So yeah, I can't figure out why, but i hooked it up according to this:
http://arduino.cc/playground/Main/SonarSrf08
and this is the code :
#include <Wire.h>
#define srfAddress 0x70 // Address of the SRF08
#define cmdByte 0x00 // Command byte
#define lightByte 0x01 // Byte to read light sensor
#define rangeByte 0x02 // Byte for start of ranging data
void setup(){
Wire.begin(); // Initialize the I2C bus
Serial.begin(115200); // Initialize the serial connection
delay(100); // Waits to make sure everything is powered up before sending or receiving data
void loop(){
//int rangeData = getSoft(); // Calls a function to get software version
int rangeData = getRange(); // Calls a function to get the range data
int lightData = getLight(); // Calls a function to get the light data
Serial.print("Range: ");
Serial.print(rangeData);
Serial.println("cm");
Serial.print("Light: ");
Serial.print(lightData);
Serial.println("");
delay(100); // Wait before looping
int getRange(){ // This function gets a ranging from the SRF08
int range = 0;
Wire.beginTransmission(srfAddress); // Start communicating with SRF08
Wire.write((byte)cmdByte); // Send Command Byte
Wire.write(0x51); // Send 0x51 to start a ranging in cm
Wire.endTransmission();
delay(100); // Wait for ranging to be complete
Wire.beginTransmission(srfAddress); // start communicating with SRFmodule
Wire.write(rangeByte); // Call the register for start of ranging data
Wire.requestFrom(srfAddress, 2); // Request 2 bytes from SRF module
while(Wire.available() < 2); // Wait for data to arrive
byte highByte = Wire.read(); // Get high byte
byte lowByte = Wire.read(); // Get low byte
range = (highByte << 8) + lowByte; // Put them together
return(range); // Returns Range
int getLight() { // Function to get light reading
Wire.write(lightByte); // Call register to get light reading
Wire.requestFrom(srfAddress, 1); // Request 1 byte
while(Wire.available() < 0); // While byte available
int lightRead = Wire.read(); // Get light reading
return(lightRead); // Returns lightRead
int getSoft(){ // Function to get software revision
Wire.beginTransmission(srfAddress); // Begin communication with the SRF module
Wire.write((byte)cmdByte); // Sends the command bit, when this bit is read it returns the software revision
int software = Wire.read(); // Get byte
return(software);
It blinks on start up then nothing if I enter the Serial monitor.
Any ideas?
