Hey guys I'm having some trouble getting this sprintf to work.
I got this code that connects to a hotspot, when connected, it sends its MAC address, then the hotspots send data: parameter1 / parameter2
I find the /
and I find the last char of parameter 1 and the first char of parameter 2.
With those, I want to make a char array. For this example, it should be 1p
But I'm having problems making the char array, I keep getting :
invalid conversion from 'char' to 'char*'
I tried multiple things but with no succes.
#include <ESP8266WiFi.h>
#include <WiFiUdp.h>
// Set WiFi credentials
#define WIFI_SSID "Little Edian Hotspot"
// UDP
WiFiUDP UDP;
#define UDP_PORT 4210
char incomingPacket[255]; // buffer for incoming packets
const char seperator = '/';
uint8_t wantedpos;
// Setup serial port
// Begin WiFi
WiFi.mode(WIFI_STA);
WiFi.begin(WIFI_SSID);
// Connecting to WiFi...
Serial.print("Connecting to ");
Serial.print(WIFI_SSID);
// Loop continuously while WiFi is not connected
while (WiFi.status() != WL_CONNECTED)
delay(100);
Serial.print(".");
// Connected to WiFi
Serial.print("Connected! IP address: ");
// Begin UDP port
UDP.begin(UDP_PORT);
Serial.print("Opening UDP port ");
Serial.println(UDP_PORT);
UDP.beginPacket(UDP.remoteIP(), UDP_PORT);
UDP.write(WiFi.macAddress().c_str());
UDP.endPacket();
Serial.println(WiFi.macAddress().c_str());
int packetSize = UDP.parsePacket();
if (packetSize)
// receive incoming UDP packets
Serial.printf("Received %d bytes from %s, port %d\n", packetSize, UDP.remoteIP().toString().c_str(), UDP.remotePort());
int len = UDP.read(incomingPacket, 255);
if (len > 0)
incomingPacket[len] = 0;
Serial.printf("UDP packet contents: %s\n", incomingPacket);
for (int i = 0; i < strlen(incomingPacket); i++) {
if (seperator == incomingPacket[i]) {
wantedpos = i;
if (wantedpos != 0) {
char buffer[255];
sprintf("%c%c", incomingPacket[wantedpos - 2], incomingPacket[wantedpos + 2]);
Serial.println(buffer);
Serial.println(incomingPacket[wantedpos - 2]);
Serial.println(incomingPacket[wantedpos + 2]);
// UDP.beginPacket(UDP.remoteIP(), UDP.remotePort());
// UDP.write(buffer);
// UDP.endPacket();
wantedpos = 0;
