Sprinter "Expected Identifier" Error
Hello all! I am putting together a DLP 3D printer using Sprinter (Marlin) firmware and keep getting an error when trying to compile my .h file. I’m not a coder and cannot figure out why this keeps happening. :confused: Any assistance would be appreciated. I’m using release version 1.6.10.
[Arduino: 1.6.10 (Windows 7), Board: “Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)”
Sprintermod:2232: error: ‘block_t’ was not declared in this scope
Sprintermod:2232: error: ‘block’ was not declared in this scope
void calculate_trapezoid_for_block(block_t *block, float entry_factor, float exit_factor)
Sprintermod:2232: error: expected primary-expression before ‘float’
Sprintermod:2234: error: conflicting declaration ‘long unsigned int final_rate’
unsigned long final_rate = ceil(block->nominal_rate*exit_factor); // (step/min)
In file included from C:\Users\Primary\Documents\Arduino\Little_Dipper\Sprintermod.ino:154:0:
sketch\Sprinter.h:83:8: note: previous declaration as ‘long int final_rate’
long final_rate; // The minimal rate at exit
Sprintermod:2234: error: ‘block’ was not declared in this scope
Sprintermod:2234: error: ‘exit_factor’ was not declared in this scope
Sprintermod:2237: error: expected unqualified-id before ‘if’
if(initial_rate <120) {initial_rate=120; }
Sprintermod:2238: error: expected unqualified-id before ‘if’
if(final_rate < 120) {final_rate=120; }
Sprintermod:2240: error: conflicting declaration ‘long int acceleration’
long acceleration = block->acceleration_st;
sketch\Sprinter.h:75:9: note: previous declaration as ‘float acceleration’
float acceleration; // acceleration mm/sec^2
Sprintermod:2240: error: ‘block’ was not declared in this scope
Sprintermod:2242: error: ‘block’ was not declared in this scope
ceil(estimate_acceleration_distance(block->initial_rate, block->nominal_rate, acceleration));
Sprintermod:2244: error: ‘block’ was not declared in this scope
floor(estimate_acceleration_distance(block->nominal_rate, block->final_rate, -acceleration));
Sprintermod:2247: error: conflicting declaration ‘int32_t plateau_steps’
int32_t plateau_steps = block->step_event_count-accelerate_steps-decelerate_steps;
C:\Users\Primary\Documents\Arduino\Little_Dipper\Sprintermod.ino:281:15: note: previous declaration as ‘long unsigned int plateau_steps’
unsigned long plateau_steps;
Sprintermod:2247: error: ‘block’ was not declared in this scope
Sprintermod:2252: error: expected unqualified-id before ‘if’
if (plateau_steps < 0) {
In file included from C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:30:0,
from sketch\Little_Dipper.ino.cpp:1:
Sprintermod:171: error: expected ‘)’ before ‘::’ token
#define CRITICAL_SECTION_START unsigned char _sreg = SREG; cli()
C:\Users\Primary\Documents\Arduino\Little_Dipper\Sprintermod.ino:2267:3: note: in expansion of macro ‘CRITICAL_SECTION_START’
CRITICAL_SECTION_START; // Fill variables used by the stepper in a critical section
Sprintermod:2268: error: expected unqualified-id before ‘if’
if(block->busy == false) { // Don’t update variables if block is busy.
In file included from c:\program files\arduino\hardware\tools\avr\avr\include\avr\io.h:99:0,
from c:\program files\arduino\hardware\tools\avr\avr\include\avr\pgmspace.h:90,
from C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:28,
Sprintermod:172: error: expected unqualified-id before ‘volatile’
#define CRITICAL_SECTION_END SREG = _sreg
C:\Users\Primary\Documents\Arduino\Little_Dipper\Sprintermod.ino:2278:3: note: in expansion of macro ‘CRITICAL_SECTION_END’
CRITICAL_SECTION_END;
Sprintermod:172: error: expected ‘)’ before ‘volatile’
Sprintermod:2279: error: expected declaration before ‘}’ token
exit status 1
expected identifier before ‘long’
“Show verbose output during compilation”
option enabled in File → Preferences.
Curadh013: Hello all! I am putting together a DLP 3D
And? You have some problem? Care to enlighten us as to what it is?
Sorry, posted too early! Updated original post above...
I'm using release version 1.6.10
To compile what code? In this part of the forum, POST YOUR CODE rules.
