bonjour je travaille sur un projet de capteurs SpO2 relié a un microcontrôleurs Esp - 32 ce projet est pour mon épreuve du bac.
Quand je veux téléversé sur le microcontrôleur
IDE Arduino me mets un message d'erreurs que je n'arrive pas a comprendre.
Je vous mets le ci - dessous le message d'erreurs, et le le script du programme.
Pourriez vous m'aider s'il vous plaît .
Merci d'avance.
code d'erreurs:
test:58:1: error: 'Serial' does not name a type
test:59:1: error: 'Serial' does not name a type
Serial.println("Initializing...");
test:60:1: error: 'Blynk' does not name a type
Blynk.begin(auth, ssid, pass);
test:63:1: error: expected unqualified-id before 'while'
while (!particle.Sensor.begin(Wire, I2C_SPEED_FAST))) //Use default I2C port, 400kHz speed
programme Arduino:
## Hardware Connections (ESP32 Arduino):
-VIN = 3.3V
-GND = GND
-SDA = 21 (or SDA)
-SCL = 22 (or SCL)
#define BLYNK_PRINT Serial
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <Wire.h>
#include "MAX30105.h" //sparkfun MAX3010X library
#include "heartRate.h"
MAX30105 particleSensor;
//#define MAX30105 //if you have Sparkfun's MAX30105 breakout board , try #define MAX30105
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "****"; // Token you received on your email, Replace with stars
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "*****"; // Replace stars with Wifi Name/SSID
char pass[] = "*****"; //Replace stars with Wifi Password
double avered = 0; double aveir = 0;
double sumirrms = 0;
double sumredrms = 0;
int i = 0;
int Num = 100;//calculate SpO2 by this sampling interval
double ESpO2 = 95.0;//initial value of estimated SpO2
double FSpO2 = 0.7; //filter factor for estimated SpO2
double frate = 0.95; //low pass filter for IR/red LED value to eliminate AC component
#define TIMETOBOOT 3000; // wait for this time(msec) to output SpO2
#define SCALE 88.0; //adjust to display heart beat and SpO2 in the same scale
#define SAMPLING 5; //if you want to see heart beat more precisely , set SAMPLING to 1
#define FINGER_ON 30000; // if red signal is lower than this , it indicates your finger is not on the sensor
#define MINIMUM_SPO2 80.0;
const byte RATE_SIZE = 4; //Increase this for more averaging. 4 is good.
byte rates[RATE_SIZE]; //Array of heart rates
byte rateSpot = 0;
long lastBeat = 0; //Time at which the last beat occurred
float beatsPerMinute;
int beatAvg;
#define USEFIFO
void setup();
// Initialize sensor
Serial.println("MAX30102 was not found. Please check wiring/power/solder jumper at MH-ET LIVE MAX30102 board. ");
//while (1);
//Setup to sense a nice looking saw tooth on the plotter
byte ledBrightness = 0x7F; //Options: 0=Off to 255=50mA
byte sampleAverage = 4; //Options: 1, 2, 4, 8, 16, 32
byte ledMode = 2; //Options: 1 = Red only, 2 = Red + IR, 3 = Red + IR + Green
//Options: 1 = IR only, 2 = Red + IR on MH-ET LIVE MAX30102 board
int sampleRate = 200; //Options: 50, 100, 200, 400, 800, 1000, 1600, 3200
int pulseWidth = 411; //Options: 69, 118, 215, 411
int adcRange = 16384; //Options: 2048, 4096, 8192, 16384
// Set up the wanted parameters
particleSensor.setup(ledBrightness, sampleAverage, ledMode, sampleRate, pulseWidth, adcRange); //Configure sensor with these settings
particleSensor.enableDIETEMPRDY();
uint32_t ir, red , green;
double fred, fir;
double SpO2 = 0; //raw SpO2 before low pass filtered
#ifdef USEFIFO
particleSensor.check(); //Check the sensor, read up to 3 samples
while (particleSensor.available()) {//do we have new data
#ifdef MAX30105
red = particleSensor.getFIFORed(); //Sparkfun's MAX30105
ir = particleSensor.getFIFOIR(); //Sparkfun's MAX30105
#else
red = particleSensor.getFIFOIR(); //why getFOFOIR output Red data by MAX30102 on MH-ET LIVE breakout board
ir = particleSensor.getFIFORed(); //why getFIFORed output IR data by MAX30102 on MH-ET LIVE breakout board
#endif
i++;
fred = (double)red;
fir = (double)ir;
avered = avered * frate + (double)red * (1.0 - frate);//average red level by low pass filter
aveir = aveir * frate + (double)ir * (1.0 - frate); //average IR level by low pass filter
sumredrms += (fred - avered) * (fred - avered); //square sum of alternate component of red level
sumirrms += (fir - aveir) * (fir - aveir);//square sum of alternate component of IR level
if ((i % SAMPLING) == 0) {//slow down graph plotting speed for arduino Serial plotter by thin out
if ( millis() > TIMETOBOOT) {
float ir_forGraph = (2.0 * fir - aveir) / aveir * SCALE;
float red_forGraph = (2.0 * fred - avered) / avered * SCALE;
//trancation for Serial plotter's autoscaling
if ( ir_forGraph > 100.0) ir_forGraph = 100.0;
if ( ir_forGraph < 80.0) ir_forGraph = 80.0;
if ( red_forGraph > 100.0 ) red_forGraph = 100.0;
if ( red_forGraph < 80.0 ) red_forGraph = 80.0;
// Serial.print(red); Serial.print(","); Serial.print(ir);Serial.print(".");
if (ir < FINGER_ON) ESpO2 = MINIMUM_SPO2; //indicator for finger detached
float temperature = particleSensor.readTemperatureF();
Blynk.run();
Blynk.virtualWrite(V4, ESpO2 );
Serial.print(" Oxygen % = ");
Serial.println(ESpO2);
if ((i % Num) == 0) {
double R = (sqrt(sumredrms) / avered) / (sqrt(sumirrms) / aveir);
// Serial.println(R);
SpO2 = -23.3 * (R - 0.4) + 100; //http://ww1.microchip.com/downloads/jp/AppNotes/00001525B_JP.pdf
ESpO2 = FSpO2 * ESpO2 + (1.0 - FSpO2) * SpO2;//low pass filter
// Serial.print(SpO2);Serial.print(",");Serial.println(ESpO2);
sumredrms = 0.0; sumirrms = 0.0; i = 0;
particleSensor.nextSample(); //We're finished with this sample so move to next sample
//Serial.println(SpO2);
#endif
