ssd1306 (128x64) why most image sizes doesnt work below 128x64 size?
Hello.
I am struggling to understand why most image sizes doesnt work below 128x64 size.
I am using Adafruit libary and ssd1306 display
TEST:
I did a simple image 109x36 with PAINT in monocrome.
Then I used LCD Asistant to create the hex code of the image.
This is the main coding line: display.drawBitmap(0,0,test109x36,109,36,WHITE);
The image result in the sdd1306 is a mess, with chaotic dots and lines
....buuut when I went down to 104x36 in "w" and "h" in the code:
display.drawBitmap(0,0,test109x36,104,36,WHITE)
I got the correct image but with 104 width.
So, why I cant use any size image I want below 128x64 with ssd1306 + Adafruit?
Does anybody know what must be the ratio between the width and the height?
Thank you!
The resident psychic is on vacation this month.
Normal mind-reading services will be resumed in July.
If you can't wait until then . . . post your code.
