Hi, I have a question about this code, can I use sscanf to seperate mystring1 ? When I had "1,new" it worked but when string is first "new,1" it doesn't work because as led_on_off it returns "new,1"
mystring1 = "new,1";
char new[50];
mystring1.toCharArray(new,50);
int led_bright;
char led_on_off[10];
if(sscanf(new, "%s,%d",led_on_off,&led_bright)==2)
Serial.println(led_bright);
Serial.println(led_on_off);
strtok() would be a better choice.
guix
October 29, 2021, 6:50pm
3
Hello
%s
will read until a whitespace. As there is no whitespace in your string, it will read the entire string new,1
and your if condition will fail because sscanf
didn't return 2
Instead of %s
you have to use something like %[^,]
which means read everything until ,
J-M-L
October 29, 2021, 8:55pm
4
And side note, I would not use new for the buffer nameā¦
The new operator is a reserved keyword (technically an operator which denotes a request for memory allocation on the Heap).
String mystring1 = "new,1";
char new1[50];
mystring1.toCharArray(new1,50);
int led_bright;
if (sscanf(new1, "%[^,],%d", led_on_off, &led_bright) == 2)
//if(sscanf(new1, "%s,%d",led_on_off,&led_bright)==2)
Or, leaving out the useless String:
char line[] = "new,1";
int led_bright;
int x = sscanf(line, "%[^,],%d", led_on_off, &led_bright);
if (x == 2)
void loop() {}
wsdl123:
char new[50];
how does it let you compile? new is a reserved keyword nkw9pu - Online C++0x Compiler & Debugging Tool - Ideone.com
system
Closed
April 27, 2022, 10:33pm
8
