Split of serial data
Hi I am capturing the serial data from LiDAR, i want to split the data in multiple string on the basis of count. For example i receiving continuous data, i want to split it into 3 array, initial 400 sample in array-1, then next 400 in array-2 and last 400 sample array-3, then again next 400 sample in array-1 and so on..
how i can do that?
This really sounds like an XY problem. Why do you want to do that? Why three separate arrays?
What does the stream of data look like?
Use three 'for' loops?
  for (int i=0; i<400; i++)
    array_1[i] = getSample();
    array_2[i] = getSample();
    array_3[i] = getSample();
Another interesting question, have you yet written code to put the data in one array? If so, can you please post it?
...or two nested loops:
  for (int j=0; j<3; j++)
      array[j][i] = getSample();
But OP wants 3 arrays not one.
Johnwasser example fits in that logic.
for (unsigned short i=0; i<400; array_1[i++]=getSample);
for (unsigned short i=0; i<400; array_2[i++]=getSample);
for (unsigned short i=0; i<400; array_3[i++]=getSample);
You're right, but it's not "one" array, it's a matrix. Also known as "array of arrays".. :wink:
With it OP might learn how to make parametric programs and avoid duplicates of identical objects (as a good programming practice). But if one likes spagetti coding, I'm ok with that.
I couldnt miss your two dimensional linear array.
But 2 separate arrays and one “2 dimensional“ array are not the same.
Just look at addresses of 2 dimensional array elements and you will see its 1 array with continuous addresses.
Only in high level its 2 dimension.
May be for some unknown reason OP wants them to be separated.
Have no idea why he wants 3 separate arrays. It could be done in many ways with matrix that u showed also in 1 array with delimiter after 400 chars, with mallocing and reallocing to have more dynamic array etc.
Hasn't been back since he was asked, so a lot of help is being wasted on both sides of an unnecessary discussion.
Generally speaking, yes. But IMHO 2 (or "n") arrays with fixed size and exactly the same size and data type are better stored in a matrix container. It also helps keeping the code parametric (if you need a fourth array you just change highest index). If needed, you could also have some constant symbols to distinguish between the arrays. I won't even mention memory allocation issues (I agree with your latest sentence) as OP doesn't need it.
PS: Anyway, every programmer has his own philosophy and programming mental scheme, so there's no point in trying to convince anyone else (except for other considerations like algorithm/processing speed, code compacting, source readability, and so on...) :wink:
Sometimes is a useful thing to better explain some programming techniques/philosophy if a small debate comes out, not for OP only but for future readers. But I agree it shouldn't go on for more than necessary, so I'll cut it down here.
