Thanks Awol
The code I am using to run the SRF05 is :
int duration; // Stores duratiuon of pulse in
int distance; // Stores distance
int srfPin = 3; // Pin for SRF05
void setup(){
void loop(){
pinMode(srfPin, OUTPUT);
digitalWrite(srfPin, LOW); // Make sure pin is low before sending a short high to trigger ranging
delayMicroseconds(2);
digitalWrite(srfPin, HIGH); // Send a short 10 microsecond high burst on pin to start ranging
delayMicroseconds(10);
digitalWrite(srfPin, LOW); // Send pin low again before waiting for pulse back in
pinMode(srfPin, INPUT);
duration = pulseIn(srfPin, HIGH); // Reads echo pulse in from SRF05 in micro seconds
distance = duration/58; // Dividing this by 58 gives us a distance in cm
Serial.println(distance);
delay(50); // Wait before looping to do it again
I have also run the playback example code for my rmp3 shield and it is working.
I am trying to use the 'rmp3 trigger with delay code' as a starting point for my project:
I want to integrate the SRF05 to act as the trigger for the mp3 playback.
I have hacked these 2 pieces of code together, and added this in the loop:
if (distance < 20)
digitalWrite(INPUT_PIN, HIGH);
heres the mashed together code:
rMP3 Trigger with Time-Out Example
rMP3 Control Requirements
* Play songs in order when trigger is set.
* If trigger clears, start timer and stop
playback if timer runs out.
Assumptions
* When timer runs out, playback starts
at the beginning.
* Playback will continue if trigger re-sets
before timer runs out.
#include <RogueSD.h>
#include <RogueMP3.h>
#include <NewSoftSerial.h>
// 30 second timeout
#define TIMER_MAX 30000
#define INPUT_PIN 8
// Objects
NewSoftSerial rmp3_serial(6, 7);
RogueMP3 rmp3(rmp3_serial);
RogueSD filecommands(rmp3_serial);
// global variables
int numberOfSongs;
int currentSong = 0;
boolean triggered = false;
boolean playing = false;
uint32_t triggerTimer = 0xffffffff - TIMER_MAX;
char filePath[96];
// consts
const char *directory = "/";
delay(50);
pinMode(INPUT_PIN, INPUT);
rmp3_serial.begin(9600);
// synchronize audio player
rmp3.sync();
rmp3.stop();
// synchronize file system controller
filecommands.sync();
Serial.println("rMP3 Synchronized.");
// get the number of songs available
strcpy(filePath, directory);
strcat(filePath, "/");
strcat(filePath, "*.mp3");
numberOfSongs = filecommands.filecount(filePath);
if (numberOfSongs < 0)
// rMP3 error
if (filecommands.LastErrorCode == 8)
Serial.println("No card inserted.");
Serial.print("rMP3 Error Code: ");
Serial.println(filecommands.LastErrorCode, HEX);
Serial.println("Reset required to continue.");
for (;;);
Serial.print(numberOfSongs, DEC);
Serial.println(" files available.");
// rewind directory
filecommands.opendir(directory);
Serial.println("Awaiting trigger.");
// Play next song, if we can
void playNextSong()
char filename[80];
if (playing == true)
if (filecommands.status() == 0)
// card is inserted and good to go
if (currentSong == 0)
// rewind directory
if (currentSong < numberOfSongs)
// get the next song
filecommands.readdir(filename, "*.mp3");
rmp3.playfile(directory, filename);
Serial.print("Playing: ");
Serial.print(directory);
Serial.print('/');
Serial.println(filename);
currentSong++;
playing = false;
currentSong = 0;
for (;;);
// This is the function to check the input
boolean checkTrigger(void)
if (digitalRead(INPUT_PIN) == HIGH)
return true;
return false;
Main loop
char rMP3Status = rmp3.getplaybackstatus();
if (distance < 20)
// First, check the trigger
if (checkTrigger())
if (triggered == false)
Serial.println("Trigger set.");
if (playing == false)
// Start from the top
playing = true;
currentSong = 0;
triggered = true;
if (triggered == true)
Serial.println("Trigger cleared.");
triggered = false;
triggerTimer = millis();
if ((millis() - triggerTimer) > TIMER_MAX)
playing = false;
Serial.println("Playback stopped.");
if (rMP3Status == 'P')
// stop playback
rmp3.stop();
if (triggered == true || ((millis() - triggerTimer) < TIMER_MAX))
if (rMP3Status != 'P')
playNextSong();
// Arbitrary delay
delay(250);
When I run it, the activity light on the rmp3 flashes 3 times quickly and goes off. In the serial monitor I see :
rpm3 synchronised
3 files available
Trigger set
Playing // Snake Awake.mp3
Playing // Track 2.mp3
Playing// Track3.mp3
These are the 3 tracks on my sd card. It seems to begin playing the track then skips instantly on to the next and so on until it stops.
I hear no audio.
Can anyone help ?
Many Thanks
Twogan
