SRF02 serial com protocol error! please help
im working in diecimila with a srf02 range finder. i read Tech Specs and connected it, programmed, and yet a get an error when y run it.
Error is "avrdude: stk500_paged_load(): (a) protocol error, expect=0x14, resp=0x00
avrdude: stk500_cmd(): programmer is out of sync"
so my questions are:
Can a write to SRF02 then read from it and then read with serial monitor in my computer? or is this causing the error
How can i know if my SRF02 is actually recieving commands and writing the range to the arduino, anyone has worked with SRF02 in serail mode before...?
i read Tech Specs
Always a good thing.
and connected it,
How?
programmed,
Huh? There is nothing on that device to be programmed.
This is not a run-time error. This is an upload error. If you are trying to upload code to the sensor, it's no wonder you have a problem.
If you are trying to upload code to the Arduino board, and you get this error with the sensor attached, but not without the sensor attached, it should be obvious what you need to do.
Ok thank you Paul i solved the error, i wasnt trying to program the SRF02 though, but since it was connected during upload i guess some program package was mistaken for a comand and the sensor responded so it caused a failed upload. thank you for your sugestion.
Yet i havnt been able to get it to work yet, what i meant woth connecting was:
5v from arduino to 5v in SRF02
Tx in arduino to RX in SRF
RX in arduino to Tx in SRF
GNd in arduino to GND and MODE in SRF
What i meant with program was this:
int incomingByte = 0; // for incoming serial data
void setup() // run once, when the sketch starts
Serial.begin(9600); // set up Serial library at 9600 bps
void loop() // run over and over again
Serial.println(00); // srf02 direction
Serial.println(83); //srf02 starte rangeing command
delay(100);
// send data only when you receive data:
if (Serial.available() > 0) {
// read the incoming byte:
int incomingByte = Serial.read();
// say what i received:
Serial.print("I received: ");
Serial.println(incomingByte, HEX);
im using serial monitor yet i can only see what i send, i dont get any answer from srf02..
Any sugestions?
According to this site, SRF02 Ultra sonic range finder, you should send the sensor 2 bytes to start it working. The first byte is the address of the device (0 by default). The second byte is the command - what the sensor should do.
You, instead, are sending it 6 bytes - 0, , , 83, , .
Not really surprising then that the sensor doesn't respond. It doesn't know how to . So, stop sending the . Use Serial.print, not Serial.println.
