2 from 'SPIClass' to 'uint8_t {aka unsigned char}'
D:\Mijn documenten\Arduino\libraries\MD_MAX72XX\src/MD_MAX72xx.h:315:7: note: candidate: constexpr MD_MAX72XX::MD_MAX72XX(const MD_MAX72XX&)
class MD_MAX72XX
D:\Mijn documenten\Arduino\libraries\MD_MAX72XX\src/MD_MAX72xx.h:315:7: note: candidate expects 1 argument, 4 provided
exit status 1
nankie
August 16, 2022, 10:00pm
17
I deleted the parola library again and I found an older version on this page:
https://www.arduinolibraries.info/libraries/md_parola
Now I downloaded version 3.5, and now the problem of the SPIClass is solved.
Also I tried to put the <SPI.h> as first line, but it also compiled with NO errors.
