Spot welder coding issues
hi every baddie,
i have some troubles with my diy spot welder arduino code.
i am using a “encoder” to control a counter variable called (position), its a number witch is displayed in a lcd i2c scree.
i am all so using a solid state relay (SSR) to control a microwave transformer and a push-button as a trigger.
i came up with the code to control that variable (number) called “position “ and display it in the lcd screen.
and here is my problem :
i want to make that number (or the variable position) as a pulse duration and out-put it to the SSR corresponding pin. for that i will use a push-button as a triggering in-put (with a debouncing function).
And i don’t know how, it is something advanced for me for now; so come to ask for your help and advising generosity.
And here's my code so far
#include <Wire.h>
#include <Adafruit_SSD1306.h>
#include <Adafruit_GFX.h>
#include "EncoderStepCounter.h"
#define OLED_WIDTH 128
#define OLED_HEIGHT 64
#define OLED_ADDR 0x3C
#define ENCODER_PIN1 2
#define ENCODER_INT1 digitalPinToInterrupt(ENCODER_PIN1)
#define ENCODER_PIN2 3
#define ENCODER_INT2 digitalPinToInterrupt(ENCODER_PIN2)
//int SWITCH = 7;
//int SSR = 13;
EncoderStepCounter encoder(ENCODER_PIN1, ENCODER_PIN2);
Adafruit_SSD1306 display(OLED_WIDTH, OLED_HEIGHT);
display.begin(SSD1306_SWITCHCAPVCC, OLED_ADDR);
display.clearDisplay();
display.setTextSize(2);
display.setTextColor(WHITE);
display.setCursor(0, 0);
display.println("Welcome");
display.setCursor(0, 17);
display.println("This is");
display.println("a Spot");
display.println("welder");
display.display();
delay(3000);
encoder.begin();
attachInterrupt(ENCODER_INT1, interrupt, CHANGE);
attachInterrupt(ENCODER_INT2, interrupt, CHANGE);
void interrupt() {
encoder.tick();
signed long position = 0;
signed char pos = encoder.getPosition();
if (pos != 0) {
position += pos;
encoder.reset();
Serial.println(position);
display.println("pulse:");
display.setTextSize(4);
display.setCursor(50, 30);
display.println(position);
display.display();
spot_welder.ino (1.59 KB)
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html .
Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom.... :slight_smile:
  #include <Wire.h>
//int SWITCH = 7;
//int SSR = 13;
  display.display();
  delay(3000);
  encoder.begin();
void interrupt() {
  encoder.tick();
  if (pos != 0) {
    position += pos;
    encoder.reset();
  display.display();
Would you help me plz
Alyoussefrou:
There is a spot welder on maker.com complete with code have a look at it.It uses a nano and a oled. I am looking for the url. Will post it ASAP
here it is
cheers!
Oh yah thank you its a ready cake.
I prefer making my own within the help of others
And that link is for a car battery spot welder not like mine it’s very different
Thank you sire
