Sscanf function in arduino code
Could somebody please put me out of my misery..
I use the following code:-
Serial.println("Start example");
char buffer[16];
sscanf(buffer, "1234567890");
Serial.println(buffer);
Serial.println("End Example");
The "1234567890" is not sent.
What am I doing wrong?
It is not clear what you are trying to do, but the code you posted won't do anything useful.
Take a look at some tutorials on how to use sscanf(). Randomly chosen example:
Did you mean to copy the string, using strcpy()?
char buffer[16];
strcpy(buffer, "1234567890");
Serial.begin !
Well, no, it wouldn't be sent. That's not how you use sscanf. sscanf reads formatted data from a string and stores it into variables according to a format string.
What this what you were trying to do?
   char buf[] = "1234567890";
   unsigned long result;
   sscanf(buf, "%lu", &result);
   Serial.println(result);
Or were you simply trying to copy "1234567890" into buf, as @jremington showed?
look this over
const char *prompt = "enter cmd: ";
void
loop (void)
    if (Serial.available ())  {
        char buf [90];
        int  n = Serial.readBytesUntil ('\n', buf, sizeof(buf)-1);
        buf [n] = '\0';
        int  val;
        char cmd [10];
        sscanf (buf, "%d %s", & val, cmd);
        Serial.print ("cmd ");
        Serial.print (cmd);
        Serial.print (", val ");
        Serial.println (val);
        Serial.print (prompt);
void
setup (void)
    Serial.begin (9600);
the C Programming Language pg 140
Thanks everybody the example I gave was not good.
What I'm actually trying to do is output to a parallel port (8 pins) on an ESP32 text that will contain variables.
I wrote a function to output text on that parallel port and it works fine.
Now I want to output text containing variables.
I was just using Serial.println() to simplify the question. Now realize it was an incorrect example.
Rephrasing the question how do I do something like:-
char buffer[64];
sscanf(buffer,"text string" + a variable number + more "text string");
Thanks in advance
John
Clearly, you have no idea what the function sscanf() actually does, and we still don't know what you are trying to do.
sprintf() can produce a formatted string like the above
int val = 1234;
char buffer[40];
sprintf(buffer, "text string %d more text string", val);
Serial.println(buffer);  //prints: text string 1234 more text string
Thanks that's it!!!
John
