Split message from mqtt topic
I work on a project where I subscribe to mqtt topic using arduino due.
What I did so far and is working is this
void callback(char* topic, byte* payload, unsigned int length) {
  if ((char)payload[0] == '1') {
   startR5();
if ((char)payload[0] == '0') {
   stopR5();
If I send 1 to the topic then I power a led and if I send 0 then I turn it off.
My question is how can I read a message like : "s01|2350" ? Where s01 is a senzor and 2350 is a value for tare it?
Thanks
"Read" it from where? Is that the contents of payload?
If it is, you know the length of the "string". It's the value in length.
The difference between payload and a string is that a string is a NULL terminated array of chars and payload is a non-NULL terminated array of bytes. Well, bytes and chars are the same size, and any valid char value will fit in a byte or a char. So, the type doesn't matter. And, adding a NULL is trivial.
So, your question is really "How can I parse payload?". There are plenty of sites on the internet that discuss string parsing. strtok() is function to use.
Now, the compiler will probably complain that payload is not a char *, but it is safe to lie to the compiler, and tell it that payload IS a char * by using
   char *token = strtok((char *)payload, ...
Thanks a lot
