I have a problem with clearing the SSD1306 buffer. No matter what I do I can't get it to clear after each "case." If I you observe in "Case 1" the line display.print( "TANK") it will display TANK in the display, but that display line will remain on the display when the sketch moves to "Case 2". You can see in the code below the display should change to "TANKTWO". but it just remains on "TANK".
The data (ie distance and voltage) do change. Any idea how to fix this?
case 1:
LoRa.readBytes((byte *)&struct1 + 1, packetSize - 1); // receive struct1 packet
struct1.StructureID = structureID;
Serial.println(" Tank 1 ");
Serial.print(struct1.seq);
Serial.print(" distance 1 = ");
Serial.print(struct1.distance);
Serial.print(" voltage 1 = ");
Serial.println(struct1.voltage);
checkSeqNumber(struct1.NodeID, struct1.seq);
display.clearDisplay();
display.setTextSize(2);
display.setCursor(30, 0);
display.print("TANK");
display.setTextSize(1);
display.setCursor(0, 25); //First line
display.print("water down ");
display.print(struct1.distance);
display.print(" in");
display.setCursor(0, 35); //second line
display.print("volts ");
display.print(struct1.voltage);
display.display();
delay(2000);
// case 2:
LoRa.readBytes((byte *)&struct2 + 1, packetSize - 1); // receive struct1 packet
Serial.println(" Tank 2 ");
Serial.print(struct2.seq);
Serial.print(" water down = ");
Serial.print(struct2.distance);
Serial.print(" voltage is ");
Serial.println(struct2.voltage);
checkSeqNumber(struct2.NodeID, struct2.seq);
display.print("TANKTWO");
display.print(struct2.distance);
display.print(struct2.voltage);
display.display();
delay(2000);
