SQL: PROBLEM TO CONNECTION
Hello friends,
I’m doing a system where the arduino writes directly to Mysql database , I am using xampp tool, 3306 , User root and no password , but arduino is only accusing the connection fails, someone could help me with this problem ?
Under the code:
#include < SPI.h >
#include < Ethernet.h >
#include < sha1.h >
#include < stdlib.h >
#include < mysql.h >
mac_addr byte = { 0xDE , 0xAD , 0xBE , 0xEF , 0xFE , 0xED } ;
IPAddress SERVER_ADDR ( 192, 168, 1, 10 ) ; // Supply the IP of the MySQL server * * here
char user = " root" ;
char password = “”;
Connector my_conn ;
void setup () {
Serial.begin ( 115200 ) ;
while ( Serial !) ;
Ethernet.begin ( mac_addr ) ;
delay ( 1000) ;
Serial.println ( “Connecting …”);
if ( my_conn.mysql_connect ( SERVER_ADDR , 3306 , user , password ) ) {
delay ( 1000) ;
Serial.println ( " Connection failed. " ) ;
void loop () {
I'm doing a system where the arduino writes directly to Mysql database
It is orders of magnitude simpler to write a PHP script that reads the data and deals with storing it in the database.
I would like to use the mysql connector library to have nothing in the middle interfering
marlonrettore: I would like to use the mysql connector library to have nothing in the middle interfering
Well, OK. Good luck.
