sprintf problem
I am trying to format a string with a floating point specifier/value asbelow
    float flVal = 23.468;
     sprintf(buff,"The floating pointvalue is %3.2f", flVal);
     Serial.println(buff);
The result that i get is a '?' where the value shoul be.
Am I using the wrong specifier, and if so what is it ??
Many thanks !
sprintf doesn't work with float.
michinyon: sprintf doesn't work with float.
I assume that you mean that it doesn't work with Arduino C ? (asit does in "normal" C/C++) If so, that is most anoying !!
Thanks for your helpanyway !
Remittub:
Yes, because the code in library about this features, is very big. You can use dtostr(). If you search in previous threads in Programming you can find many info. http://forum.arduino.cc/index.php?topic=103935.0
http://www.gammon.com.au/forum/?id=12153#trap6
Remittub: I assume that you mean that it doesn't work with Arduino C ? (asit does in "normal" C/C++) If so, that is most anoying !!
"Normal" C usually has megabytes of memory to play with these days, unlike the Arduino.
I’ve got round the problem …
    // sprintf(g_chMsg,"Float flItem = %5.2lf  <",flItem);
    byte byIntPart = (byte)flItem;
    byte byFractPart = (byte)(flItem - byIntPart)*100;
    sprintf(g_chMsg,"Zone %d temperature is %d.%d deg C", byZoneNum, byIntPart,byFractPart);
A bit messy,but it works !!
Until you try that with flItem = 1.05.
Change the format specifiers to %d.%02d, so that there are always exactly 2 digits after the decimal point.
PaulS:
You beat me to it - just found that !! (Well spotted)
