Hello,
Im trying to interface with the Adafruit Metro M0 Express’s builtin SPI Flash chip. I looked into Adafruits SPIFlash library, but it forces me to use my SPI flashchip as a SD card(fafts). I dont want to do this. All I would like to do is write a single byte to a address,then read it. But it seems im misunderstanding something. Code is posted below.
According to Adafruit FLASH SPI PINS are:
MISO = 36
MOSI = 37
SCK = 38
CS = 39
And looking at datasheet of SAMD21, these use SERCOM5 with the respected PAD associated to them.
I believe I setup my SPIClass correctly,and have the correct commands I need to send to the flash chip(write/read/erase chip commands).Says write command is (0x06) and read command is (0x03) and erase chip is (0x60). It compiles,but doesnt send my data = 20 to address 0…
Links to datasheets with pages:
https://www.cypress.com/file/196886/download FLASH CHIP DATASHEET(page 63 is the command list)
SAMD21 Datasheet(go to page 23): https://cdn.sparkfun.com/assets/6/3/d/d/2/Atmel-42181-SAM-D21_Datasheet.pdf
Adafruit Metro M0 Express Overview: Overview | Adafruit Metro M0 Express - Designed for CircuitPython | Adafruit Learning System
Code:
#include <SPI.h>
#include "wiring_private.h" // pinPeripheral() function
// FLASH SCK pin is #38, MISO is #36, MOSI is #37, and CS is #39
// SPIClass SPI (&PERIPH_SPI, PIN_SPI_MISO, PIN_SPI_SCK, PIN_SPI_MOSI, PAD_SPI_TX, PAD_SPI_RX);
SPIClass mySPI (&sercom5, 36, 38, 37, SPI_PAD_2_SCK_3, SERCOM_RX_PAD_1);
#define CSPIN 39
uint32_t addr = 0;
uint8_t data = 20;
uint8_t datasent;
void setup(void) {
delay(4000);
Serial.begin(250000);
mySPI.begin();
pinPeripheral(37, PIO_SERCOM);// Assign MOSI
pinPeripheral(38, PIO_SERCOM); // Assign SCK
pinPeripheral(36, PIO_SERCOM);// Assign MISO
// Assign CS
pinMode(CSPIN, OUTPUT);
digitalWrite(CSPIN, HIGH);
mySPI.beginTransaction(SPISettings(20000000, MSBFIRST, SPI_MODE0));
//chip erase
digitalWrite(CSPIN, LOW);
mySPI.transfer(0x06);//write enable on
mySPI.transfer(0x60);//erase command
void loop(void) {
//write byte to address
addr = mySPI.transfer(0x00); //address
datasent = mySPI.transfer(data); //data to send
Serial.println(" addr=");
Serial.println(addr);
Serial.println("datasent =");
Serial.println( datasent);
//read byte at address
mySPI.transfer(0x03);//read command
mySPI.transfer(addr);//address
// send a value of 0 to read the first byte returned:
uint8_t result = mySPI.transfer(0x00);
Serial.println(" result = ");
Serial.println(result);
Any advice would be great, if theres a better way, or if im going about this all wrong.
