I've been using an SD card for logging and had a lot of problems. I've just descovered SPIFFS and I think that this may be the answer to all my prayers.
There are of course some memory size issues. I don’t have the 2GB of the SD. Although, I have never used much memory capacity of the SD because it gets corrupted if I look at it wrong.
There are a couple of queries that I have about SPIFFS that i have not found the answer to.
If I try to write to SPIFFS that is full, will it cause serious problems with memory, or just fail to write?
If I set up a loop to delete older files, will it cause problems trying to delete a file which does not exist? All my files include a day reference.
Reading the Espressif SPIFFS filesystem, i wonder if i may have fragmentation problems.
Looking at the FRAM, at first glance, it looks more complex. Am I understanding correctly that you need to write information to it a byte at a time and specify a memory location for each byte?
