I’m currently working on a quadcopter control system, and I’m having a small problem.
There are two parts of the whole thing:
a transmitter which sends messages on serial monitor like
<1234123412341234>
containing markers to indicate the beginning and the end of the message, and four 4-digit numbers generated according to the joystick axis values, -
a receiver to get the message, decode it, and make 62.5Hz square waves based on the axis states.
I’ve written two codes for the receiver.
One to convert text got from serial monitor to integer values:
int y = 0, t = 0, p = 0, r = 0;
boolean mE = false;
unsigned long timer;
static boolean mS = false;
static byte i = 0;
char rec;
while (Serial.available() > 0 && mE == false) {
rec = Serial.read();
if (mS == true) {
if (rec != '>') {
if (i >= 0 && i <= 3) {
y += digit(i, rec);
} else if (i >= 4 && i <= 7) {
t += digit((i % 4), rec);
} else if (i >= 8 && i <= 11) {
p += digit((i % 4), rec);
} else if (i >= 12 && i <= 15) {
r += digit((i % 4), rec);
i++;
else {
mS = false;
i = 0;
mE = true;
else if (rec == '<') {
mS = true;
if (mE == true) {
mE = false;
int digit(int i, int rec) {
switch (i) {
case 0:
return (rec - 48) * 1000;
case 1:
return (rec - 48) * 100;
case 2:
return (rec - 48) * 10;
case 3:
return (rec - 48);
And another one to generate squarewaves:
DDRD = B11111110;
DDRD = DDRD | B11111100;
timer = micros();
do {
if (micros() - timer <= y) PORTD = B00010000;
else if (micros() - (timer + y) <= 4000) PORTD = B00000000;
} while (micros() - timer <= 4000);
timer = micros();
do {
if (micros() - timer <= t) PORTD = B00100000;
else if (micros() - (timer + t) <= 4000) PORTD = B00000000;
timer = micros();
do {
if (micros() - timer <= p) PORTD = B01000000;
else if (micros() - (timer + p) <= 4000) PORTD = B00000000;
timer = micros();
do {
if (micros() - timer <= r) PORTD = B10000000;
else if (micros() - (timer + r) <= 4000) PORTD = B00000000;
By changing y, t, p, r values in the code above, I got decent waves, and my flight controller also worked with them. But when putting these two sketches together into something like this:
boolean mE = false;
DDRD = B11111110;
static byte i = 0;
char rec;
if (mS == true) {
if (rec != '>') {
y += digit(i, rec);
i++;
else {
mS = false;
i = 0;
mE = true;
mS = true;
if (mE == true) {
mE = false;
timer = micros();
do {
timer = micros();
do {
timer = micros();
do {
timer = micros();
do {
switch (i) {
case 0:
case 1:
case 2:
case 3:
return (rec - 48);
The flight controller didn’t notice the signal, but according to my scope, they were kind of good.
Now, I’m really confused, so help me, please!
AFK
