sprintf() confusion... Only one buffer?
Can I not use more than one buffer with the sprintf() function? Here is a program that shows that the second buffer corrupts the first buffer... I am trying to understand what is causing this...
char buff1[3];
char buff2[3];
  sprintf(buff1,"%d:%d",1,2); // 1:2
  Serial.print("buff1>");
  Serial.print(buff1);
  Serial.println("<");
  sprintf(buff2,"%d:%d",3,4); // 3:4
  Serial.print("buff2>");
  Serial.print(buff2);
The output with this program is:
buff1>1:2<
buff2>3:4<
buff1><
Why did buff1 change when we assigned buff2?
Your buffer isn't big enough
char buff1[3];  //not big enough for 3 characters and a terminating zero
char buff2[3];  //ditto
... and furthermore, you should not presume the order of variables in memory.
TheMemberFormerlyKnownAsAWOL:
Ahh.... Bingo! If I change it to buff1[4] and buff2[4] it all works. I forgot about the \0 character that is needed in the arrays.
You guys are awesome!!! Many thanks!!
It is a bit safer to use snprintf() instead of sprintf(). Given the size of the buffer, snprintf() will truncate the text to allow space for the null terminator.
