I’m facing a new issue with my projet. I try to split an array of string from a user input. User is sending command with argument. To easily process it, i want to split user input to an array of string. But this is where i failed.
Here is the relevant portion of code, *pOutString will be used later to handle command and args. And maxNumberOfargs is a value equal to size the array size definition
[some code]
//char commandAndArgs[4][30]; we expect 4 array_rows of 30 char max each
char **commandAndArgs[ROWSIZE][30];
myclass.splitToArray(pUserCommand, commandAndArgs, ROWSIZE );
[some more code]
//my method
void MyClass::splitToArray(char *pInString, char *pOutString, int maxNumberOfargs)
const char delimiters[] = "!:, ";
char* val;
int index=0;
val = strtok (pInString, delimiters);
while (val != NULL && index < maxNumberOfargs - 1 ) //-1 for index0 of array
pOutString[index] = val;
val = strtok (NULL, delimiters);
[code]
I'm pretty sure *pOutString should be declared as an array of pointers (char **) but each time i try to do it... I fail.
Can someone do some light ?
Thank you for your time and advices.
BR
val is a pointer. Storing the pointer in an array of pointers is NOT the same as saving the pointed-to data.
At the end, all elements of the pOutString array are going to contain the same pointer, and all elements are going to point to the same thing.
pOutString[index] = strdup(val);
on the other hand, WILL duplicate the pointed-to data. so that pOutString ends up containing many different pointers, pointing to different data.
Do NOT forget to free the memory pointed to by the pOutString elements.
PaulS:
By using free(pUserCommand) when using the var is done ?
But... This var is used only in setup() for now so it will be deleted on the end of setup() right ?
You don’t need an array of arrays of pointers to pointers. You just need an array of pointers.
char *commandAndArgs[ROWSIZE];
[some more code]
//my method
void MyClass::splitToArray(char *pInString, char *pOutString[], int maxNumberOfargs)
char *val;
int index=0;
I’m not entirely sure that the argument doesn’t have to be "char (*pOutString)’. It’s possible that ‘char **pOutString’ would also work when used as a function argument.
