I’m trying to write a Long to the EEPROM, so I’m splitting it into 4 bytes and writing those, then read and recombine later. I’m having trouble getting the code to simply do the split and recombine properly - the EEPROM part otherwise is working fine, as is the splitting. I’m running into problems recombining the bytes into a Long. I am aware of the EEPROM write anything code, but would like to figure out why this isn’t working. Here’s my code:
unsigned long groundpress=101325;
unsigned char byte1, byte2, byte3, byte4;
unsigned long recomb;
void setup(){
while(!Serial)
Serial.print(groundpress, DEC);
Serial.print("\t");
Serial.print(groundpress, HEX);
Serial.print("\t");
Serial.println(groundpress, BIN);
byte4 = lowByte(groundpress);
groundpress= groundpress >> 8;
byte3 = lowByte(groundpress);
byte2 = lowByte(groundpress);
byte1 = groundpress;
Serial.print("Byte1: ");
Serial.print(byte1, HEX);
Serial.print("\t");
Serial.println(byte1, BIN);
Serial.print("Byte2: ");
Serial.print(byte2, HEX);
Serial.print("\t");
Serial.println(byte2, BIN);
Serial.print("Byte3: ");
Serial.print(byte3, HEX);
Serial.print("\t");
Serial.println(byte3, BIN);
Serial.print("Byte4: ");
Serial.print(byte4, HEX);
Serial.print("\t");
Serial.println(byte4, BIN);
recomb = byte1 << 24 | byte2 << 16 | byte3 << 8 | byte4;
Serial.print("Recombined: ");
Serial.print(recomb, DEC);
Serial.print("\t");
Serial.print(recomb, HEX);
Serial.print("\t");
Serial.println(recomb, BIN);
And here’s the result:
101325 18BCD 11000101111001101
Byte1: 0 0
Byte2: 1 1
Byte3: 8B 10001011
Byte4: CD 11001101
Recombined: 4294937549 FFFF8BCD 11111111111111111000101111001101
