sprintf pointer functions as character array arguments
In the sketch below I get the value from getValueTwo() as output for both sprintf values. If I reverse the calls in sprintf then I get the value of GetValueOne() for both values.
The only thing I have found to get the expected result from sprintf was to make sure the return values from the stub functions are a different lengths - be them statically declared or initialized with a string they have to be different length.
Any suggestions to fixing the issue or a better way to create a comma delimited list of values in a character array to be used as HTTP POST data are welcome.
void setup() { Serial.begin(9600); Serial.println("Starting"); }
char logEntry[80];
sprintf(logEntry,"%s,%s\n",getValueOne(),getValueTwo());
Serial.print(logEntry);
char *getValueOne()
char retval=“12.01”;
return retval;
char *getValueTwo()
char retval=“70.20”;
return retval;
Don't return pointers to automatic variables and expect sensible results.
Do use code tags.
(Uncompiled, untested)
char retval1[]="12.01";
char retval2[]="70.20";
  char logEntry[80];
char *getValueOne()
  return retval1;
char *getValueTwo()
  return retval2;
