Hi all, I have a simple use of the library, I need to open and retrieve data from a small database. I found that the library is only working with files created by itself, is there a way to make a file using a PC, and then open it on the Arduino, thank you
You can install SQLite on your PC. I can not guarantee the compatibility between the PC version and the Arduino version, you will have to check.
I have checked this, the problem is with the signature, as I see from the error log
