I have a problem too. i do select ESP32 and after clicking on "upload" it shows this: "signal: killed Compilation error: signal: killed". I tried to solve this problem with my trainer but we could not find any solution. We also tried to install the old version and also tried with "CP210xVCPDriver". Maybe you can help me.
Last login: Tue Nov 14 08:29:56 on console
princemince@MacBook-Air-von-Elif ~ % /Applications/Arduino IDE.app/Contents/MacOS/Arduino IDE
zsh: no such file or directory: /Applications/Arduino
princemince@MacBook-Air-von-Elif ~ % "/Applications/Arduino IDE.app/Contents/MacOS/Arduino IDE"
Arduino IDE 2.2.1
Checking for frontend application configuration customizations. Module path: /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/electron-main.js, destination 'package.json': /Applications/Arduino IDE.app/Contents/Resources/app/package.json
2023-11-14 09:42:07.483 Arduino IDE[2312:39389] WARNING: Secure coding is not enabled for restorable state! Enable secure coding by implementing NSApplicationDelegate.applicationSupportsSecureRestorableState: and returning YES.
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.2.1" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.34.0" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2023-08-31T14:26:39.874Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.2.1","cliVersion":"0.34.0","buildDate":"2023-08-31T14:26:39.874Z"}
Starting backend process. PID: 2341
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///Users/princemince/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2023-11-14T08:42:08.608Z root WARN Backend Object.initialize took longer than the expected maximum 50 milliseconds: 64.1 ms [Finished 0.937 s after backend start]
2023-11-14T08:42:08.617Z root WARN Backend Object.configure took longer than the expected maximum 50 milliseconds: 54.0 ms [Finished 0.939 s after backend start]
2023-11-14T08:42:08.618Z root INFO Backend a.onStart: 13.8 ms [Finished 0.939 s after backend start]
2023-11-14T08:42:08.620Z root INFO Backend a.configure: 6.4 ms [Finished 1.043 s after backend start]
2023-11-14T08:42:08.631Z root INFO Backend u.onStart: 3.8 ms [Finished 1.043 s after backend start]
2023-11-14T08:42:08.635Z root INFO Backend d.configure: 0.3 ms [Finished 1.043 s after backend start]
2023-11-14T08:42:08.648Z root WARN Backend d.initialize took longer than the expected maximum 50 milliseconds: 103.5 ms [Finished 1.047 s after backend start]
2023-11-14T08:42:08.648Z root INFO Backend c.onStart: 3.5 ms [Finished 1.047 s after backend start]
2023-11-14T08:42:08.654Z root INFO Backend s.configure: 11.0 ms [Finished 1.060 s after backend start]
2023-11-14T08:42:08.664Z config INFO >>> Initializing CLI configuration...
2023-11-14T08:42:08.667Z root INFO Backend c.initialize: 2.6 ms [Finished 1.060 s after backend start]
2023-11-14T08:42:08.667Z root INFO Backend P.onStart: 10.9 ms [Finished 1.071 s after backend start]
2023-11-14T08:42:08.669Z config INFO Loading CLI configuration from /Users/princemince/.arduinoIDE/arduino-cli.yaml...
2023-11-14T08:42:08.676Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2023-11-14T08:42:08.677Z root INFO Backend s.initialize: 0.7 ms [Finished 1.075 s after backend start]
2023-11-14T08:42:08.677Z root INFO Backend w.onStart: 13.1 ms [Finished 1.088 s after backend start]
2023-11-14T08:42:08.677Z root INFO Backend r.configure: 16.8 ms [Finished 1.088 s after backend start]
2023-11-14T08:42:08.678Z discovery-log INFO start
2023-11-14T08:42:08.678Z discovery-log INFO start new deferred
2023-11-14T08:42:08.678Z root INFO Backend d.initialize: 2.5 ms [Finished 1.094 s after backend start]
2023-11-14T08:42:08.678Z root INFO Backend y.onStart: 17.1 ms [Finished 1.106 s after backend start]
2023-11-14T08:42:08.678Z root INFO Backend r.configure: 12.8 ms [Finished 1.107 s after backend start]
2023-11-14T08:42:08.678Z root INFO Backend s.onStart: 7.0 ms [Finished 1.117 s after backend start]
2023-11-14T08:42:08.679Z root INFO Backend h.configure: 1.7 ms [Finished 1.117 s after backend start]
2023-11-14T08:42:08.679Z root INFO Backend a.configure: 1.4 ms [Finished 1.118 s after backend start]
2023-11-14T08:42:08.679Z root INFO Backend s.configure: 0.1 ms [Finished 1.119 s after backend start]
2023-11-14T08:42:08.679Z root INFO Backend l.configure: 0.1 ms [Finished 1.119 s after backend start]
2023-11-14T08:42:08.735Z root INFO Theia app listening on http://localhost:49312.
2023-11-14T08:42:08.747Z root INFO Finished starting backend application: 55.5 ms [Finished 1.173 s after backend start]
2023-11-14T08:42:08.810Z root WARN The local plugin referenced by local-dir:/Users/princemince/.arduinoIDE/extensions does not exist.
2023-11-14T08:42:08.832Z root WARN The local plugin referenced by local-dir:/Users/princemince/.arduinoIDE/plugins does not exist.
2023-11-14T08:42:09.011Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":["https://dl.espressif.com/dl/package_esp32_dev_index.json"]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"builtin":{"libraries":"/Users/princemince/Library/Arduino15/libraries"},"data":"/Users/princemince/Library/Arduino15","downloads":"/Users/princemince/Library/Arduino15/staging","user":"/Users/princemince/Documents/Arduino"},"library":{"enable_unsafe_install":false},"locale":"en","logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2023-11-14T08:42:09.013Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2023-11-14T08:42:09.013Z config INFO Loaded the CLI configuration.
2023-11-14T08:42:09.021Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///Users/princemince/Library/Arduino15","sketchDirUri":"file:///Users/princemince/Documents/Arduino","additionalUrls":["https://dl.espressif.com/dl/package_esp32_dev_index.json"],"network":"none","locale":"en"}
2023-11-14T08:42:09.022Z config INFO Validating the CLI configuration...
2023-11-14T08:42:09.044Z root INFO Resolve plugins list: 376.3 ms [Finished 1.484 s after backend start]
2023-11-14T08:42:09.379Z daemon INFO time="2023-11-14T09:42:09+01:00" level=info msg="Using config file: /Users/princemince/.arduinoIDE/arduino-cli.yaml"
time="2023-11-14T09:42:09+01:00" level=info msg="arduino-cli version 0.34.0"
time="2023-11-14T09:42:09+01:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:49313
{"IP":"127.0.0.1","Port":"49313"}
2023-11-14T08:42:09.381Z daemon INFO Daemon is running.
2023-11-14T08:42:09.759Z daemon INFO time="2023-11-14T09:42:09+01:00" level=info msg="Checking signature" index=/Users/princemince/Library/Arduino15/package_index.json signatureFile=/Users/princemince/Library/Arduino15/package_index.json.sig trusted=true
time="2023-11-14T09:42:09+01:00" level=info msg="Missing signature file" index=/Users/princemince/Library/Arduino15/package_esp32_dev_index.json
time="2023-11-14T09:42:09+01:00" level=info msg="Loading hardware from: /Users/princemince/Library/Arduino15/packages"
time="2023-11-14T09:42:09+01:00" level=info msg="Loading package arduino from: /Users/princemince/Library/Arduino15/packages/arduino/hardware"
time="2023-11-14T09:42:09+01:00" level=info msg="Missing signature file" index=/Users/princemince/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/installed.json
time="2023-11-14T09:42:09+01:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2023-11-14T09:42:09+01:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
time="2023-11-14T09:42:09+01:00" level=info msg="Checking existence of 'tools' path: /Users/princemince/Library/Arduino15/packages/arduino/tools"
time="2023-11-14T09:42:09+01:00" level=info msg="Loading tools from dir: /Users/princemince/Library/Arduino15/packages/arduino/tools"
time="2023-11-14T09:42:09+01:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
time="2023-11-14T09:42:09+01:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2023-11-14T09:42:09+01:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
time="2023-11-14T09:42:09+01:00" level=info msg="Loaded tool" tool="arduino:dfu-util@0.11.0-arduino5"
time="2023-11-14T09:42:09+01:00" level=info msg="Loading package builtin from: /Users/princemince/Library/Arduino15/packages/builtin"
time="2023-11-14T09:42:09+01:00" level=info msg="Checking existence of 'tools' path: /Users/princemince/Library/Arduino15/packages/builtin/tools"
time="2023-11-14T09:42:09+01:00" level=info msg="Loading tools from dir: /Users/princemince/Library/Arduino15/packages/builtin/tools"
time="2023-11-14T09:42:09+01:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2023-11-14T09:42:09+01:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2023-11-14T09:42:09+01:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2023-11-14T09:42:09+01:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
time="2023-11-14T09:42:09+01:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.13.0"
time="2023-11-14T09:42:09+01:00" level=info msg="Loading package esp32 from: /Users/princemince/Library/Arduino15/packages/esp32/hardware"
time="2023-11-14T09:42:09+01:00" level=info msg="Missing signature file" index=/Users/princemince/Library/Arduino15/packages/esp32/hardware/esp32/2.0.11/installed.json
2023-11-14T08:42:09.850Z daemon INFO time="2023-11-14T09:42:09+01:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2023-11-14T09:42:09+01:00" level=info msg="Loaded platform" platform="esp32:esp32@2.0.11"
time="2023-11-14T09:42:09+01:00" level=info msg="Checking existence of 'tools' path: /Users/princemince/Library/Arduino15/packages/esp32/tools"
time="2023-11-14T09:42:09+01:00" level=info msg="Loading tools from dir: /Users/princemince/Library/Arduino15/packages/esp32/tools"
time="2023-11-14T09:42:09+01:00" level=info msg="Loaded tool" tool="esp32:esptool_py@4.5.1"
time="2023-11-14T09:42:09+01:00" level=info msg="Loaded tool" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
time="2023-11-14T09:42:09+01:00" level=info msg="Loaded tool" tool="esp32:mkspiffs@0.2.3"
time="2023-11-14T09:42:09+01:00" level=info msg="Loaded tool" tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
time="2023-11-14T09:42:09+01:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2023-11-14T09:42:09+01:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
time="2023-11-14T09:42:09+01:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
time="2023-11-14T09:42:09+01:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2023-11-14T09:42:09+01:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2023-11-14T09:42:09+01:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2023-11-14T09:42:09+01:00" level=info msg="Adding libraries dir" dir=/Users/princemince/Library/Arduino15/packages/esp32/hardware/esp32/2.0.11/libraries location=platform
time="2023-11-14T09:42:09+01:00" level=info msg="Adding libraries dir" dir=/Users/princemince/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries location=platform
time="2023-11-14T09:42:09+01:00" level=info msg="Loading libraries index file" index=/Users/princemince/Library/Arduino15/library_index.json
2023-11-14T08:42:10.060Z daemon INFO time="2023-11-14T09:42:09+01:00" level=info msg="Adding libraries dir" dir=/Users/princemince/Library/Arduino15/libraries location=ide
time="2023-11-14T09:42:09+01:00" level=info msg="Adding libraries dir" dir=/Users/princemince/Documents/Arduino/libraries location=user
2023-11-14T08:42:10.697Z root INFO Deploy plugins list: 376.3 ms [Finished 3.135 s after backend start]
2023-11-14T08:42:11.678Z config INFO The CLI config is valid.
2023-11-14T08:42:11.679Z config INFO <<< Initialized the CLI configuration.
2023-11-14T08:42:11.682Z discovery-log INFO start request start watch
2023-11-14T08:42:11.683Z discovery-log INFO start requested start watch
2023-11-14T08:42:11.683Z discovery-log INFO start resolved watching
2023-11-14T08:42:11.685Z daemon INFO time="2023-11-14T09:42:11+01:00" level=info msg="starting discovery builtin:mdns-discovery process"
2023-11-14T08:42:11.685Z daemon INFO time="2023-11-14T09:42:11+01:00" level=info msg="starting discovery builtin:serial-discovery process"
time="2023-11-14T09:42:11+01:00" level=info msg="starting discovery builtin:dfu-discovery process"
2023-11-14T08:42:11.703Z daemon INFO time="2023-11-14T09:42:11+01:00" level=info msg="started discovery builtin:dfu-discovery process"
time="2023-11-14T09:42:11+01:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.34.0\" to discovery builtin:dfu-discovery"
time="2023-11-14T09:42:11+01:00" level=info msg="started discovery builtin:mdns-discovery process"
time="2023-11-14T09:42:11+01:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.34.0\" to discovery builtin:mdns-discovery"
2023-11-14T08:42:11.706Z daemon INFO time="2023-11-14T09:42:11+01:00" level=info msg="started discovery builtin:serial-discovery process"
time="2023-11-14T09:42:11+01:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.34.0\" to discovery builtin:serial-discovery"
2023-11-14T08:42:11.711Z daemon INFO time="2023-11-14T09:42:11+01:00" level=info msg="from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1"
2023-11-14T08:42:11.712Z daemon INFO time="2023-11-14T09:42:11+01:00" level=info msg="sending command START_SYNC to discovery builtin:mdns-discovery"
2023-11-14T08:42:11.712Z daemon INFO time="2023-11-14T09:42:11+01:00" level=info msg="from discovery builtin:mdns-discovery received message type: start_sync, message: OK"
2023-11-14T08:42:11.733Z daemon INFO time="2023-11-14T09:42:11+01:00" level=info msg="from discovery builtin:dfu-discovery received message type: hello, message: OK, protocol version: 1"
2023-11-14T08:42:11.734Z daemon INFO time="2023-11-14T09:42:11+01:00" level=info msg="sending command START_SYNC to discovery builtin:dfu-discovery"
2023-11-14T08:42:11.736Z daemon INFO time="2023-11-14T09:42:11+01:00" level=info msg="from discovery builtin:dfu-discovery received message type: start_sync, message: OK"
2023-11-14T08:42:11.739Z daemon INFO time="2023-11-14T09:42:11+01:00" level=info msg="from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1"
2023-11-14T08:42:11.740Z daemon INFO time="2023-11-14T09:42:11+01:00" level=info msg="sending command START_SYNC to discovery builtin:serial-discovery"
time="2023-11-14T09:42:11+01:00" level=info msg="from discovery builtin:serial-discovery received message type: start_sync, message: OK"
2023-11-14T08:42:11.743Z daemon INFO time="2023-11-14T09:42:11+01:00" level=info msg="from discovery builtin:serial-discovery received message type: add, port: /dev/cu.wlan-debug"
2023-11-14T08:42:11.746Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"/dev/cu.wlan-debug","label":"/dev/cu.wlan-debug","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2023-11-14T08:42:13.942Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 792.2 ms [Finished 4.978 s after frontend start]
2023-11-14T08:42:13.988Z root WARN A command editor.action.toggleStickyScroll is already registered.
2023-11-14T08:42:14.129Z root WARN Frontend keybindings.onStart took longer than the expected maximum 100 milliseconds: 163.1 ms [Finished 5.185 s after frontend start]
2023-11-14T08:42:14.604Z root WARN Frontend c.onStart took longer than the expected maximum 100 milliseconds: 226.2 ms [Finished 5.680 s after frontend start]
2023-11-14T08:42:15.082Z root INFO Start frontend contributions: 2169.0 ms [Finished 5.693 s after frontend start]
2023-11-14T08:42:15.083Z root INFO Changed application state from 'init' to 'started_contributions'.
2023-11-14T08:42:15.233Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2023-11-14T08:42:15.234Z root INFO >>> Restoring the layout state...
2023-11-14T08:42:15.234Z root INFO <<< Nothing to restore.
2023-11-14T08:42:15.305Z root INFO [hosted-plugin: 2356] PLUGIN_HOST(2356) starting instance
2023-11-14T08:42:15.317Z root INFO Initialize the workbench layout: 68.5 ms [Finished 6.382 s after frontend start]
2023-11-14T08:42:15.356Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2023-11-14T08:42:15.743Z root INFO [f9e22ced-a85e-4e39-b828-ab488e6baa5f] Waiting for backend deployment: 1127.7 ms [Finished 6.813 s after frontend start]
2023-11-14T08:42:17.244Z root INFO Replace loading indicator with ready workbench UI (animation): 1233.7 ms [Finished 7.670 s after frontend start]
2023-11-14T08:42:17.247Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2023-11-14T08:42:17.247Z root WARN Linked preference "workbench.colorCustomizations" not found. Source: "editor.bracketPairColorization.enabled"
2023-11-14T08:42:17.253Z root INFO Frontend application start: 3328.2 ms [Finished 9.652 s after backend start]
Checking for update
2023-11-14T08:42:17.878Z root ERROR ---- !!!SLOW!!! DURATION: search took 535.931 ms. Args: [{"type":"Updatable"}] ----
Update for version 2.2.1 is not available (latest version: 2.2.1, downgrade is allowed).
2023-11-14T08:42:18.292Z root INFO [f9e22ced-a85e-4e39-b828-ab488e6baa5f] Sync of 23 plugins: 2493.5 ms [Finished 9.306 s after frontend start]
2023-11-14T08:42:18.295Z root INFO [f9e22ced-a85e-4e39-b828-ab488e6baa5f] Loading plugin contributions
2023-11-14T08:42:18.295Z root INFO [f9e22ced-a85e-4e39-b828-ab488e6baa5f] Load contributions of 23 plugins: 50.4 ms [Finished 9.357 s after frontend start]
2023-11-14T08:42:18.460Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2023-11-14T08:42:18.460Z root WARN a registered grammar configuration for 'cpp' language is overridden
2023-11-14 09:42:19.079 Arduino IDE Helper (Renderer)[2346:39641] CoreText note: Client requested name ".NewYork-Regular", it will get TimesNewRomanPSMT rather than the intended font. All system UI font access should be through proper APIs such as CTFontCreateUIFontForLanguage() or +[NSFont systemFontOfSize:].
2023-11-14 09:42:19.079 Arduino IDE Helper (Renderer)[2346:39641] CoreText note: Set a breakpoint on CTFontLogSystemFontNameRequest to debug.
2023-11-14T08:42:21.262Z root ERROR [hosted-plugin: 2356] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.linux as cortex-debug.armToolchainPath is null
2023-11-14T08:42:21.268Z root ERROR [hosted-plugin: 2356] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.osx as cortex-debug.armToolchainPath is null
2023-11-14T08:42:21.268Z root ERROR [hosted-plugin: 2356] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.windows as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.linux as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.osx as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.windows as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.linux as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.osx as cortex-debug.openocdPath is null
2023-11-14T08:42:21.268Z root ERROR [hosted-plugin: 2356] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.windows as cortex-debug.openocdPath is null
2023-11-14T08:42:21.269Z root ERROR [hosted-plugin: 2356] Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.linux as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.osx as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.windows as cortex-debug.pyocdPath is null
2023-11-14T08:42:21.270Z root ERROR [hosted-plugin: 2356] Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.linux as cortex-debug.PEGDBServerPath is null
2023-11-14T08:42:21.272Z root ERROR [hosted-plugin: 2356] Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.osx as cortex-debug.PEGDBServerPath is null
2023-11-14T08:42:21.272Z root ERROR [hosted-plugin: 2356] Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.windows as cortex-debug.PEGDBServerPath is null
2023-11-14T08:42:21.274Z root ERROR [hosted-plugin: 2356] Conflict in settings file Default: Ignoring cortex-debug.stutilPath.linux as cortex-debug.stutilPath is null
2023-11-14T08:42:21.282Z root ERROR [hosted-plugin: 2356] Conflict in settings file Default: Ignoring cortex-debug.stutilPath.osx as cortex-debug.stutilPath is null
2023-11-14T08:42:21.304Z root ERROR [hosted-plugin: 2356] Conflict in settings file Default: Ignoring cortex-debug.stutilPath.windows as cortex-debug.stutilPath is null
2023-11-14T08:42:21.306Z root ERROR [hosted-plugin: 2356] Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.linux as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.osx as cortex-debug.stlinkPath is null
2023-11-14T08:42:21.306Z root ERROR [hosted-plugin: 2356] Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.windows as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.linux as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.osx as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.windows as cortex-debug.stm32cubeprogrammer is null
2023-11-14T08:42:21.401Z root INFO [hosted-plugin: 2356] PLUGIN_HOST(2356): PluginManagerExtImpl/init()
2023-11-14T08:42:21.420Z root INFO [hosted-plugin: 2356] PLUGIN_HOST(2356): initializing(vscode-arduino-api@0.1.2 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2023-11-14T08:42:21.471Z root INFO [hosted-plugin: 2356] PLUGIN_HOST(2356): initializing(cortex-debug@1.5.1 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2023-11-14T08:42:21.471Z root INFO [hosted-plugin: 2356] Debugger contribution has been registered: cortex-debug
2023-11-14T08:42:21.473Z root INFO [hosted-plugin: 2356] PLUGIN_HOST(2356): initializing(vscode-arduino-tools@0.0.2-beta.8 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2023-11-14T08:42:21.474Z root INFO [hosted-plugin: 2356] PLUGIN_HOST(2356): initializing(cpp@1.52.1 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2023-11-14T08:42:21.475Z root INFO [hosted-plugin: 2356] PLUGIN_HOST(2356): initializing(json@1.46.1 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2023-11-14T08:42:21.476Z root INFO [hosted-plugin: 2356] PLUGIN_HOST(2356): initializing(json-language-features@1.46.1 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2023-11-14T08:42:21.481Z root INFO [hosted-plugin: 2356] PLUGIN_HOST(2356): initializing(vscode-language-pack-bg@1.48.3 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2023-11-14T08:42:21.483Z root INFO [hosted-plugin: 2356] PLUGIN_HOST(2356): initializing(vscode-language-pack-cs@1.78.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2023-11-14T08:42:21.484Z root INFO [hosted-plugin: 2356] PLUGIN_HOST(2356): initializing(vscode-language-pack-de@1.78.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2023-11-14T08:42:21.487Z root INFO [hosted-plugin: 2356] PLUGIN_HOST(2356): initializing(vscode-language-pack-es@1.78.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2023-11-14T08:42:21.494Z root INFO [hosted-plugin: 2356] PLUGIN_HOST(2356): initializing(vscode-language-pack-fr@1.78.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2023-11-14T08:42:21.498Z root INFO [hosted-plugin: 2356] PLUGIN_HOST(2356): initializing(vscode-language-pack-hu@1.48.3 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2023-11-14T08:42:21.502Z root INFO [hosted-plugin: 2356] PLUGIN_HOST(2356): initializing(vscode-language-pack-it@1.78.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2023-11-14T08:42:21.509Z root INFO [hosted-plugin: 2356] PLUGIN_HOST(2356): initializing(vscode-language-pack-ja@1.78.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2023-11-14T08:42:21.509Z root INFO [hosted-plugin: 2356] PLUGIN_HOST(2356): initializing(vscode-language-pack-ko@1.78.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2023-11-14T08:42:21.513Z root INFO [hosted-plugin: 2356] PLUGIN_HOST(2356): initializing(vscode-language-pack-nl@1.48.3 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2023-11-14T08:42:21.526Z root INFO [hosted-plugin: 2356] PLUGIN_HOST(2356): initializing(vscode-language-pack-pl@1.78.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2023-11-14T08:42:21.529Z root INFO [hosted-plugin: 2356] PLUGIN_HOST(2356): initializing(vscode-language-pack-pt-BR@1.78.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2023-11-14T08:42:21.530Z root INFO [hosted-plugin: 2356] PLUGIN_HOST(2356): initializing(vscode-language-pack-ru@1.78.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2023-11-14T08:42:21.530Z root INFO [hosted-plugin: 2356] PLUGIN_HOST(2356): initializing(vscode-language-pack-tr@1.78.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2023-11-14T08:42:21.532Z root INFO [hosted-plugin: 2356] PLUGIN_HOST(2356): initializing(vscode-language-pack-uk@1.48.3 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2023-11-14T08:42:21.540Z root INFO [hosted-plugin: 2356] PLUGIN_HOST(2356): initializing(vscode-language-pack-zh-hans@1.78.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2023-11-14T08:42:21.540Z root INFO [hosted-plugin: 2356] PLUGIN_HOST(2356): initializing(vscode-language-pack-zh-hant@1.78.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2023-11-14T08:42:21.579Z root INFO [hosted-plugin: 2356] PLUGIN_HOST(2356): PluginManagerExtImpl/loadPlugin(/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-arduino-api/extension/dist/extension.js)
2023-11-14T08:42:21.624Z root INFO [hosted-plugin: 2356] PLUGIN_HOST(2356): PluginManagerExtImpl/loadPlugin(/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-builtin-json-language-features/extension/client/dist/jsonMain)
2023-11-14T08:42:21.670Z root INFO [f9e22ced-a85e-4e39-b828-ab488e6baa5f] Starting plugins.
2023-11-14T08:42:21.690Z root INFO [hosted-plugin: 2356] PLUGIN_HOST(2356): PluginManagerExtImpl/loadPlugin(/Applications/Arduino IDE.app/Contents/Resources/app/plugins/cortex-debug/extension/dist/extension.js)
2023-11-14T08:42:21.743Z root INFO [hosted-plugin: 2356] Debug configuration provider has been registered: cortex-debug, trigger: 1
2023-11-14T08:42:21.754Z root INFO [hosted-plugin: 2356] GDB server console created
2023-11-14T08:42:21.760Z root INFO [f9e22ced-a85e-4e39-b828-ab488e6baa5f] Start of 23 plugins: 3452.9 ms [Finished 12.840 s after frontend start]
