SPIFSS write byte or char array into a file
Hi!
I tried adapting the following topic on how to write a byte-array to a binary file:
link
But after writing, when I open the file, there is 0 bytes.
My code:
#include <SPIFFS.h>
  if(!SPIFFS.begin(true)){
    Serial.println("An Error has occurred while mounting SPIFFS");
#define frame_total 50688
byte mem[frame_total];
  for ( unsigned int i=0; i<frame_total; i++) {
    mem[i] = 0x00;  // fill with '0's
File file = SPIFFS.open("/test.bmp", "wb");  // binary write mode
file.write(mem, frame_total);
file.close();
//test size
File file2 = SPIFFS.open("/test.bmp", "rb");  // binary read mode
Serial.println(file2.size());   // Serial output result: 0
file2.close();
Please, how to write a byte or char array and retrieve it?
Thank you!
This value is too large for a signed integer. Perhaps use unsigned int or size_t instead.
Thank you jfjlaros I made a mstake writing this topic:
it depends on what controller OP has. Since OP uses of SPIFS, I guess that this is esp8266 or esp32 - and on these controllers the int type is 4 bytes
Try writing a smaller array first, such as 32 bytes.
ESP32. I Will try 32 bits.
Thank you.
Ok. I'll try
