Split string into parts
I have a String want to split it into 3 different strings
String s = “firstString, secondString, thirdString”
I want to split the string with the delimiter of “,”
The sting length varies, each part not a constant length.
So far I have, splits the string with delimiter.
Now I want string a= the first part so “firstString”
string b= the second part so “secondString”
string c= the third part so “thirdString”
#include <iostream>
#include <string>
std::string a;
std::string b;
std::string c;
std::string s = "firstString,secondString,thirdString";
std::string delim = ",";
int main()
    auto start = 0U;
    auto end = s.find(delim);
    while (end != std::string::npos)
        std::cout << s.substr(start, end - start) << std::endl;
        start = end + delim.length();
        end = s.find(delim, start);
    std::cout << s.substr(start, end);
    std::cout << a;
    std::cout << b;
    std::cout << c;
Post #9
Just note myString and String s are two very different strings to parse.
check the spacing, case etc. Be careful.
Sorry meat to be s - edited
Thank you I am a bit closer to my goal.
I loop through the function and send new data for the string. The string is actually hex so I first change it to char and that then makes up the string. Works fine.
String sent is "firstString,secondString,thirdString,fourthSting"
Now I split the string and I index it -- strs[i] -- output as below.
0: "firstString"
1: "secondString"
2: "thirdString"
3: "fourthSting"
Now I send a update for the string "1String,2String,3String,4Sting", now the out put is
0: "firstString"
1: "secondString"
2: "thirdString"
3: "fourthSting"
4: "fourthSting"
5: "1String"
6: "2String"
7: "3String"
8: "4Sting"
So it kept the old strs[i] and add the new string to it.
How do I fix it so that the output is
1: "1String"
2: "2String"
3: "3String"
4: "4Sting"
My code
if (fPort == 100)
        {decoded = "";
        a = "";
        for (int i = 0; i < dataLength; i++){
            a = static_cast<char>(data[i]);
            decoded += a;
    // Split string
    while (decoded.length() > 0)
    int index = decoded.indexOf(',');
    if (index == -1) // No space found
      strs[StringCount++] = decoded;
      strs[StringCount++] = decoded.substring(0, index);
      decoded = decoded.substring(index+1);
    for (int i = 0; i < StringCount; i++)
    Serial.print(i);
    Serial.print(": \"");
    Serial.print(strs[i]);
    Serial.println("\"");
    line1 = strs[0];
    line2 = strs[1];
    line3 = strs[2];
    line4 = strs[3];
    printOled();```
