Hi I am trying to format c string in char array using sprintf.
I have following code:
bool relay_status = false;
char response[1024];
sprintf(response,
"HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n"
"<!DOCTYPE HTML>\r\n<html>\r\n"
"<body style=\"font-size: 2em;\">\r\n"
"relay_status=%s\r\n",
<a href=\"/gpio/%c\">switch %s</a>\r\n"
"</body></html>",
(relay_status)?"high":"low", (relay_status)?'0':'1', (relay_status)?"off":"on"
Serial.println(response);
delay(3000);
Outpus is:
HTTP/1.1 200 OK
<!DOCTYPE HTML>
<html>
<body style="font-size: 2em;">
relay_status=
<a href="/gpio/%c">switch %s</a>
</body></html>
What I do bad?
system
January 8, 2017, 5:14pm
2
What I do bad?
I'm going to guess you used too much RAM
AWOL:
I'm using ESP8266 wit a lot of ram.
If I use smaller buffer char response[256]; , still doesn't work.
With String it works great:
String r;
r += "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n";
r += "<!DOCTYPE HTML>\r\n<html>\r\n";
r += "<body style=\"font-size: 2em;\">\r\n";
r += "relay_status=";
r += (relay_status)?"high":"low";
r += "\r\n";
r += "
<a href=\"/gpio/";
r += (relay_status)?'0':'1';
r += "\">switch ";
r += (relay_status)?"off":"on";
r += "</a>\r\n";
r += "</body></html>";
Serial.println(r);
system
January 8, 2017, 5:31pm
5
I'm sure the fine folks over at snippets-r-us will have some answers for you.
dev_1
January 8, 2017, 5:43pm
6
There's no reason to put everything in one big buffer and print it with one statement. Just print the pieces:
Serial.print
"relay_status="
Serial.print( (relay_status) ? "high" : "low" );
Serial.print
"\r\n"
<a href=\"/gpio/"
Serial.print( (relay_status) ? '0' : '1' );
Serial.print( "\">switch " );
Serial.print( (relay_status)?"off":"on" );
Serial.println
"</a>\r\n"
"</body></html>"
(Adjacent double-quoted string literals are treated as one concatenated literal.)
And yes, the String
can also get you into memory trouble on the ESP8266.
Cheers,
/dev
martin159:
sprintf(response,
"\r\n\r\n"
"<body style="font-size: 2em;">\r\n"
<a href="/gpio/%c">switch %s\r\n"
delay(3000);
You are trying to get sprintf to work not just for the first format string but also the next string.
This is the format string,
This is not, so why the format chars in it?
"</body></html>",
The better question is WHY bother using a completely unnecessary array and sprintf there at all?
Serial goes out one bit at a time, each char takes many cycles to send. You can print single chars and still overfill the output buffer before a single char is sent. Break that up and print pieces, it will still be received the same as if it was all sent from a prepared buffer for instant transmission (an unreal notion).
martin159:
What I do bad?
What is the comma doing in
That indicates the end of the format string and anything after that is arguments to the format string. So the the %s will be replaced by
"</body></html>"
and
will be ignored as there is only one format specifier in the format string.
