Split string at comma
Hi!
I'm trying to split a string at a comma this is my string: Sunday, July 10 2022 10:17:27
and this is what I'm trying to get: July 10 2022 10:17:27
I've tried to use strtok(), but the output is: Sunday
So you probably only used strtok() once in your code. the example on https://cplusplus.com/reference/cstring/strtok/ shows how it can be used to split the full string. Note the use of the while-loop.
If you still have problems after that, post your code.
Note:
The example is not tailored to Arduino.
Like this:
char array[] = "Sunday, July 10 2022 10:17:27";
char *strings[3]; // an array of pointers to the pieces of the above array after strtok()
char *ptr = NULL;
   //Serial.print(array);
   byte index = 0;
   ptr = strtok(array, " ,");  // delimiters space and comma
   while (ptr != NULL)
      strings[index] = ptr;
      index++;
      ptr = strtok(NULL, ",");
   //Serial.println(index);
   // print all the parts
   Serial.println("The Pieces separated by strtok()");
   for (int n = 0; n < index; n++)
      Serial.print("piece ");
      Serial.print(n);
      Serial.print(" = ");
      Serial.println(strings[n]);
   // step away, nothing to see here.
Output:
piece 0 = Sunday
piece 1 = July 10 2022 10:17:27
subsequent calls to strtok () are passed a NULL pointer. strtok() captures a ptr to the string passed to it processes it during these subsequent calls
