I have two Nodemcu/DHT22 sender units in different rooms and each send to a central Nodemcu Receiving unit using espnow. I then created a web server on the Receiving unit that successfully creates a real time graph using SPIFFS (https://randomnerdtutorials.com/esp32-esp8266-plot-chart-web-server/). I wanted to change the real time graphs to Google Gauges and have changed the html file. The html file should be receiving the temperature data (Did not change the sketch) but Google Gauge does not recognize the incoming temperature data. Could anyone please make a suggestion about how to change the html so that Google Gauge can display the temperature data. Thanks.
Arduino Sketch
#include <Arduino.h>
#include <ESP8266WiFi.h>
#include <Hash.h>
#include <ESPAsyncTCP.h>
#include <ESPAsyncWebServer.h>
#include <FS.h>
#include <espnow.h>
//Define global variables
float Room1temp;
float Room2temp;
float Tempearture;
//Connection info to Internet Router
const char* ssid = "TG1672G42";
const char* password = "TG1672GD98242";
// declare an object of WebServer library
AsyncWebServer server(80);
//Create structure for incoming Room emp data
typedef struct struct_message {
int id;
float temp;
} struc_message;
// Create a struct_message to hold incoming Room sensor readings
struc_message myData;
// Create a structure to hold the readings from each board
struct_message board1;
struct_message board2;
// Create an array with all the structures
struct_message boardsStruct[2] = {board1, board2};
// Callback function that will be executed when data is received
void OnDataRecv(uint8_t * mac_addr, uint8_t *incomingData, uint8_t len) {
char macStr[18];
Serial.print("Packet received from: ");
snprintf(macStr, sizeof(macStr), "%02x:%02x:%02x:%02x:%02x:%02x",
mac_addr[0], mac_addr[1], mac_addr[2], mac_addr[3], mac_addr[4], mac_addr[5]);
Serial.println(macStr);
memcpy(&myData, incomingData, sizeof(myData));
Tempearture = myData.temp;
Serial.printf("Board ID %u: %u bytes\n", myData.id, len);
// Update the structures with the new incoming data
boardsStruct[myData.id - 1].temp = myData.temp;
//Retrive temp from Room 1 and assign as string
String readRoom1temp() {
Serial.println("Read Room 1 Temp");
float Room1temp = boardsStruct[0].temp;
Serial.println(Room1temp);
return String(Room1temp);
//Retrive temp from Room 2 and assign as string
String readRoom2temp() {
Serial.println("Read Room 2 Temp");
float Room2temp = boardsStruct[1].temp;
Serial.println(Room2temp);
return String(Room2temp);
//Initialize Serial Monitor
delay(100);
// Initialize SPIFFS
if (!SPIFFS.begin()) {
Serial.println("An Error has occurred while mounting SPIFFS");
return;
//connect to your local wi-fi network
WiFi.begin(ssid, password);
//check wi-fi is connected to wi-fi network
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected..!");
Serial.print("Got IP: "); Serial.println(WiFi.localIP());
//Set device as a Wi-Fi Station
//WiFi.mode(WIFI_STA);
//Init ESP-NOW
if (esp_now_init() != 0) {
Serial.println("Error initializing ESP-NOW");
return;
// Once ESPNow is successfully Init, we will register for recv CB to get recv packer info
esp_now_register_recv_cb(OnDataRecv);
// Route for root / web page
Serial.println("Initialize SPIFFS");
server.on("/", HTTP_GET, [](AsyncWebServerRequest * request) {
request->send(SPIFFS, "/index.html");
Serial.println("Send Room 1 Temp");
server.on("/Room1temp", HTTP_GET, [](AsyncWebServerRequest * request) {
request->send_P(200, "text/plain", readRoom1temp().c_str());
Serial.println("Send Room 2 Temp");
server.on("/Room2temp", HTTP_GET, [](AsyncWebServerRequest * request) {
request->send_P(200, "text/plain", readRoom2temp().c_str());
// Start server
server.begin();
///Access the variables for each board and print
Serial.print("Room 1 temperature: ");
Serial.print(Room1temp);
Serial.print("Room 2 temperature: ");
Serial.print(Room2temp);
delay(10000);
HTML
<!DOCTYPE html>
<html>
<head>
<script type="text/javascript" src="https://www.gstatic.com/charts/loader.js"></script>
<script type="text/javascript">
google.charts.load('current', {'packages':['gauge']});
google.charts.setOnLoadCallback(drawGauge);
var gaugeOptions = {min: 0, max: 280, yellowFrom: 200, yellowTo: 250,
redFrom: 250, redTo: 280, minorTicks: 5};
var gauge;
// Obtain SPIFF Temperature Data
setInterval(function ( ) {
var xhttp = new XMLHttpRequest();
xhttp.onreadystatechange = function() {
if (this.readyState == 4 && this.status == 200) {
var Room1temp = parseFloat(this.responseText);
xhttp.open("GET", "/Room1temp", true);
xhttp.send();
}, 10000 ) ;
var Room2temp = parseFloat(this.responseText);
xhttp.open("GET", "/Room2temp", true);
xhttp.send();
}, 10000 ) ;
//Draw Google Gage
function drawGauge() {
gaugeData = new google.visualization.DataTable();
gaugeData.addColumn('number', 'Room 1 Temp');
gaugeData.addColumn('number', 'Room 2 Temp');
gaugeData.addRows(2);
gaugeData.setCell(0, 0, Room1temp);
gaugeData.setCell(0, 1, Room2temp);
gauge = new google.visualization.Gauge(document.getElementById('gauge_div'));
gauge.draw(gaugeData, gaugeOptions);
</script>
</head>
<body>
<div id="gauge_div" style="width:280px; height: 140px;"></div>
<body>
</html>
