Split data
Hi dear,
I have this code arduino
#define timop 1000
#define lucion 13//pin luci accese
#define lucioff 12//pin luci spente
#define moton 11//pin accensione motore
#define motoff 10//pin spegnimento motore
#define velon 9//pin aumento velocità motore
#define veloff 8//pin diminuizione velocità motore
#define conta A0 //pin conteggio carrelli
#define velsens A1//pin magnete velocità
//storage variables
int reedVal;
long timer;// time between one full rotation (in ms)
float mph;
float radius = 13.5;// tire radius (in inches)
float circumference;
int val;
int pass;
int carr=0;
int maxReedCounter = 100;//min time (in ms) of one rotation (for debouncing)
int reedCounter;
 void setup(){
  pinMode(lucion, OUTPUT);//
  pinMode(lucioff, OUTPUT);//
  pinMode(moton, OUTPUT);//
  pinMode(motoff, OUTPUT);//
  pinMode(velon, OUTPUT);//
  pinMode(veloff, OUTPUT);//
  pinMode(velsens, INPUT);//sensore velocità
 pinMode(conta, INPUT);
    reedCounter = maxReedCounter;
  circumference = 2*3.14*radius;
  // TIMER SETUP- the timer interrupt allows precise timed measurements of the reed switch
  //for more info about configuration of arduino timers see http://arduino.cc/playground/Code/Timer1
  cli();//stop interrupts
  //set timer1 interrupt at 1kHz
  TCCR1A = 0;// set entire TCCR1A register to 0
  TCCR1B = 0;// same for TCCR1B
  TCNT1  = 0;
  // set timer count for 1khz increments
  OCR1A = 1999;// = (1/1000) / ((1/(16*10^6))*8) - 1
  // turn on CTC mode
  TCCR1B |= (1 << WGM12);
  // Set CS11 bit for 8 prescaler
  TCCR1B |= (1 << CS11);
  // enable timer compare interrupt
  TIMSK1 |= (1 << OCIE1A);
  sei();//allow interrupts
  //END TIMER SETUP
   ISR(TIMER1_COMPA_vect) {//Interrupt at freq of 1kHz to measure reed switch
  reedVal = digitalRead(velsens);//get val of A0
  if (reedVal){//if reed switch is closed
    if (reedCounter == 0){//min time between pulses has passed
      mph = (56.8*float(circumference))/float(timer);//calculate miles per hour
      timer = 0;//reset timer
      reedCounter = maxReedCounter;//reset reedCounter
    else{
      if (reedCounter > 0){//don't let reedCounter go negative
        reedCounter -= 1;//decrement reedCounter
  else{//if reed switch is open
  if (timer > 2000){
    mph = 0;//if no new pulses from reed switch- tire is still, set mph to 0
  else{
    timer += 1;//increment timer
 void displayMPH(){
  Serial.println(mph);
    if(Serial.available() >0)
       val= Serial.read();
      if(val == 'A')
  digitalWrite(lucion, HIGH);
  digitalWrite(lucion, LOW);
  }else if(val == 'B')
  digitalWrite(lucioff, HIGH);
  digitalWrite(lucioff, LOW);
      }else if(val=='C')
  digitalWrite(moton, HIGH);
  digitalWrite(moton, LOW);
      }else if(val =='D')
        }else if(val == 'E')
                  digitalWrite(velon, HIGH);
  digitalWrite(velon, LOW);
        }else if(val == 'F')
  digitalWrite(veloff, HIGH);
  digitalWrite(veloff, LOW);
           pass = digitalRead(conta);
   if(pass>0)
 carr++;
  Serial.println(carr);
 //  print mph once a second
  displayMPH();
and this code processing
// Example by Tom Igoe
import processing.serial.*;
//IMPOSTAZIONI GRAFICHE//
int width = 800;
int height = 600;
int statoluci= 0;
int statomot= 0;
int button1X;
int button1Y;
int button1Width = width/10;
int button1Height = height/20;
int button2X;
int button2Y;
int button3X;
int button3Y;
int button4X;
int button4Y;
int button2Width = button1Width;
int button2Height = button1Height;
int button3Width = button1Width;
int button3Height = button1Height;
int button4Width = button1Width;
int button4Height = button1Height;
float buttonFont = button1Height/1.5;
float wordFont = button1Height;
color buttonColor, buttonHighlight, buttonPressed;
PFont font;
boolean button1Over = false;
boolean button2Over = false;
boolean button3Over = false;
boolean button4Over = false;
//END//
Serial myPort;    // The serial port
     // The display font
String inString;  // Input string from serial port
int lf = 10;      // ASCII linefeed
  size(width,height);
  smooth();
  // Make your own font. It's fun!
  font = loadFont("CourierNew36.vlw");
  buttonColor = color(255);
  buttonHighlight = color(200);
  buttonPressed = color(50);
  button1X = width/10 - button1Width/2;
  button1Y = height/5 - button1Height/2;
  button2X = 2*width/10 - button1Width/2;
  button2Y = height/5 - button1Height/2;
    button3X = 3*width/10 - button1Width/2;
  button3Y = height/5 - button1Height/2;
      button4X = 3*width/10 - button1Width/2;
  button4Y = height/5 - button1Height/2;
  textFont(font, 18);
  // List all the available serial ports:
  //println(Serial.list());
  // Open the port you are using at the rate you want:
  myPort = new Serial(this, Serial.list()[0], 9600);
  myPort.bufferUntil(lf);
void draw() {
  background(200);
  noFill();
  stroke (255);
strokeWeight(2);
  rect(width/25, height/13,280,100);
  strokeWeight(2);
  rect(width/2.3, height/13,405,300);
    strokeWeight(2);
  rect(width/25, height/3.5,280,175);
      strokeWeight(2);
  rect(width/25, height/1.6,720,175);
  update(mouseX,mouseY);
  if(button1Over) {
    fill(buttonHighlight);
    fill(buttonColor);
  stroke(0);
  rect(width/8,height/5.8, 132, button1Height);
  if(button2Over) {
    fill(buttonColor);
  stroke(0);
  rect(width/1.72,height/5.8, 132, button2Height);
  if(button3Over) {
    fill(buttonColor);
  stroke(0);
  rect(377,250, 134, button3Height);
    if(button4Over) {
    fill(buttonColor);
  stroke(0);
  rect(530,250, 185, button3Height);
  textFont(font, buttonFont);
   textFont(font, wordFont);
  fill(0);
  text("Controllo Luci",width/20,height/8);
    fill(0);
  text("Controllo Motore",width/1.9,height/8);
      fill(0);
  text("Produzione",width/20,height/3);
  fill(0);
  if(statoluci == 0)
  text("Accendi",width/7.6,height/4.7);
  }else if(statoluci == 1)
    text("Spegni",width/7.6,height/4.7);
      if(statomot == 0)
  text("Accendi",width/1.7,button1Y + button1Height/1.3);
  }else if(statomot == 1)
  text("Spegni",width/1.7,button1Y + button1Height/1.3);
  text("Velocità",width/1.7,height/2.9);
     text("Aumenta",width/2.1,height/2.2);
   text("Diminuisci",width/1.5,height/2.2);
  fill(0);
 // text("Accendi/Spegni Led ",button3X + button1Width + width/20,button1Y + button1Height/1.2);
    fill(0);
  text("Velocità: " + inString, 40,248);
  text("Carrelli: " + inString, 40,310);
void update(int x, int y) {
  if(overButton(width/8,height/6,width/6,button1Height)){
    button1Over = true;
  if(overButton(462,height/6,135,button2Height)){
    button2Over = true;
  if(overButton(381,250,130,button3Height)){
    button3Over = true;
    if(overButton(530,250,180,button4Height)){
    button4Over = true;
void mousePressed() {
  if(button1Over) {
    println("Button1 pressed");
    if(statoluci == 0)
   myPort.write('A');
  statoluci=1;
      myPort.write('B');
    statoluci=0;
    fill(buttonPressed);
    rect(width/8,height/5.9, width/6, button1Height);
  if(button2Over) {
    println("Button2 pressed");
    if(statomot == 0)
    myPort.write('C');
  statomot=1;
      myPort.write('D');
    statomot=0;
    rect(465,height/5.8, 130, button2Height);
  if(button3Over) {
  println("Button3 pressed");
    myPort.write('E');
    rect(381,250, 130, button3Height);
  if(button4Over) {
  println("Button4 pressed");
     myPort.write('F');
    rect(530,250, 180, button4Height);
boolean overButton(int x, int y, int width, int height) {
  if(mouseX >= x && mouseX <= x+width && mouseY >= y && mouseY <= y+height) {
    return true;
    return false;
void serialEvent(Serial p) {
 inString = (myPort.readString());
How i can split the value returned by Serial? ( Serial.println(carr); and Serial.println(mph):wink:
Thx for help!
I have this code
Istheresomethingwrongwithyourspacekey?
Why didn't you use Tools + Auto Format before posting that code?
Why are there so many blank line between the #define statements, and none between setup(), displayMPH(), and loop()?
There is a carriage return and linefeed between the two values. Why can't you detect that? The Processing code actually buffers the data until the line feed is received. Then, it calls serialEvent(). What you seem to need to know is how to determine if inString contains a carr value or a mph value. The answer is that, as written, it can't. The Arduino needs to add some prefix or suffix to the value, so that Processing can tell which is which.
if i try to delete
the GUI show correctly the value mph
if i try to delete...the GUI show correctly the value mph
If the sender only sends one kind of data, there is no problem interpreting that data, is there? When you need to send multiple kinds, then the type needs to be known.
