Sprintf() returning garbage characters
I'm using RTCLib which has functions that returns hour,minute,second in uint8_t.
I used Sprintf to format them to this 00:00:00.
This is the code:
DateTime now = rtc.now();
char str[9];
sprintf(str, "%02u:%02u:%02u", now.hour(),now.minute(),now.second());
str[9] = '\0';
If I print str, the output will look like this:
00:00:00��?u� @���?L��?��?�3 @��?P�?
How do I properly null terminate this char array?
str[9] = '\0';
Your array does not have an element 9.
In any case sprintf() will add the terminating zero
sprintf should take care of it for you - no need to explicitly add a NUL.
I adjusted the size to 8 and remove the manual termination but I'm still getting garbage characters
Edit:
I made the char array global and the garbage characters are gone.
Size needs to be nine and lose the manual termination.
dalvikvm:
Edit:
If only you had posted your complete program in the first place ...
