Square of the variable is negative
I’m so new to the arduino and this forum.
My question is - why I’m getting negative value (a) of the square of my ax axis. And actually, itsn’t square of ax value.
My code is:
#include "MPU6050.h"
MPU6050 accelgyro;
int16_t ax, ay, az;
int16_t gx, gy, gz;
    accelgyro.initialize();
    accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
 if (ax < 0)
          {ax = -ax;
        Serial.print("ax = "); Serial.println(ax);
        int a = sq(ax);
        Serial.print("a = "); Serial.println(a);
thank you
Multiplying int16_t by int16_t gives an intermediate int16_t result. If you multiply 1000*1000, the result won't fit in int16_t and (IIRC) you get the low-order 16 bits of the result. Using "ax = -ax" will make the result positive but it still won't have the correct magnitude.
Pete
thanks!
You need to use variables that are a suitable size to hold the intermediate and final values for a calculation.
It can help to plan the order of calculation so as to keep the size of intermediate values reasonable.
...R
